 Posted: 16:06 - 05 Sep 2016 Post subject: YB100 oil pump seal change without splitting? |
There's a slight oil leak into the oil pump/carb area of the wifes YB100. Looks very much like gearbox oil and I'm pretty sure it's coming from somewhere behind the oil pump suggesting the oil seal around the pump drive shaft is shot.
Anyone know if it can be pulled and changed from the outside? The workshop manual is not very extensive and only describes driving one in and out of split crankcases.
If it can't be changed in-situ, I'll leave it alone for now because it's only a few cc coming though when it gets hot but it's marking its territory when parked up.
It'll be identical to an FS1E setup. Visually looks very like the oil pump setup on an RXS100 (and most other Yamahas of that era by the look of things) but with less room to get at it due to crankcase induction. The seal itself is the same part number. ____________________ “Rule one: Always stick around for one more drink. That's when things happen. That's when you find out everything you want to know.”
| Islander |
 Islander World Chat Champion
| redeem ouzzer |
| Hahadumball |
 Hahadumball World Chat Champion
 Posted: 11:29 - 06 Sep 2016 Post subject: |
have to split im afraid
www.yammy100.com may be able to advise when you do so.
or mod the frame a little and put a dt 125 engine in. ____________________ Fin: no matter how much I look at It I can't understand what was going through my head, all I remember is going about 80 and redlining it to stop it seizing.
360 Deg... Five 1/4 turns. :- Teflon-Mike 18 Jan 2015 |
| hmmmnz |
 hmmmnz Super Spammer
 Posted: 17:33 - 07 Sep 2016 Post subject: |
It'll be part 14. Although it looks like there's a paper gasket in there too which I wasn't aware of.
I'll see about pulling the pump and seeing properly where it's coming from. The overspill seems too dirty to be 2-stroke (and doesn't smell of strawberries). ____________________ “Rule one: Always stick around for one more drink. That's when things happen. That's when you find out everything you want to know.”
| hmmmnz |
 Posted: 23:25 - 07 Sep 2016 Post subject: |
sorry i meant 14.
surely if oil was getting past that seal, then there'd also be air/fuel as well and you'd be able to feel it when the bike was running.
does your pump inject oil on both side of the crank or just the intake side,
my bridgestone only injects on the intake side of each cylinder. ____________________ the humans are dead
I kick arse for the lord
| hmmmnz |
 Posted: 23:59 - 08 Sep 2016 Post subject: |
ok, i get ya,
so the pump has nothing at all to do with the crank.
and you reckon its possiblly gear box oil
having a look at the diagrams, id say you'd be able to get out any seal with out having to split the crank,
seal puller for the win ____________________ the humans are dead
| Banana_B1 |
 Banana_B1 Banned
| Hahadumball |
| redeem ouzzer |
| Banana_B1 |
 Banana_B1 Banned
 Posted: 20:12 - 10 Sep 2016 Post subject: |
| Banana_B1 |
 Banana_B1 Banned
 Posted: 21:10 - 10 Sep 2016 Post subject: |
| redeem ouzzer |
| Banana_B1 |
 Banana_B1 Banned
 Posted: 21:22 - 10 Sep 2016 Post subject: |
| Banana_B1 |
 Banana_B1 Banned
 Posted: 00:51 - 11 Sep 2016 Post subject: |
| Banana_B1 |
 Banana_B1 Banned
 Posted: 01:03 - 11 Sep 2016 Post subject: |
I use this Polini measuring bottle for mixing with 5 liters...
https://beedspeed.com/images/PoliniOilMixtureBottle.jpg
Basically 3% = 32:1' much easier than guessing how many milliliters etc.. 1 thing i learnt while filling up at fuel pumps was not to pour fuel in before oil as the oil would sink straight to the bottom - even after pumping the forks with front brake applied to shake it up. ____________________ The entire Butthurt BCF wrote: Spam Flame Abusive Redundant Off Topic Boring Disagree Confusing |
| Banana_B1 |
 Banana_B1 Banned
 Posted: 01:43 - 11 Sep 2016 Post subject: |
| Banana_B1 |
 Banana_B1 Banned
 Posted: 23:14 - 11 Sep 2016 Post subject: YB100 oil pump seal change without splitting? |
The last post was made 9 years, 213 days ago. Instead of replying here, would creating a new thread be more useful? |
