Band Saws
dydey90
PostPosted: 12:58 - 25 Jul 2016    Post subject: Band Saws Reply with quote
Just had a new kitchen floor put down, which looks the business. But, the fitter had to take off the kick-plates from the bottom of the kitchen units which now will not fit due to their being floor under them, rather than up to them.
Ideally, I'd like to use a band saw to do a nice even job of skimming some wood off the bottom of the boards to make them fit again, but I don't have one.
Is there such a thing as a workshop that'll hire me a saw for around half an hour?
I could jigsaw them but I'm worried that I won't get it quite even as I don't have any sort of clamp or jig to set it up with.
weasley
PostPosted: 13:14 - 25 Jul 2016    Post subject: Reply with quote
I did ours on a table-top circular saw with a fine-tooth blade. Same for getting a bit off the bottom of the door. I'd imagine even a hand-held circular saw with a cutting guide on it would be OK.
dydey90
PostPosted: 13:26 - 25 Jul 2016    Post subject: Reply with quote
I've found a couple of table saws for sale locally, sort of a flat surface with a circular saw poking through and a clamped guide on one side.
Having a ring around now, hopefully be problem solved.
Suntan Sid
PostPosted: 13:32 - 25 Jul 2016    Post subject: Reply with quote
If you've never used a band saw before, you might find it a bit tricky, they take a hell of a lot of setting up and cutting a straight line, over a long length of wood, is not as easy as it appears!
I've done the same job and used a jig saw, for a rough cut, then used a router to square up and make everything neat!
UnknownStuntm...
PostPosted: 14:37 - 25 Jul 2016    Post subject: Reply with quote
If the floor is flat, don't cut the bit that touches it, cut the bit that meets the bottom of the cabinet carcass. When you're stood up, you can't see that bit - unless you make a right crap job of it. I'd use a jigsaw and do it by eye.
Tracey Suntan-King
PostPosted: 15:39 - 25 Jul 2016    Post subject: Reply with quote
Dydey, can. Just I ask you to reflect on whether it's wise to accept advice on powerful, sharp tools from someone called Stuntman?
He sounds like a risk-taker to me......
HTH
Edit: I've just seen Sid's reply, it may also help you to know that Sid is not allowed sharp cutty things on account of needing all his fingers Laughing
growler
PostPosted: 16:26 - 25 Jul 2016    Post subject: Reply with quote
I second this cut the top of the board could even use a good hand saw if careful
DILLIGAF
J4mes
PostPosted: 17:08 - 25 Jul 2016    Post subject: Reply with quote
Got the same to do this week, using a circular saw to take the top of the board off.
Looked at table saws but cheapest one was screwfix for £99, which is a bit much for one job tbh.
dydey90
PostPosted: 17:15 - 25 Jul 2016    Post subject: Reply with quote
I have solved my problem by having to spend some money. Bought a table saw for £60.
Despite the above advice, I've taken the excess off the bottom because there was a veneer on the top and three of the pieces had wiggly bits* cut out for the skirting boards. I've only skimmed 5mm off and it's all now fitting in nice and flush.
I'm thinking about finishing it with a dab of silicon to seal the counter to the floor, so water can't get through and damage the counters or the MDF underneath the laminate. The counters are white so it should blend in nicely enough.
*stop me if I'm getting too technical
You can get away with it if you're dead 'ard. I didn't attach the blade guard to my saw and I didn't have any safety glasses or gloves and no kittens were damaged in any way.
stevo as b4
PostPosted: 17:24 - 25 Jul 2016    Post subject: Reply with quote
I need a table saw myself at the moment. I've got about 4x 3m lengths of 3-4'' wide planks to cut. Theres no way on anything small in width I'd go near it with a circular saw, too much risk of tragedy with a bodged up saw guide strip etc.
I did think of clamping the circular saw upside-down in a work mate and cable tying the on switch down for a while, and quite liked the idea before realising what a lunatic I was being. Laughing
I've run a jig saw with a sharp blade along a straight edge on thin boards with some success, but you've still got the same problem when you get to narrow planks like plinths etc.
Table saw is the only right tool for the job, and though they are big and bulky to store, I get the feeling once you've got one it'll be one of those tools you wondered how life ever existed before that moment.
Maybe we need to buy a BCF table saw and pass it around for all those of us that have one or two awkward jobs and then we're done with it?
dydey90
PostPosted: 18:02 - 25 Jul 2016    Post subject: Reply with quote
I had the exact same thought process earlier until I realised I was planning out which route to the hospital would be easiest to take if I needed to drive with no fingers.
Anybody is welcome to borrow mine. Kitchen is finished now so I'll probably never need it again. Wish I'd had it a few weeks ago though when I had to fit some new skirting boards and was cutting the 45 degree angle for the corners with my dads manual mitre saw.
PostPosted: 20:07 - 25 Jul 2016    Post subject: Reply with quote
I'm presuming they're fibreboard rather than proper wood/ply or the correct tool would be a plane.
It still might be.
A router would also do it.
mentalboy
PostPosted: 01:27 - 26 Jul 2016    Post subject: Reply with quote
... it may also help you to know that Sid is not allowed sharp cutty things on account of needing all his fingers Laughing
The sewer that is my brain just had a WTF moment. Please clarify where exactly it is that Sid needs all 8 digits Shocked
Make mine a Corona.
Ribenapigeon
PostPosted: 19:48 - 26 Jul 2016    Post subject: Re: Band Saws Reply with quote
Two G-clamps and a length of wood to use as a goude when you jigsaw them is hardly going to rbeak the bank. Do the cut at the top edge of the kickboard so any roughness will be hidden.
The last post was made 9 years, 237 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.11 Sec - Server Load: 2.04 - MySQL Queries: 16 - Page Size: 88.15 Kb
