| pondy2495 |
 pondy2495 L Plate Warrior
| WD Forte |
 WD Forte World Chat Champion
| bamt |
 bamt World Chat Champion
| stinkwheel |
 Posted: 20:15 - 30 Oct 2016 Post subject: |
Sounds like you have a short circuit. Had one on my bike not so long ago but it did it when I put the bike on full beam. This narrowed down the wires I needed to check somewhat. Being a bigger bike, it also had seperate fuses for the lights etc.
Have a think. Was there anything in common with the times it happened. Like you'd put the brake on or switched on an indicator? That might narrow down where you're looking.
For fault finding, connect a lightbulb in place of the fuse (presuming it's a blade fuse, a bulb holder with two male spade terminals is ideal). It'll probably glow dimly, normally. When you get the short, it'll light up fully bright instead of blowing the fuse.
Common places for shorts are rubs where the wiring runs past the headstock, under the tank and anywhere a wire could have got trapped under body panels. If the wiring goes up under the mudguard or through a hole in the bodywork/frame, these are also prime candidates.
I'd suggest doing the bulb thing, then run the bike trying all the electrical accessories. Wiggle any wires you can get at. If you don't get a "lightbulb moment", it's down to a laborious visual inspection of all the wiring that had power in it when the cutting out happened. ____________________ “Rule one: Always stick around for one more drink. That's when things happen. That's when you find out everything you want to know.”
| Robby |
 Robby Dirty Old Man
The last post was made 10 years ago. Instead of replying here, would creating a new thread be more useful? |
