| Petemate |
 Petemate Trackday Trickster
 Posted: 18:34 - 29 Sep 2016 Post subject: Transmission backlash |
Bike - LA250 Custom, engine unit same as CB250 Nighthawk, CMX250 Rebel, and CD250U.
Got the bike in Nov 2013, delivered, never rode it until I put it back on the road after a full strip and rebuild.
Advised on sale about 3rd gear noise - sure enough, 2 and a half teeth stripped on one of the gears, fitted new both 3rd gears. As far as I could see, there were no issues with all the other gears and bearings, or splines etc on the shafts.
Once back on the road, I noticed a slight whine in 4th, which has progressed to now sound like a Blackpool tram, and fifth is now whining a bit. 3rd of course is OK....
Now to the current problem. From the moment I took the first tentative rides after putting it back on the road, I noticed a 'clack'/'clunk' on take up letting the clutch out. It will occur once I have closed the throttle (at which there is another clunk as the drive reverses) then recur when I open up again. This has not got any worse in the few thousand miles I have put on the bike. It can be reproduced in 1st, 2nd, and 3rd but to be kind to the clutch I have not tried it in 4th or 5th.
To my mind this rules out any issues with dogs on the gears and points to possible problems with splines etc. I did consider the rear sprocket cush drives (mine are the 'silentbloc' type) but checked them today while attending to a rear brake squeal and all is OK there.
When I was rebuilding the engine I paid particular attention to the clutch basket slots and internal splines in the centre and the splines on the input shaft, also the output shaft on which the front sprocket sits. Nothing was amiss there, and still isn't, (checked today) and the clutch plates are new (fitted a year ago)
I am not going to purchase a new pair of 4th gears, and am going instead to get hold of a complete gear cluster from a low mileage bike - there are going for less than the pair of 4th gears including delivery.
Assuming the bike doesn't blow up in the meantime, I intend to take it off the road at the beginning of December and remove the motor and strip it down and get out my magnifying glass!
Footnote - I know I tightened up the clutch centre nut (and everything else) to the correct torque loading on the rebuild. I am baffled at the moment but hopeful that I will find something obvious when I strip it. The clutch is wonderfully smooth both upchanging and downshifting. Once I have fed the clutch in, traffic lights grands prix are great.
Pete ____________________ 82 not out....1983 Honda LA250 Custom
2008 Saab 9-3 1.9 Tid 150 Vector Sport estate
2005 Stirling Eccles Topaz 2-berth |
| bikenut |
 bikenut World Chat Champion
| Petemate |
 Posted: 23:34 - 29 Sep 2016 Post subject: |
Thanks bikenut for the quick response.
Sprocket pins all tight and correctly positioned. A good fit in the bushes, which have no signs of the inners parting company with the rubbers. I inserted a pin in each of them (pins removed for inspection) and moved them sideways to check the rubbers. The circlip is a good fit and there is no play in the sprocket when it is refitted.
Swinging arm smooth and engine bolts all tight; handling perfect - I can hammer the bike round bumpy bends and no snaking etc.
Can't remember the torque setting for the clutch nut but I know I tightened everything exactly according to the book; washer correct way round etc.
Crank gear tight.
Ckutch drum cush drive? If the 233cc lump has one in its clutch I didn't know - if it has, then that will be my first line of investigation when I strip it.
No judder at the 'bars when braking.
Rear sprocket to wheel arrangement: (pic of CD250 used as one of my type not available)
https://i460.photobucket.com/albums/qq324/Petemate_01/Miscellaneous/Current%20wheels/rear%20wheel.gif
Although the 4th gears are now noisier, I can discount them as the symptom has been in place from the word go with no worsening and as stated, can be reproduced in at least the first three gears. A good point re cush drive and I am hoping that there is some sort of one in that outer.
Thanks!
PS note to Teflon-Mike: Mike, is there any sort of cush drive in the clutch outers of these little 233cc lumps? TIA! ____________________ 82 not out....1983 Honda LA250 Custom
| bikenut |
 Posted: 11:14 - 30 Sep 2016 Post subject: |
post an exploded view of the clutch please.
Most clutch baskets have a cush drive, a spigot fit of the clutch gear to the basket, all held in place with a riveted plate.
These parts wear, rock hard cush rubbers and slack, wear on drive gear/basket spigot, meaning play and back lash ( you should see my kwak one, cush and 3 drive pins, cush "gone" so drive via drive pins, mega back lash, new parts are 100's £ ! been trying to get an overhaul kit, new rubbers and rivets etc. but no luck so far, may have to either use bolts or make new rivets so I can disassemble, sort it out, and re assemble, eventually. ) misalignment/mesh with drive basket and crank gears, loose rivets and "steel plate that holds the lot together" ) meaning noise/back lash/ jerky transmission, just like a landy with buggered half shaft splines and Drive plates, not to mention completely buggered UJ'S etc. Press throttle, count to 2, hear "bang" then accelerate, quite comical really but dangerous.
You fitted the clutch nut with flat face out ? ____________________ nuts about bikes |
| Petemate |
 Posted: 16:37 - 30 Sep 2016 Post subject: |
| bikenut wrote: | post an exploded view of the clutch please.
You fitted the clutch nut with flat face out ? |
Thanks again bikenut. Hilarious post there, I'm still chuckling.
The washer was fitted correctly with the nice clearly stamped word OUTSIDE to the outside! My input shaft has a nut as opposed to some models which have a circlip. I modified a socket to fit the nut, socket now in my special tools.
Found my list I made and can confirm that the r/h crank and clutch nuts were tightened to 55nm (book says 45-60nm).
Exploded view of clutch assembly:
https://i460.photobucket.com/albums/qq324/Petemate_01/Miscellaneous/Current%20wheels/clutch.gif
A pic I found in an eBay ad of the clutch basket:
https://i460.photobucket.com/albums/qq324/Petemate_01/Miscellaneous/Current%20wheels/s-l1600.jpg
Indeed it is obvious to me from the rivets that there is a cush drive in there.
I am listening carefully (when I am not concentrating on that car drivers are doing at the front of the queues) to the clunk and it is deffo coming from the engine, noticeably towards the right which places it nicely in the clutch area. As it has not got any worse from day one, I will carry on for now and hope to sort the lot out when I strip it to do the gears. What fun.
Ta again,
| bikenut |
 Posted: 18:08 - 30 Sep 2016 Post subject: |
Yep, I liked the boss, but he was a twat to work for.
Boss, the landy needs xyz, half shafts and drive plates.
Weld it he says, but boss you cant really do that, just weld it he says, but boss, WELD IT ! he ordered, so I did.
Was told "what have you done to the landy, is brilliant now", lasted about 4 weeks and so did I, I left.
Difficult bloke to work for.
Anyways could you post a picture of the engine, both sides please.
5 gears and nutted on clutch hub, ala superdream ( bloody nightmare more like ).
Carb ( twin carbs on yours or single ? ) imbalance can cause a thud thud thud noise ( as can so many other faults like balance shaft problems and bottom end ) which may lessen when clutch pulled in, and slightly more so when in gear holding the clutch. ____________________ nuts about bikes |
| Petemate |
| bikenut |
 Posted: 23:10 - 01 Oct 2016 Post subject: |
If you look between the steel plate and the basket you may see the rubbers, or the "rombiod" if that's the right word, the shape the cush blocks sit in between gear and basket, its the rivets that are the problem.
Older triumphs have a cush in the clutch that runs close to oil, but i think they are "round rods"? will check.
Large pieces of oil tolerant "rubber" or the stuff engine oil seals and cam chain slippers are made from may do, trimmed, but where from ? or from what ?
The kwak i have has a largish block in the cam cover, to form an arc for the cam chain, a cam chain slipper. E15 each may be big enough to do 2 cush segments ?
I heard of someone in holland ? that used bolts/nuts to replace the rivets.
Been trying for ages to get an overhaul kit for the kawasaki, Z1 kits you would think are available, but from where, that's a real classic isn't it.
I don't have one of them, Z1 I mean. ____________________ nuts about bikes |
| bikenut |
| Petemate |
| Petemate |
 Posted: 18:32 - 21 Oct 2016 Post subject: |
Took the clutch out today. I was expecting to find massive play between the sprocket and the basket, with a load of rubber particles/debris lying at the bottom of the crankcase. Nothing. No play whatever between the sprocket and basket. Gripped the sprocket by wrapping a piece of webbing round it and holding it in the vice, then a piece of wood across the slots and no movement.
Now to the nitty gritty. The bike is on the sidestand. When I grasp the end of the mainshaft with first gear engaged, I get quite a bit of rotational play, with the exact 'clack' which I experience when pulling away. Far less rotational play exists in all the other 4 gears, with exactly the same clack. Looking at the manual pics of the gears the movement within the engagement of the dogs seems to equate to this play - am I worrying about nothing more than a characteristic of this tyoe of gearbox? (ie constant mesh dog engagement) Strangely however I don't remember hearing these clacks on all the other bikes I have owned, Jaoanese or otherwise. Can someone advise if they too hear this clacking every time they pull away?
Everything (without stripping further, and as far as I can see) was as it should have been, eg the clutch assembly was tight, its washers the right way round, the crank and clutch basket gears are perfect, the front sprocket is secure and no play in the splines, etc etc.
I am going to do a filter clean while the cover is off, and pop some clean oil in there after reassembling it all. Lucky I don't need a gasket; when I put the engine together I used Wellseal thin jointing compound sparingly on the crankcase and grease also sparingly on the cover and the cover came away easily by merely operating the clutch lever. The whole engine has been oil tight so much so reminding me of how my old Triumphs were not lol.
Later this year as a winter project I will be completely stripping the motor to sort the gears out (the 4th whine mainly). I plan to get hold of a low(ish) mileage gear cluster, there are several out there and happily for me the internals of this motor are identical with many others in the 233cc range.
Pic later showing the play in each gear which I am now convinced is normal dog to dog and dog to gear holes.
Pics best I could. The dial type rig I made shows the slack in each gear. Having studied the gear train and how each ratio is not as straightforward as previously thought, it appears that (especially in 1st) the slack rotations are linked to the movement between the dogs, and there are occasions where more than one pair of gears are transmitting power via dogs and holes. As far as I remember the dogs and all holes in the gears were in fine condition, and considering that the 3rd gears are only just over 2k miles old, this leads me to believe that all this slack is merely characteristic. (I hope lolol) The diagram of the gears is great fun to work out....
Time will tell. ____________________ 82 not out....1983 Honda LA250 Custom
| Petemate |
| bikenut |
This post is not being displayed because it has a low rating (Spam). Unhide this post / all posts.
| Petemate |
| bikenut |
| Snod Blatter |
 Snod Blatter Crazy Courier
 Posted: 12:02 - 23 Oct 2016 Post subject: |
I can help with the oil piston thing, it is spring loaded and lives in the end of the crank where it is pressed against a face on the clutch cover.
For what it's worth my CB250 has 82K on the clock and doesn't have this clack, or at least I've never noticed it. The only lash it has is that the rear sprocket no longer snugly fits the rear wheel and flaps about far too much, a new washer and circlip helped (the old ones worn surprisingly thin!) but it obviously flaps about, with the studs almost grazing the inside of the swinging arm. I'll have to replace the wheel if it gets any worse, or perhaps find another washer to pack it out with..
Sorry to be somewhat simplistic about it but are you tightening the chain enough?  ____________________ 1994 CB250, 1984 CBX250RS-E, 1989 K100RS, 1995 TRX850, 2016 Z250SL |
| Petemate |
 Posted: 13:13 - 23 Oct 2016 Post subject: |
| bikenut wrote: | So there is a sprung loaded "piston" affair with a hole in it that lives in the clutch cover and lines up with the hole in the crank, an oil feed to the big ends......or it may live in the end of the crank and line up with an oil hole in the clutch cover.....an oil feed to the big ends.....
Will take a picture of a clutch basket a have stored in the shed, a picture of the back of the basket, hopefully showing cush rubbers or where they live.....
Could you give a link to the cmsnl pages for the belt drive, need to check f and r belt sprocket sizes etc as well as belt length, may fit a bike/bikes i/we have to rid ourselves of chains !Thanks
Had a negative feedback on cush rubbers from Wiseco uk, but still looking for rubbers for the kawasaki cush drive ( and pin ) clutch |
Thanks bikenut.
CMSL pages shows the actual belt as unavailable, also does not list the length. The parts for attaching both belt drive sprockets to the wheel and countershaft (eg bolts, pins, plate etc) are identical with the chain items, if that helps.
I have adjust the chain a bit better, and the clack has almost disappeared but I can still 'sense' the play in the dogs.
| Petemate |
 Posted: 13:18 - 23 Oct 2016 Post subject: |
| Snod Blatter wrote: | I can help with the oil piston thing, it is spring loaded and lives in the end of the crank where it is pressed against a face on the clutch cover.
Sorry to be somewhat simplistic about it but are you tightening the chain enough?  |
Thanks Snod Blatter.
My cush drive in the rear wheel is in surprisingly good condition for a 33 yr old bike. No wonnle of sprocket under the circlip, which is in excellent condition as well as the washer beneath. The silentblocs are all OK too.
However, simplistic worked to an extent for me (with a small amount of egg on face). I have carefully adjusted the chain again, and now the clack has almost gone, in that I can 'sense' it rather than 'hear' it, if that makes sense. The play I can now feel as I feed in the clutch I am now certain is the several pairs of dogs waking up to propel me away from the traffic lights and all the boy racer Audi and Astra owners.
| bikenut |
| bikenut |
The last post was made 9 years, 306 days ago. Instead of replying here, would creating a new thread be more useful? |
