| MahatmaAndhi |
 MahatmaAndhi Traffic Copper
| Kawasaki Jimbo |
 Kawasaki Jimbo World Chat Champion
| stinkwheel |
 Posted: 12:57 - 02 Sep 2016 Post subject: |
The oil pressure light means there is no pressurised oil coming out of the oil pump. Which there isn't when the engine isn't running, situation normal.
The temperature light comes on when the engine isn't running to show it's working.
So. The lights are working correctly, they ought to be on when the engine isn't running but the ignition is on.
Seems like you have a problem with your satarter ciurcuit or possibly a flat battery. Does it make a clicking sound when you push the starter? How about with the clutch pulled in? The neutral light also ought to be on.
The ignition system on that bike isn't sophisticated enough to have fault codes. There is no ECU, there is just a pair of IC igniters to control the timing of the spark, no microprocessors involved, only straight electrics and electronics. ____________________ “Rule one: Always stick around for one more drink. That's when things happen. That's when you find out everything you want to know.”
| tom_e |
 tom_e Brolly Dolly
| Azoth |
 Azoth Brolly Dolly
 Posted: 13:52 - 02 Sep 2016 Post subject: |
Before trying to diagnose a fault, flip the kill-switch the other way and try again.
Here's what I would do, assuming you've already put a multimeter across your battery and have a low voltage reading (low voltage means you also have low current):
1) Get a couple of jump leads, connect them up to your battery from a running, working bike, and see if your bike starts. If it does, then it's a reg/rec or battery fault.
2) Assuming your bike started when jumped and died shortly after the jump leads were taken off, something needs replacing, either the regulator/rectifier or the battery. If it started and didn't die after a couple of minutes of the engine running after the jump leads were removed, then you had a flat battery and that problem is now solved.
3) You don't want to unnecessarily spend money and replace a working component, so buy a trickle charger. Why? Because it's a useful thing to have, even if you have a working bike and battery, and trying a trickle charger on your battery right now will tell you whether your battery can take and hold a charge.
4) If your battery won't hold a charge from a trickle charger, you know you have to replace your battery.
5) If your battery can hold a charge, you know it's a generator or reg/rec unit issue. Now buy a new reg/rec unit (the more likely culprit) and replace it.
EDIT: The oil pressure and temp lights are wired in series on these bikes and should both be lit until you get oil pressure, which is immediately when the pump turns on and the engine starts. So if those lights are on when the engine isn't running but after you've turned the key, that's normal. Nevertheless, don't rule out a simple electrical short circuit! If you're very lucky it may start after jiggling some wires.
To add to what stinkwheel said, if it clicks when you try to start the ignition, that means your ignition circuit is OK. ____________________ Safety in numbers
| Evil Hans |
 Evil Hans World Chat Champion
| MahatmaAndhi |
| Kawasaki Jimbo |
| Azoth |
 Azoth Brolly Dolly
| stinkwheel |
 Posted: 15:06 - 02 Sep 2016 Post subject: |
Don't even think about pulling your carbs apart until you have a good, working charging system and a steady battery voltage.
If you have a low voltage it will be producing intermittant, poor quality sparks. Sort out the electrics then see how it is.
The carbs are unlikely to have suddenly stopped working overnight. The charging/electrical system could.
A well known fault with those EX500 derivatives is corrosion on the main power supply wire to the ignition switch. It's a fat white wire and runs from the main fuse block connector to the ignition switch. Pull the main 30A fuse holder (on top of the starter solenoid) and check the wires running into it for corrosion. They'll often pull right out.
People fixate on carbs becaue they don't understand electrics but electrical faults are far more common than fuelling faults. ____________________ “Rule one: Always stick around for one more drink. That's when things happen. That's when you find out everything you want to know.”
| MCN |
 MCN Super Spammer
 Posted: 15:10 - 02 Sep 2016 Post subject: |
I traded a bike that I had just fitted a new battery in. I had no intentions of selling the bike when I bought the battery or It would have been sold without. The battery that was in was working but was either on a ctek charger or the bike was 'in-regular-use.
So happens I refitted the old battery and put the new one in another bike.
The old battery started the bike fine. (1200cc Twin engine) but I had a private plate on the bike and wanted to swap to new bike.
I couldn't do that as the MOT had ran out the week later and DVLA were being completely wankers about it (the Taffy cunts.) so I had to ask the dealer if they could MOT the feckin bike I had sold them so I could retain the feckin plate. They don't do MoTs but they will let me take it to a place they use.
Hassle McHassleface.
I went the dealer and low and behold the fekin beast wouldn't start.
It had been sat for two weeks.
Moral: Don't sell a second hand bike with a duff battery.
Sounds/reads awfy like your battery is simply goosed.
The previous owner probably knows that but had it on charge and you haven't charged it. ____________________ Disclaimer: The comments above may be predicted text and not necessarily the opinion of MCN. |
| MahatmaAndhi |
| MCN |
 MCN Super Spammer
| Azoth |
 Azoth Brolly Dolly
| stinkwheel |
| Azoth |
 Azoth Brolly Dolly
 Posted: 10:35 - 03 Sep 2016 Post subject: |
I can't be sure, but the fact that the bike was working (probably quite badly) and then just failed to start when he went to it during his work break suggests very strongly that it's just not getting enough electrical juice, i.e. the battery or charging circuit is defective. I've seen a picture of his bike, and the way it looks doesn't match up with its description as a properly serviced bike. The minor details such as the left indicator bodged on with electrical tape hint that hundreds weren't always spent on Kawasaki servicing at regular intervals. Just looking at that bike, I would assume it runs a bit rough. The bike doesn't have an inline fuel filter, and is vulnerable to petrol contamination and bits of dirt blocking the jets, and the inaccessibility of the carbs means that they don't get stripped down much, and petrol varnish also afflicts them. Owners of the 250 Ninjas are always messing with the carbs and regularly have them off. EX500 bike owners hate going down in there because it's tricky. So a lot of these bikes and GPZ500s will run rough because of carb problems. That said, you're absolutely right that electrical problems, i.e. a weak spark, will cause rough or no running on the relevant cylinder. Once he's fixed and tested his electrical system and changed his spark plugs, I would bet the rough running is still there, though I may be wrong. ____________________ Safety in numbers |
| MahatmaAndhi |
| stinkwheel |
 Posted: 12:09 - 03 Sep 2016 Post subject: |
I've owned three kawasakis with that same engine design. Be aware that another fault I've had on all three was an intermittant ignition switch. It can fail in such a way as the dash lights come on and all the electrics work when you turn the key but the ignition circuit isn't activated.
Wiggling the key works for a while but you eventually need to replace the switch. ____________________ “Rule one: Always stick around for one more drink. That's when things happen. That's when you find out everything you want to know.”
| Kawasaki Jimbo |
| Rogerborg |
 Rogerborg nimbA
 Posted: 21:44 - 05 Sep 2016 Post subject: |
Mmm, I'll be surprised if that bike starts tomorrow morning.
Either way, buy yourself a cheap multimeter. It'll take a lot of "looks OK" guesswork out of it. ____________________ Biking is 1/20th as dangerous as horse riding.
| MahatmaAndhi |
 Posted: 22:26 - 05 Sep 2016 Post subject: |
| Kawasaki Jimbo wrote: | The bike works. Either you're gifted or your bumped ride home recharged the battery to an extent, but I suspect you'll have further problems unless you charge that weakened battery. |
I've never known a battery of any type to just stop. They tend to wear down. I rode around 60-odd miles on 60 and 70mph roads. I rode it home about 15 miles, got ready for work, road it to work. No issues. It was on my lunch break where it began to turn over, then stopped. As if all was normal - then wasn't. It made no noise after. Nothing. The lights came on, indicators worked, but the thing that turned the engine on, wouldn't.
I went at it with a screwdriver and yeah, so far so good. I haven't ridden it, but have started it several times since.
Once my shoulder has healed up properly, I'll know for sure. |
| MCN |
 MCN Super Spammer
 Posted: 15:18 - 06 Sep 2016 Post subject: |
| MahatmaAndhi wrote: | | Kawasaki Jimbo wrote: | The bike works. Either you're gifted or your bumped ride home recharged the battery to an extent, but I suspect you'll have further problems unless you charge that weakened battery. |
It is not at all uncommon for a battery to sudden death.
If it shorts internally then everything goes out the door when ever any decent load is applied. It may recovery and show wee volts but it will not push out high amps. 'pseudo' Mechanical Failure
Batteries that get weaker and weaker over time do so because of sulfation where the plates lose their ability to take up and release energy. Chemical failure. ____________________ Disclaimer: The comments above may be predicted text and not necessarily the opinion of MCN. |
The last post was made 9 years, 204 days ago. Instead of replying here, would creating a new thread be more useful? |
