YBR125 - what does this hose do?
Jaymz1975
PostPosted: 18:09 - 26 Nov 2016    Post subject: YBR125 - what does this hose do? Reply with quote
Hi there,
Just cleaned the Yam and manage to dislodge a pipe It comes from the left hand side under the tank as you look at the front of the bike....is it a fuel breather hose??
If so, where should it be routed.
Cheers, James
jaffa90
PostPosted: 18:28 - 26 Nov 2016    Post subject: Reply with quote
Sounds like the suction pipe from the fuel tap to the intake /carb manifold. This keeps the fuel flowing when the engine is running.
Jaymz1975
PostPosted: 18:52 - 26 Nov 2016    Post subject: Reply with quote
Thanks jaffa90. Do you know where the other end should go?
ThatDippyTwat
PostPosted: 19:38 - 26 Nov 2016    Post subject: Reply with quote
It may also be a pipe that comes from a plastic collector that sits under the edge of the tank. It goes nowhere, it's to drain water that collects in/around the ridge of the tank. Stick it in where the lower front engine mount is.
Jaymz1975
PostPosted: 20:26 - 26 Nov 2016    Post subject: Reply with quote
Top man - that's it, it comes from a plastic squeezeable collector. Thought it must be something minor as it did come away rather easily.
Problem solved!! Thanks muchly...
Hong Kong Phooey
PostPosted: 22:53 - 28 Nov 2016    Post subject: Reply with quote
It's the secret supercharger boost hose. Don't tell anyone, 'tis a secret Thumbs Up
The last post was made 9 years, 255 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.11 Sec - Server Load: 2.43 - MySQL Queries: 13 - Page Size: 45.46 Kb
