Car issue, BMW E39, no heat from the center and side vents
RhynoCZ
PostPosted: 14:52 - 07 Oct 2016    Post subject: Car issue, BMW E39, no heat from the center and side vents Reply with quote
Hello, my mate's E39 developed this nuisance last night and I'm not sure where to start.
I get no heat/cold from the center vent and both side vents (all I get there is the ambient outside air), but I do get heated/cooled air from the rest of the vents in the car (legs, windshield...)
1) Could it be electrical? Does the system have its own fuse? I also know there should be two solenoids with valves, but those only distribute the heat to the left or the right hand side of the car.
2) Could it be a mechanical problem and if so, why would I then get no heated/cooled air from the side vents. I do know there is a dial with a cable attached to it, that regulates the temperature of air comming out of the center vent, but that dial does not influce the side vents.
MCN
PostPosted: 15:52 - 07 Oct 2016    Post subject: Reply with quote
I dont know which year you are bangin' on about.. Mines is a 520 2007 (E60) the center vent is controlled via the iDrive in the middle of the consol.
So it is servo/motor driven flaps controoled by electrickery.
Maybe a 'full bore' OBDII reader can pull the diagnostic off the ecus.
You will need a fancy OBDII reader though. The 5 euro bluetooth jobbies only read very very basic shite.
RhynoCZ
PostPosted: 16:17 - 07 Oct 2016    Post subject: Reply with quote
It's the 37th week of 1998, pre-facelift. So there's no iDrive.
janner_10
PostPosted: 16:24 - 07 Oct 2016    Post subject: Reply with quote
Loads of answers on Google. That should be the port of call.
RhynoCZ
PostPosted: 16:30 - 07 Oct 2016    Post subject: Reply with quote
Yes, but 99% of the google answers is about the center vent, but that's not my issue. Oh, and I'm still after that 1%, that would actually help me.
dodsi
Dirty Carny
PostPosted: 18:18 - 07 Oct 2016    Post subject: Reply with quote
You issue could be 'the hedgehog ' - the final stage resistor.
On a e46 3 series this can be resolved by removing fuse 50 and replacing it after 30 seconds. The fuse is probably different on the 5 series but could be the same thing.
It's a common zim zimmer fault
RhynoCZ
PostPosted: 18:32 - 07 Oct 2016    Post subject: Reply with quote
Isn't that the fan speed controller?
dodsi
Dirty Carny
PostPosted: 20:49 - 07 Oct 2016    Post subject: Reply with quote
Yes it does but you might find it's the reason it's not blowing?
RhynoCZ
PostPosted: 21:19 - 07 Oct 2016    Post subject: Reply with quote
The blower works, it's the heating/cooling that doesn't.
MCN
PostPosted: 18:45 - 08 Oct 2016    Post subject: Reply with quote
Is it ducted from the main heater core or is there a seperate core?
It may be a core blockage.
Grasping at straws here now. Smile
uberkron
I have replaced many heater cores on these cars.
You lose some heating, soon all heating.
Of course check all servo motors.
i ride a zip 50 2smoke. It overtakes a hundred times a day.
bugeye_bob
PostPosted: 04:58 - 09 Oct 2016    Post subject: Reply with quote
Google flap alignment, some can be reset by pressing a few buttons.
RhynoCZ
PostPosted: 19:05 - 09 Oct 2016    Post subject: Reply with quote
Problem solved, apparently stuck valve that's on the end of the cable that goes from the center vent's temperature dial. Thinking
Anyway, thank you. Thumbs Up
The last post was made 9 years, 257 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.23 Sec - Server Load: 1.33 - MySQL Queries: 13 - Page Size: 76.5 Kb
