Honda Cg125
benjih2
PostPosted: 20:08 - 15 Apr 2016    Post subject: Honda Cg125 Reply with quote
Hey guys, this is my 78 honda cg (picture attached).
I have a few questions in which I was hoping someone may be able to answer at least one!
Firstly, to my knowledge this is the original paintwork, could anyone let me know what the paint colour is called? I have tried looking up online and not have been able confirm what colour it is. I have a feeling it is the Candy Orange colour but am not entirely sure if this is correct?
Secondly, recently I have noticed that my indicators wont work all the time. If I am stopped at a roundabout indicating right (no brake applied) it will not indicate, but when I'am half way around the bout it will start to indicate no problem. TBH I have no idea what could cause this?
Finally, my gears sometimes lock when trying to change down typically from 3rd to second. I have an incling it may be oil related as the oil is currently looking like its had a date with a dragon! A change and clean of the filter is due. However could be something different.
I will be off work tomorrow and able to have a little tinker and do the oil change to see if the gear problem is sorted from that.
Many thanks in advance and thanks for your time!
Cheers and gone
Ariel Badger
PostPosted: 20:17 - 15 Apr 2016    Post subject: Reply with quote
Please do not repaint it, looks great as it is.
benjih2
PostPosted: 20:18 - 15 Apr 2016    Post subject: Reply with quote
i have no intentions of repainting it matey! my mates dad sprays cars and has offered to respray it (as it has a few rust spots) if i can find the original paint which im well keen to do!
Cheers and gone..
Ariel Badger
PostPosted: 22:39 - 15 Apr 2016    Post subject: Reply with quote
Re paint/Re spray, same thing. It deserves a few spots of rust at 37 years old, it is called patination and is greatly prized.
PostPosted: 08:19 - 16 Apr 2016    Post subject: Re: Honda Cg125 Reply with quote
The paintwork is subjective, but I agree that honest original is better than a respray which will just raise questions about why it's been done.
The indicator, I'd slap a multimeter on and see how much voltage you're getting at idle and when revving. You may simply not be getting enough to trip the relay. Diagnosis before random replacement. I believe that's a 6v model, although it may have been converted to 12v along the way.
Absolutely change the oil and clean the centrifugal filter. It only takes a litre of the cheapest 10W40. Also, how's your chain tension and condition?
kramdra
PostPosted: 14:33 - 16 Apr 2016    Post subject: Reply with quote
Horrible, tatty bike. Some people might respect the age of paint, I think it makes owner look like a tramp. It looks neglected, therefore if any intention of keeping it, check wheel bearings, brakes and forks. I would not be riding until oil is changed if it has a gear issue.
The frame would greatly benefit from a clean - not water but with an oil soaked rag. I do this with all steel frame bikes.
benjih2
PostPosted: 16:57 - 16 Apr 2016    Post subject: Reply with quote
It does look out of shape. I bought it from a chap who had it in his garage for over 4 years and never ridden! it was bound to be tatty.. ive not had the time to give it a good clean. it had no issues when it was MOT'd and for something thats 37 years old, its in good shape!
Cheers and gone..
mauzo
PostPosted: 17:31 - 16 Apr 2016    Post subject: Re: Honda Cg125 Reply with quote
Cleaning the centrifugal filter is a pain on CGs: you need a special tool to get it off the crankshaft. Unless oil changes have been seriously neglected in the past it's probably not worth it. Just change the oil and keep an eye on its colour.
'04 CG125, '07 CBF500
PostPosted: 18:02 - 16 Apr 2016    Post subject: Re: Honda Cg125 Reply with quote
That's why I fully expect that it's never been done, let alone every 7500 miles as per the schedule.
It's a CG125, so again I'd expect that it's been neglected. Bulletproof, mate, never needs nothing done to it, no worries.
Did you read what OP wrote about the oil?
mauzo
PostPosted: 20:32 - 16 Apr 2016    Post subject: Re: Honda Cg125 Reply with quote
Fair enough.
OP: I've got the magic socket you need, and I see you're down in Cornwall. If you felt like popping up to Totnes sometime you could borrow it.
kramdra
PostPosted: 09:34 - 17 Apr 2016    Post subject: Reply with quote
I cleaned it 3 times in the 6k miles I owned my 92. The filter body does not need to come off, just remove the lid and clean it in place.
However I did have to drill out the JIS screws. Order some M5 x 50? Csk allen head bolts before you start.
skyliner22
PostPosted: 11:57 - 17 Apr 2016    Post subject: Reply with quote
Keep the paint original unless you want to go down the full restore root!, you could try polishing it
I'm a CG lover i have Three now a J reg Brazil a 2001 classic looking one, and another Brazil for parts.
on one of the replacement engines i had a lot of times my gears felt they were locking up when i was switching down i found out it was due to my clutch it just needed adjusting it wouldn't pull in all the time it felt like it did and it would temporarily cause them to lock.
and indicators not working do remember this is a 6v bike so it needs to be running for the indicators to run and its quite old wiring it might need a couple of patches grab a multi meter like everyone else said they're cheap
just out of curiosity how much did you pay? as i was looking at classic ones like this a while ago but dont seem to pop up for under 900
Edit: this is the tool you need for the filter
Singe Cylinder fan club: CG x 2 , NC50 x 1, Kawasaki Kx250
kramdra
PostPosted: 13:22 - 17 Apr 2016    Post subject: Reply with quote
That is the tool you dont need for the filter. There is no advantage to removing it completely. This is the filter we are talking about, clean it in place.
https://www.dansmc.com/changeoil_centrifugal2.jpg
So you had 3 cg125's and a replacement engine, yet you dont know how to adjust clutch and change gears properly? Laughing
There couldnt be a more simple bike for electrics. Rewire the whole lot in an afternoon will cost about 30 quid in wire and proper connectors, rather than shitty bullets. Not that anyone with one of these would have 30 quid...
benjih2
PostPosted: 14:39 - 17 Apr 2016    Post subject: Reply with quote
havent managed to do my oil change yet cos i didnt have a 24mm spanner but will get that done today! i actually picked this bike up for £350! a lot of people on the forum have said its in pretty shoddy condition from how it looks but its 37 years old, running beautifully and cost me feck all Very Happy i aint complaining, i love it!
Cheers and gone..
PostPosted: 15:31 - 17 Apr 2016    Post subject: Reply with quote
A running 125 for £350 is a great buy. Thumbs Up
benjih2
PostPosted: 17:55 - 17 Apr 2016    Post subject: Reply with quote
a running cg with just over 25k on the clock is even better Wink
Cheers and gone..
Tamsin
PostPosted: 18:10 - 17 Apr 2016    Post subject: Reply with quote
fantastic buy!
First thing I would be doing re the gears is change the oil and check the clutch adjustment... I've run mine with the clutch out of whack and it makes changing gears an utter pain in the arse...
Billy Balthorpe
PostPosted: 21:26 - 17 Apr 2016    Post subject: Reply with quote
I'm sure CG125's have a mechanism which will not let you bang it all the way down the box in one go. You have to drop the clutch in about 3rd, then carry on going down the box. I think they did it to stop people easily dropping valves by over revving during downshifts. From memory, that's how John Robinsons nitrous CG died in a Performance Bikes Challenge, so its still possible to kill one even with the mechanism in place.
M.O.B. Successfully taking the piss since 2014.
skyliner22
PostPosted: 21:42 - 17 Apr 2016    Post subject: Reply with quote
Rolling Eyes clearly I do ha. stop acting like a spoilt little girl slagging people off. This is a forum dedicated to helping people, not for showing off and acting like a knob. I like CG's, that's my preference Middle Finger Very Happy Middle Finger
Moxey
PostPosted: 23:00 - 17 Apr 2016    Post subject: Reply with quote
A friend sold her 76 CG last year for a grand, she had paid 900 for it (quite clean, only deviation from standard was flat bars), she did feck all but Polish the thing, no idea who was willing to pay that much for a dull but shiny 70s commuter
The 77 model I got the other half cost 180 2 years ago!
benjih2
PostPosted: 00:49 - 18 Apr 2016    Post subject: Reply with quote
there seems to be a fair amount that ive seen over a grand! ive even seen some over 2g which have been pretty much entirely altered.. im sure you know there is a lot you can do with them.. however, this is a bike that i hope to keep for many more years! i'am almost 23 and hope to keep riding this well into my late 30's! i donpln to do a lot of refurbishment to it, but until i have a garage/more time, i cant! Sad
Cheers and gone..
lilredmachine
PostPosted: 12:37 - 18 Apr 2016    Post subject: Reply with quote
I have been offered 1800 quid for my custom built cafe racer, but she ain't for sale. Haha.
https://i.imgur.com/8Cct5gn.jpg
hondakawasaki
PostPosted: 00:50 - 19 Apr 2016    Post subject: Reply with quote
my old cg had the paint color code under the seat on the mud guard Thumbs Up
benjih2
PostPosted: 10:35 - 19 Apr 2016    Post subject: Reply with quote
Ideal will have a check tomorrow as i now have all the right tools for the job Very Happy
Cheers and gone..
The last post was made 10 years, 216 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: biskey (www) - Page Generation Time: 0.11 Sec - Server Load: 1.19 - MySQL Queries: 16 - Page Size: 131.38 Kb
