Changing the size of all pages in a PDF
Azoth
PostPosted: 22:17 - 27 Oct 2016    Post subject: Changing the size of all pages in a PDF Reply with quote
Some old books are currently only available as PDF files. The pages in these PDF files are A4-sized or larger. I want to order, and send to myself, one-off, bound, hard copies from these files, using a print-on-demand service. The POD company offers several different product options depending on page size. The sizes of each page in the scanned PDF files are inconvenient.
Does anyone know of an easy way to scale the sizes of all pages in a PDF document, without Adobe Pro? There are free online programs hosted by some websites that do it, but they apply a small size limit for the PDF files. There are some complex ways to do what I want to do, such as splitting up the PDF file and feeding each smaller file to the server-side web application to process all of them, or converting the PDF to a lot of image files, scaling them, then printing to PDF. But it would be nicer if there was a less labour-intensive solution.
Thanks
Safety in numbers
ScaredyCat
PostPosted: 22:43 - 27 Oct 2016    Post subject: Reply with quote
imagemagick can convert pages to png, scale and rebuild a PDF with them. I had to do this with a pdf presentation that was originally 279Mb - after saving them out as pngs and reforming, it was an 18Mb file that loaded in a fraction of the time.
Code:
SOURCE=MY_SOURCE
convert -density 150 -trim "${SOURCE}.pdf" -resize 1280x -quality 100 "./Out/${SOURCE}-%03d.png"
convert "*.{png}" ${SOURCE}_NEW.pdf
You can use pngquant to compress the pngs first, if required.
-trim removes the surrounding whitespace, you may need to experiment with that setting to see what's best.
Just pointing out the obvious, you want to scale the images with the same output ratio as the input, otherwise you'll get squashed or stretched text.
PDFJam is also another option...
Honda CBF125 ➝ NC700X
Honda CBF125 ↳ Speed Triple
Azoth
PostPosted: 22:59 - 27 Oct 2016    Post subject: Reply with quote
Pages to numbered PNG files, then resize, then convert star dot PNG back to PDF, all using some sort of command line interface. OK, I think that should do for me. I'll give it a shot. Many thanks
Safety in numbers
Jayy
Mr. Ponzi
PostPosted: 00:57 - 28 Oct 2016    Post subject: Reply with quote
What books are they? They obviously existed in book format at some stage and assume they are quite rare to find?
I literally have access to millions of physical books. Only problem is, they aren't exactly sorted and spread over two locations 250 miles apart but if you gave a list, I could get people to keep an eye out for them?
Azoth
PostPosted: 01:11 - 28 Oct 2016    Post subject: Reply with quote
Thanks Jayy. You work for BL I presume. These books are from the 1950s and concern the physics and maths of valve amplifiers, a subject I'm trying to learn about. They were recommended to me on an internet forum. They still exist and can be obtained through BL catalogues or through university libraries, but aren't currently in print. You can download them online as clear PDFs. But reading on the screen isn't how I'm going to digest this stuff, which is a bit dry. It's easier, quicker and cheaper for me to click a couple of times from home, have them printed and bound and posted to my house than looking around. I appreciate the offer.
Safety in numbers
Jayy
Mr. Ponzi
PostPosted: 17:49 - 28 Oct 2016    Post subject: Reply with quote
BL? I work in web design, my brother owns a Book Charity which has millions of books... yeah no worries, if you ever do want to track down a book which may prove difficult to find, drop me a PM Smile
ScaredyCat
PostPosted: 18:38 - 28 Oct 2016    Post subject: Reply with quote
You think he could get "Fly fishing" by J. R. Hartley?
Lord Percy
PostPosted: 16:19 - 29 Oct 2016    Post subject: Reply with quote
There's a program called Calibre which deals with e-books of all types including PDF.
You can convert from one version to another. E-book file types are a bit iffy but PDF output is fine. I converted a book just yesterday, from epub to PDF.
PDF to PDF would have no problem at all, I expect. Pages with pictures can sometimes cause a slight hiccup so that's the only thing to look out for.
You can specify everything in the conversion process, including font style, size, spacing, page size etc.
Calibre download
The last post was made 9 years, 324 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.09 Sec - Server Load: 0.94 - MySQL Queries: 16 - Page Size: 59.82 Kb
