Seat problem FZ1N
Stewy67
PostPosted: 20:12 - 15 Aug 2016    Post subject: Seat problem FZ1N Reply with quote
Today i changed the battery on my FZ1N took the battery off disconnected the wires easy no problem. put the battery on connected the wires now the seat won't lock back in place. a proper head scratcher can anyone help please.
Stewy
CaNsA
PostPosted: 20:20 - 15 Aug 2016    Post subject: Reply with quote
Is the battery the same size?
Take everything apart, compare the battery sizes and put it back together again.
Suntan Sid
PostPosted: 20:42 - 15 Aug 2016    Post subject: Reply with quote
The battery box/space on an FZ1-N is very tight!
Are you absolutely certain that the new battery has gone in square?
Are you absolutely certain that you didn't leave a nut/bolt/spanner in the bottom of the battery box/space?
Are you absolutely certain that seat is correctly engaged with the tank/frame at the front and the latch at the back?
Stewy67
PostPosted: 22:52 - 15 Aug 2016    Post subject: Reply with quote
Ye checked everything no obstructions only used a Alan key the disconnect the battery so nothing left in the space. I've just replaced it with the same one but i just cant get the seat to lock back into position. the connection on both sides are to high to lock the seat in place. I've not done anything else other than take one out n put one inn.
Suntan Sid
PostPosted: 13:14 - 16 Aug 2016    Post subject: Reply with quote
Have you tried giving the seat a thump?
The seat on mine doesn't just drop into place, I have to give it a thump to get it to 'click' into place.
To remove the front seat, you have to take the rear seat off, has something that was under the rear seat been dislodged which is now blocking the front seat.
Also on mine there is a piece of heat shield material attached to the side of the battery, has this got wrinkled up stopping the battery dropping into place?
Stewy67
PostPosted: 13:28 - 16 Aug 2016    Post subject: Reply with quote
I've sorted it now mate all done. i just removed the spacer from the connection.
The last post was made 9 years, 334 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.10 Sec - Server Load: 1.14 - MySQL Queries: 16 - Page Size: 49.79 Kb
