Game PC motherboard blown... What to do?
Bike Chat Forums Index -> The Geek Zone Goto page 1, 2  Next
PostPosted: 17:27 - 23 Oct 2016    Post subject: Game PC motherboard blown... What to do? Reply with quote
I have a game PC based on an old AM2+ Asus M2NE motherboard with a Quad core AMD CPU (not sure exactly which model). I Have a Geforce GTX 260 graphics card, 250gb SSD and a 4tb HD. I have 8gb of DDR2 RAM.
Sadly, the motherboard has expired (which is why I can't find out what the CPU is). A component near the chipset heatsink looks charred and burned, it has a little metal shield and looks like a coil with some sort of core in it.
So I'm thinking, being I have a decent PSU, case, DVD-RAM drive and memory card reader, as well as the SSD and HD I should just replace the motherboard. This means a new CPU I guess, as well as RAM. I don't want to spend loads, and ideally I want to re-use the graphics card for the time being (for reasons of budget). Being that I have a PC based on old technology I'm not very au-fait with the latest hardware.
Arrow I'm guessing all new motherboards will need DDR3 RAM so I'll have to buy all new RAM?
Arrow Can anyone fathom what the latest AMD CPU's are? Are they worth it? Would I be better going for what appears to be as it has always been the more expensive Intel?
Arrow I assume PCI-Express is still the graphics bus of choice?
Arrow I'm guessing I can't use my AM2+ liquid cooling setup?
My monitors use DVI connections, and are quite new and shiny so I don't really want to upgrade them. I don't have display port, so there's another reason to stick with the old card for the time being.
Anyone got any ideas what I should be looking for? Do I need to worry about the tech specs of the current motherboard?
Here's the current mobo spec:
https://www.asus.com/Motherboards/M2NE/specifications/
I have a nominal budget of around (edit) £200, but if spending a few extra quid means I get a significantly more capable PC I'd be happy with that.
Any hints or ideas welcome?
Pjay
PostPosted: 17:58 - 23 Oct 2016    Post subject: Reply with quote
Protip:
Go Intel inside.
andym
PostPosted: 18:37 - 23 Oct 2016    Post subject: Reply with quote
Pjay wrote:
Protip:
Go Intel inside.
Why?
I got my last 8 core AMD (8350), for about £150 over 2 years ago, the previous one is still going strong after about 7 years.... same with the motherboards, the cheap old Gigabyte is still working in the 7 year old PC.
dydey90
PostPosted: 18:38 - 23 Oct 2016    Post subject: Reply with quote
I have this CPU. Haven't been able to touch it with anything gaming wise, it's a lot cheaper than any intel worth having and has plenty of grunt.
https://m.cclonline.com/product/93469/FD8350FRHKBOX/CPU-Processors/AMD-FX-8350-Eight-Core-Black-Edition-CPU/CPU0153/
Can't remember what motherboard I have but you're looking at £50-100 for a socket AM3+ and with 4 RAM slots you can fit 32GB which is overkill right now.
Also, if you go for an AM3+ then your existing water cooling system should fit just fine.
Prices new, I'd guess at £250-300
Used, may be able to get as low as £100
PostPosted: 18:39 - 23 Oct 2016    Post subject: Reply with quote
Pjay wrote:
Protip:
Go Intel inside.
Not really helpful as the equivalent AMD is half the price, and less cores, lower clock speed.
CaNsA
PostPosted: 18:58 - 23 Oct 2016    Post subject: Reply with quote
MarJay wrote:
Pjay wrote:
Protip:
Go Intel inside.
Actually, it's really good info.
Over the years I have found Intel to be far more reliable than any AMD kit I've owned.
But seeing as you are bitching about brexit budget, grab this bundle.
https://www.aria.co.uk/Systems/Bundles/AMD+Value+Next+Day+Bundles/GLADIATOR+AMD+Value+8+FX8320+3.50GHz+Pre-Built+Bundle+?productId=63463
PostPosted: 19:00 - 23 Oct 2016    Post subject: Reply with quote
CaNsA wrote:
Actually, it's really god info.
Pjay
PostPosted: 19:09 - 23 Oct 2016    Post subject: Reply with quote
I can qualify my reason for suggesting Intel.
If you had spent more on the Intel in the first place, you'd not be spending it now.
I have had only problems with AMD in the past, each time I try to dip my feet in. Intel on the other hand, are bullet proof.
Yes you will get people saying that their AMD is the more reliable PC ever, but it's not. They just want to feel good about buying a cheaper clone and will tell whoever will listen how great they are.
in 25 years I've owned maybe 4 AMD and 10-15 Intel based computers.
All the AMD died, none of the Intel did. Some are still going strong now. My Niece even has an old P4 I gave her 8 years ago, that's used daily.
I just don't trust AMD and never will.
PostPosted: 19:35 - 23 Oct 2016    Post subject: Reply with quote
I bought the motherboard in 2006, and it's been through CPU swaps, BIOS updates and so many hardware configuration changes, and running with no case fans for about three years. I'd happily go with another Asus/AMD combination.
If the board failed for any reason it's probably my misuse of it. It's outlived three PSUs, and up until last week was running a CPU that was designed after the board was made. I can't really stress enough how good it has been in all honesty.
M.C
PostPosted: 19:53 - 23 Oct 2016    Post subject: Reply with quote
Ran both AMD and Intel cpu's for years and never had either fail. Are you overclocking?
Consider a second hand mobo if you don't want to buy new stuff.
CaNsA
PostPosted: 20:01 - 23 Oct 2016    Post subject: Re: Game PC motherboard blown... What to do? Reply with quote
Any danger of you being a little more specific?
PostPosted: 21:00 - 23 Oct 2016    Post subject: Reply with quote
No overclocking.
Not sure of the model of my liquid cooling kit, I think it was a relatively cheap Crucial radiator thing with variable pump speeds for overclocked CPUs. I don't tend to indulge in that type of stuff any more, so I have it for noise reduction reasons rather than for performance. It's definitely quieter than the CPU fan I had on there before.
[edit] it's a corsair kit CWCH80RF, not crucial! Oops! [edit]
Jayy
Mr. Ponzi
PostPosted: 22:10 - 23 Oct 2016    Post subject: Reply with quote
WHat to do... buy all new shit Thumbs Up
bladerunner
PostPosted: 22:19 - 23 Oct 2016    Post subject: Reply with quote
intel vs AMD....intel are more efficient, no doubt about it. more £££ as well and I'm an AMD fan lol but its what fits in budget and AMD may win that one in the mid range market. Good things are new faster ram and probably faster access to your SSD etc. I updated my 2007 q6600 last year for an i7 and the whole thing is improved USB3 etc etc so even with a tight budget if you get a stable system it'll run better with the newer OS as well
PostPosted: 08:25 - 24 Oct 2016    Post subject: Reply with quote
Cost is a major issue and really the equivalent Intel setup is roughly twice the cost of AMD. Also, I've been coping with a 10 year old motherboard, with a six year old CPU and an eight year old graphics card, running things like Deus Ex Human Revolution in 1080p full detail with no issue. So I doubt that having the latest intel i7 is going to be essential. I also know that the graphics card is more important to gaming performance than the CPU generally, so until I can afford a new graphics card, I'm going to have to cope anyway.
I think I'll be going AMD. Not the very top end, but something that will last me for a while.
Currently thinking this with 8gb of RAM:
https://www.awd-it.co.uk/amd-fx-8350-gigabyte-990x-gaming-sli-motherboard-ddr3-bundle.html
colink98
PostPosted: 09:13 - 24 Oct 2016    Post subject: Reply with quote
If cost is a big issue then i have a stink load of 4GB DDR3 sticks.
with these spec's
https://i.imgur.com/zdoBJlz.jpg
Would be happy to send 4 to fill the board and save you £40
Ride it like you stole it.
Pjay
PostPosted: 09:25 - 24 Oct 2016    Post subject: Reply with quote
I could do with a couple of those.
Does you accept paypal?
PostPosted: 11:19 - 24 Oct 2016    Post subject: Reply with quote
with these spec's
Yes please! What do you want for 'em? Do you want to PM me with paypal details etc?
M.C
PostPosted: 11:23 - 24 Oct 2016    Post subject: Reply with quote
No overclocking.
Sorry that was directed more at pjay. Second hand mobo idea was for you Smile Depends how important upgrading is, I recently built an Intel system for £180 (using used 'obsolete' parts), only expensive bit was the mobo as they aren't made anymore. CPU/RAM were virtually being given away, also scored a sweet GPU which I ended up putting in my AMD system.
Shinigami
PostPosted: 11:31 - 24 Oct 2016    Post subject: Reply with quote
not sure why all the AMD hate, I'm not a fanboy for either side but i've been running AMD CPU for the last 4 years without a hitch (FX8350, was running an Intel q6600 before that)
Reason of choice was it was about half the price than an equivalent intel, it's not yet bottlenecked anything at 1080p (all i can game at as I can't afford/want a 4k display)
Using evo-212 cooler which i've had in there for years also
PostPosted: 12:46 - 24 Oct 2016    Post subject: Reply with quote
A new issue has arisen. It seems my version of Windows 10 comes from an OEM Windows 7 installation that I bought from eBay... Turns out that OEM licenses are associated with the motherboard, and cannot be transferred. FML!
M.C
PostPosted: 13:12 - 24 Oct 2016    Post subject: Reply with quote
Me either, I have an AMD system I built in 2004 which is still going. Another one I built in 2011 is still going. I understand going with Intel for performance and temps but you get what you pay for (AMD are a fair bit cheaper).
You can call up MS or use windowsloader (I think that's what it's called). I'd go for the second option Smile
Jayy
Mr. Ponzi
PostPosted: 13:24 - 24 Oct 2016    Post subject: Reply with quote
It comes down to preference and cost. Intel is a lot more expensive and if you're on a budget then AMD is the way forward, nothing wrong with AMD.
Shinigami
PostPosted: 13:27 - 24 Oct 2016    Post subject: Reply with quote
KMSpico for win10, easy to do, just watch out for fake copies of it full of malware.
PostPosted: 09:17 - 25 Oct 2016    Post subject: Reply with quote
I've been looking at some CPU benchmarks, and I think the AMD FX-8350 is the one to go for. It's the best combination of power vs price at the budget I'm looking at. I'm certainly not going to spend £600 on an intel setup which doesn't gain me all that much, especially when i've been working with a Phenom II X4 960 for the last couple of years. That'll get transplanted into my internet PC as that's running an Athlon 64 x2 5000+. The FX8350 benchmarks better than the 8370 according to https://www.cpubenchmark.net/.
Benchmarks for reference:
FX8350 - 8,940
Phenom II X4 960 - 3,840
Athlon 64 x2 5000+ - 1,316.
I think I'll cope without the latest Intel rig!! Smile
Then further down the line I'll upgrade graphics card to something more modern so I can play stuff like GTAV (on offer this week on Steam folks!) Asetto Corsa and Deus Ex Mankind Divided. Win.
Shame about having to re-install windows and lose all my settings... Still, there is a glimmer of hope that I might not have to do that.
The last post was made 9 years, 132 days ago. Instead of replying here, would creating a new thread be more useful?
Post new topic   Reply to topic    Bike Chat Forums Index -> The Geek Zone All times are GMT
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.16 Sec - Server Load: 0.51 - MySQL Queries: 16 - Page Size: 141.25 Kb
