removing warning light bulb for mot?
Hahadumball
PostPosted: 00:06 - 23 Aug 2016    Post subject: removing warning light bulb for mot? Reply with quote
vw beetle done goofed, esp light is on and wont gtfo... removing bulb for mot tomorrow wise or?
Fin: no matter how much I look at It I can't understand what was going through my head, all I remember is going about 80 and redlining it to stop it seizing.
360 Deg... Five 1/4 turns. :- Teflon-Mike 18 Jan 2015
dransy
PostPosted: 06:44 - 23 Aug 2016    Post subject: Reply with quote
Go for it . I've done it loads before
PostPosted: 08:06 - 23 Aug 2016    Post subject: Reply with quote
Awaits the EU mandating a "bulb removal warning bulb".
For future reference, do you have an OBD dongle?
https://www.ebay.co.uk/itm/162143945848 + https://play.google.com/store/apps/details?id=org.prowl.torquefree&hl=en_GB = diagnose and clear. You may find that it's a stored warning from a one-off wiring hiccup that you can just clear off. A friendly MOT tester will be OK with passing it as long as he can look at the dash and see no lights at that exact instant. Shhh!
PostPosted: 09:00 - 23 Aug 2016    Post subject: Reply with quote
ESP should be OK. There are some which will fail an MOT such as ABS, Air bag etc, but I doubt ESP would fail an MOT anyway.
Get all technical, wire all of the lights that should come on and go off into the circuit that shows the battery warning light.
That only comes on at the beginning and then turns off.
If all the lights come on, you treat it like an engine management fault. Laughing
Pjay
PostPosted: 09:25 - 23 Aug 2016    Post subject: Reply with quote
It's only red lights that are a bother to MOT stations, orange lights are not a safety issue.
My golf was one of the MK5 ones with the dodgy ESP that fell over.
VW now fit a free replacement part because it happened to so many. Maybe your Beetle has the same part?
I never bothered getting it changed as I turn ESP off anyhow and have never had a fail on the light, or even an advisory.
dydey90
PostPosted: 10:12 - 23 Aug 2016    Post subject: Reply with quote
Would probably still appear as an advisory though, which won't look good if there's a chance of selling the car inside of the year.
You've done this before, haven't you.
PostPosted: 10:13 - 23 Aug 2016    Post subject: Reply with quote
It should do. Actually, removing the bulb should be a fail as well.
https://www.gov.uk/government/uploads/system/uploads/attachment_data/file/518634/mot-inspection-manual-for-class-3-4-5-and-7-vehicles.pdf
3.4 Anti-Lock Braking and Electronic Stability Control Systems
Electronic Stability Control Systems are commonly referred to as ESC, but may also be known as ESP or some other acronym
Method of Inspection
1. If the vehicle is fitted with an ABS and/or ESC
system, check that the relevant warning
lamp(s):
a. is fitted
b. illuminates
c. does not indicate a fault
Reason for Rejection
1. A warning lamp:
a. is missing
b. does not illuminate
c. indicates a fault
PostPosted: 10:28 - 23 Aug 2016    Post subject: Reply with quote
What, me?
Shifty
Astra 1.4 m8 Laughing
Monkeywrenche...
PostPosted: 10:46 - 23 Aug 2016    Post subject: Re: removing warning light bulb for mot? Reply with quote
have you looked at the dash? pretty sure the warning lights are led and can't be removed. (from memory so not 100%)
2001 Aprilia RSV Mille R -dead, 2016 XSR 700-gone, 2018 Dorsoduro 900
PostPosted: 11:31 - 23 Aug 2016    Post subject: Re: removing warning light bulb for mot? Reply with quote
Gaffer tape is black, cover and run.
Wonko The Sane
PostPosted: 12:16 - 23 Aug 2016    Post subject: Reply with quote
It's Paddy, he's probably got the car through it's MOT with the dashboard either removed or held in place with gaffa tape but nothing on it working!
Hahadumball
PostPosted: 14:05 - 23 Aug 2016    Post subject: Reply with quote
plugged it in, lateral acceleration sensor is playing up...
i did try to get it out last night to see if its fixable or ready to replace.. after an hour in the footwell upside down and half the dash off i admitted defeat and bashed it back togetger, took for mot today and passed.
advisory on oil leak and rust on sill.
happy days
MCN
PostPosted: 17:29 - 23 Aug 2016    Post subject: Reply with quote
By the time it's in print we (all of Great Britain) will have sailed away from the clutches of the European Bureaukratti. Dance!
The last post was made 9 years, 322 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.11 Sec - Server Load: 2.07 - MySQL Queries: 16 - Page Size: 89.04 Kb
