Honda H100S... Feeling a bit gutless or purely psychological
eunos20b
PostPosted: 18:43 - 19 Nov 2016    Post subject: Honda H100S... Feeling a bit gutless or purely psychological Reply with quote
HI all,
Recently bought a H100S, has been converted to run premix (I found that out the hard way) running about 30:1 atm as I was told the more oil the better on these old ones. I'm newbie to bikes let alone 2 strokes.
Anyway it runs brilliantly but I've seen/read that it's meant to be able to hit 60mph. Now I don't care about going fast but stretches of road between my house and work are 50mph, and to even get to 50 - and this is if I'm lucky - I have to lie on the tank with no wind and a slight downhill. I've also always been led to believe that 2-strokes enjoy being revved, but this bike either doesn't feel happy to rev or the peak power is very low in the range. It's very torquey as well.
Apart from that, starts first kick every time and is in great working order. Any ideas? Thanks
'90 Honda H100SII (SJ)
Learning something new everyday
PostPosted: 19:40 - 19 Nov 2016    Post subject: Reply with quote
H100 is not really that revvy. Peak power is at 6500rpm, which is 50mph in top gear. If I remember correctly the listed speed when they were new was 58mph (not sure how accurate the speedo is). Because of the ludicrously low standard gearing the top speed isn't affected that much by the size of the rider.
It is difficult to get higher gearing for the H100. You can now get a front sprocket 1 tooth larger. Wish they had been available when I had mine.
Have you cleaned the exhaust out? Is it a standard exhaust? Is the air filter clean? Is the jetting standard (should be richer jetting to compensate for running premix)?
Katy
PostPosted: 20:52 - 19 Nov 2016    Post subject: Reply with quote
My dad had one, couldn't pull the skin off a rice pudding. I loosened the downpipe and off it went. Exhaust was badly coked up.
eunos20b
PostPosted: 20:56 - 19 Nov 2016    Post subject: Reply with quote
Katy
that explains things a bit, thanks. I expect more than 6500 from a little 2 stroke but then that's part of the reliability no doubt. Standard exhaust I've yet to get round to cleaning out, filters clean and I think I saw a receipt for a 1.9mm jet (not my doing but the previous owners). I'm not at home so I can't confirm. How would this affect my premix - if the range avaliable from Wemoto is 0.78mm to 1.9mm and I have 1.9mm, does that mean for optimum running, I run a high oil level premix I.e. Even down to 20:1? I hate to sound clueless but it's all new to me (yet interesting).
Thanks
redeem ouzzer
PostPosted: 21:06 - 19 Nov 2016    Post subject: Reply with quote
Why is it running premix? I would be tempted to find an automatic oiler and and a tank and put it back to stock.
Be a REAL MAN!
bypass2
PostPosted: 21:14 - 19 Nov 2016    Post subject: Reply with quote
Try a new plug. give the baffle a clean then give it a try.
eunos20b
PostPosted: 21:36 - 19 Nov 2016    Post subject: Reply with quote
It's running premix because... Well because I can only assume the previous owner wanted it to or the pump got knackered. I only got it last week.
Got a new plug in it now and going to try and clean the exhaust out tomorrow.
Thanks
PostPosted: 21:47 - 19 Nov 2016    Post subject: Reply with quote
Most likely he ran it out of 2 stroke and didn't know to bleed the pump, so assumed it had packed up.
PostPosted: 22:02 - 19 Nov 2016    Post subject: Reply with quote
Best thing that ever happened to 2 strokes was the oil injection pump. Why anyone would change to premix is beyond me.
Oh look, I've just gone down this long hill with the throttle shut and partially seized my bike. Rolling Eyes
The H100 is in a pretty low state of tune, hence the peak power at quite low revs. General reliability is pretty good on them, although the mains seem to suffer a bit.
Not sure on the jet size, and don't know the standard size (possibly a 125 looking online - in which case a 190 is massively bigger). 20:1 would be very rich on oil, 33:1 is probably within reason. Jet wise you need to jet appropriatly, and it isn't a case of rich = good. Rich is safe but still not good for power, hence normally you start rich and work your way down.
Personally I would source a good pump and oil tank and use that rather than premix.
Katy
redeem ouzzer
PostPosted: 22:15 - 19 Nov 2016    Post subject: Reply with quote
Premix looks better and gives more power and less weight. But it's about as much use on a standard bike as Smiler on an IAM course.
Be a REAL MAN!
eunos20b
Beats me, mate. Throttles always wide open anyway Very Happy
eunos20b
PostPosted: 22:20 - 19 Nov 2016    Post subject: Reply with quote
Katy
Thanks, will have a look for a pump. As i say it runs a treat on the mix I've given it but it just seems a bit too gutless... Might just be me. Came from a DR125SE, and before that a KC100 which never ran properly yet still felt like it had more guff than the H100.
PostPosted: 22:26 - 19 Nov 2016    Post subject: Reply with quote
While the H100 top speed is quite limited, at lower speeds they are quite spritely. I would expect up to 50 it would be noticeably quicker than the DR125.
Katy
eunos20b
PostPosted: 10:33 - 20 Nov 2016    Post subject: Reply with quote
Not heard that one before Laughing
eunos20b
PostPosted: 10:35 - 20 Nov 2016    Post subject: Reply with quote
Katy
Thanks, taking it for a good ride today (the storm has passed down this way Sick) so will report back
eunos20b
PostPosted: 10:38 - 20 Nov 2016    Post subject: Reply with quote
Maybe this is the case! I just expect that because the previous owner seemingly spent hundreds on it that he might have done the basics as well.
PostPosted: 12:31 - 20 Nov 2016    Post subject: Reply with quote
It wouldn't be the first time someone had gone to a lot of time, effort and expense to make their bike worse.
stevo as b4
PostPosted: 14:17 - 20 Nov 2016    Post subject: Reply with quote
It definitely needs looking at from what you have said. My mate used to have a low mileage H100S and though it's geared low and the engine peaks quite early. It should rev to 8000rpm on the flat and do just over 60mph indicated , maybe closer to 65 in favourable conditions.
My mates one would easily wheelie off the throttle in 1'st and 2nd if it's loading and unloading the forks with a tug on the bars is classed as a power wheelie? (some think a power wheelie is hiding face behind a fairing nose on the clocks with the front wheel coming up)
It used to leave our mate on his nearly new TZR 125 away from the lights, especially when he first got the bike and wasn't used to giving evil abuse to the clutch, because of the pinned open powervalve the previous owner had messed with.
The only thing I remember him saying is that a hot summer day would knock 10mph off the top speed when it got hot and faded a bit.
Definitely fun little bikes, but the motor would be far more fun in a beefed up MT5 chassis, which we might get to see an example of sometime this decade if Fladdem gets his arse in gear? Laughing
PostPosted: 18:32 - 20 Nov 2016    Post subject: Reply with quote
They should rev up nicely with a definate kick in the pants as you hit the powerband (a sharp snapping open of the throttle from walking pace in first sees the front wheel in the air on my one and I'm a big, heavy guy).
I can't remember which models were CDI and which were points.
If it's a points one, check the timing. Over retarded ignition timing does them no favours. From memory, there isn't actually a movable stator plate, you set the gap so it's a starting to open at the timing point then check it when fully open. if it's too big, you need a new set of points.
Also worth checking the reed valve is in good order.
eunos20b
PostPosted: 18:48 - 20 Nov 2016    Post subject: Reply with quote
A sort of reply to everyone...
I got 55 indicated today, lying flat on the tank, WOT round a nice, very slightly downhill corner that I like. Was still going but I backed off as I couldn't see shit. Would have seen 60.
I've yet to find any power band and I can't tell you what rpm it's doing as the tachometer is broke (ironically it seems to have snapped and got stuck at what would be indicated 11k).
We tried to get the baffle out today but seems it's riveted in from underneath!
I think I'm going to have to give it a bit more riding time, check the points, get the tacho fixed, find an oil pump or a decent premix ratio and then come back with more relevant info. Bike is brilliant fun with upside down bars though Twisted Evil
stevo as b4
PostPosted: 02:09 - 21 Nov 2016    Post subject: Reply with quote
It needs the exhaust hanging up for 24hours filled with caustic soda solution or drain cleaner.
While your at it you can look at the exhaust port and gently scrape out any carbon lumps or oily gunge. I'd also do a compression test to see if your getting a decent amount of compression compared to the factory specs range. If it's less than say 100-110psi it's probably a bit worn, and wants a piston and rings.
Also if your running a rich oil:fuel ratio like the 20:1 you mentioned, your just clogging it all up and it won't rev for shit. You want probably 35-40:1 with a good oil,
and go up no more than 1-2sizes on the main jet at the most, or you'll still be too rich, as 40:1 doesn't really weaken off the mixture by much over petrol alone IMO.
But put a pump on it and get it set up and working right, as riding a pre-mix stroker particularly a performance one on the street is a ball ache, and distracts you too much from good riding, worrying about making sure your keeping the motor oiled enough under high speed no load conditions etc.
eunos20b
PostPosted: 08:32 - 22 Nov 2016    Post subject: Reply with quote
Thanks that's helpful. I'll probably stick to something like 40:1 til I can get a pump and do the rest on a weekend when it ISNT raining (when will it end)...
The last post was made 9 years, 310 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.18 Sec - Server Load: 0.53 - MySQL Queries: 16 - Page Size: 138.39 Kb
