CRF450x Not Starting
Gozp
PostPosted: 22:26 - 18 Dec 2016    Post subject: CRF450x Not Starting Reply with quote
So when I go to start the bike with the e-start I just get a click coming from the starter solenoid. It's a 2011 with 3000 miles so I don't think it will be something big. I've replaced the starter solenoid and get the exact same problem, it will occasionally spin the starter motor but not enough to turn the engine over. I've had the battery checked at Halfords and they said it was fine.
Also not sure why but when the bike is in gear and the clutch is held fully in I can't move the bike, however, it seems to be easier to push the higher the gear (Was trying to bump start the bike). I managed to bump it in 4th gear but it cut out because it was too low on revs Confused
I'm also unable to kick it over as I'm just not that good at it.
PostPosted: 23:20 - 18 Dec 2016    Post subject: Reply with quote
Halfords.
Attach it to a car battery and crank it. That will tell you if Halfords are just fucking retarded.
Learn to kick it, leave ign off, kick over through the 'loose' ones until it gets quite stiff, put it all the way to the top again, ign on and belt it down. Don't twist the throttle.
Gozp
PostPosted: 23:23 - 18 Dec 2016    Post subject: Reply with quote
Paddy. wrote:
Halfords.
Thanks for the reply, will try that tomorrow and will update you.
PostPosted: 23:30 - 18 Dec 2016    Post subject: Re: CRF450x Not Starting Reply with quote
How did Halfords check the battery?
What tool(s) did they use?
Gozp
PostPosted: 23:36 - 18 Dec 2016    Post subject: Re: CRF450x Not Starting Reply with quote
It was a machine that he put the battery in and he typed the serial # into.... will try getting it started and leave it running tomorrow.
doggone
PostPosted: 23:45 - 18 Dec 2016    Post subject: Reply with quote
I more concerned about the clutch drag or whatever, has that come on gradually before the starting issues?
It does sound like a failing battery but if something is making the engine very hard to turn over you'd get similar symptom.
Gozp
PostPosted: 00:04 - 19 Dec 2016    Post subject: Reply with quote
Just bought the bike, had it started with the e-start the same day I collected it but the next morning it wouldn't start.
jaffa90
PostPosted: 01:46 - 19 Dec 2016    Post subject: Reply with quote
Sounds like car oil in the engine if it`s a wet clutch.
Gozp
PostPosted: 03:19 - 19 Dec 2016    Post subject: Reply with quote
Pretty sure it is motorcycle oil as he gave me the rest of the bottle, however, I measured the gearbox oil and it was over the max level on the dipstick. Could this cause the problem?
PostPosted: 10:52 - 19 Dec 2016    Post subject: Re: CRF450x Not Starting Reply with quote
Clutches can seize if the bike's been left for a while. If you ridden it, I wouldn't expect that to be the case.
Enduro bikes are often finicky starts, but the X has always been ok and certainly by this year I expect.
However, it probably still will have a low capacity battery and a relatively light weight starter.
So, start with jump starting with a car battery.
Presuming it is carb (quick check suggests it is), I would also clean the carb out if it hasn't been recently. A season's off road riding will normally mean they are a bit clogged.
This doesn't explain the rest, but may make it easier to kickstart - though that still does take some technique and a bit of strength.
Gozp
PostPosted: 21:29 - 19 Dec 2016    Post subject: Re: CRF450x Not Starting Reply with quote
The guy I bought it off said he only used it 6 times, so this could be the case. I'm going to try bumping it in 3rd gear. I read that the clutch problem can happen when the bike is cold, apparently once it's warm it will be fine.
Gozp
PostPosted: 04:10 - 20 Dec 2016    Post subject: Reply with quote
So I messaged the guy I bought it from and he said you can't bump start it because it has high compression. Also noticed when I hold the e-start down for a bit it starts to buzz, pretty sure this means the battery is dead.
Might try jumping it from a car tomorrow.
PostPosted: 09:04 - 20 Dec 2016    Post subject: Reply with quote
Just do it, take literally a minute. Leave car off, connect + to + and - to - or frame, doesn't really matter, they are the same in theory... but then just crank the bike over.
You'd not want to try bumping a big single anyway, it'll be proper hard Laughing
PostPosted: 15:51 - 20 Dec 2016    Post subject: Reply with quote
I had the same issue with my KTM, worked out the earth strap was corroded. 2 minutes with a file it was perfect again
Gozp
PostPosted: 00:46 - 25 Dec 2016    Post subject: Reply with quote
Tried jumping it from a car but still got nothing! this is beginning to annoy me. I pay £3000 for a bike that doesn't start Mad
But thanks for the suggestions guys.
Gozp
PostPosted: 00:49 - 25 Dec 2016    Post subject: Reply with quote
Where's the earth strap located?
My thoughts were to check the wiring from the solenoid to the starter motor. But if it's not this it must be the starter itself Sad
doggone
PostPosted: 01:10 - 25 Dec 2016    Post subject: Reply with quote
There should be a fairly simple black wire from battery negative to frame, they tend to corrode where attached to frame, a simple test is connect battery negative to a bright bit of metal with your jump lead and see if there's any change - even if it still won't start.
This is a useful test with any vehicle mysteriously not turning over.
PostPosted: 09:56 - 25 Dec 2016    Post subject: Reply with quote
I would try the negative jump lead to a conductive bit of frame as above and the positive (carefully) directly onto the positive terminal of the starter motor.
This should pretty categorically show you if the starter motor is at issue or a connection.
PostPosted: 16:53 - 25 Dec 2016    Post subject: Reply with quote
Practice using the kick start and use the electric starter as more of an electric restarter. Thumbs Up
Gozp
PostPosted: 23:41 - 04 Jan 2017    Post subject: Reply with quote
Update: Still no luck with the bike. I've checked a lot of the wiring and it looks okay to me, starting to think the starter motor could be jammed... would this link to the bike not moving in gear?
Also, I'm going to have to get a mechanic out to look at it, going to try the last thing suggested by you guys which is jumping it linked up to the starter motor.
PostPosted: 23:57 - 04 Jan 2017    Post subject: Reply with quote
The starter not turning shouldn't stop anything else on the bike working if the sprag clutch is ok.
When you jump start to the starter, I'd attach the earth to the engine or frame just in case there is an earth-strap issue.
Gozp
PostPosted: 00:19 - 05 Jan 2017    Post subject: Reply with quote
Yeah took the earth strap off and added some more insulation because it looked pretty worn. Will be trying that tomorrow and i'll update you, hopefully it's not the starter because that's £200 alone.
Gozp
PostPosted: 18:07 - 07 Jan 2017    Post subject: Reply with quote
Update: Had a mechanic round and he got it to turn the starter with jump leads. Have no idea why i couldn't jump it but he said i need a new battery and a new spark plug.
Is Champion good or shall i get NGK? the NGK is double the price.
jaffa90
PostPosted: 21:09 - 07 Jan 2017    Post subject: Reply with quote
Nowt wrong with Champion. Should be on e-bay for a fiver.
The last post was made 9 years, 262 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.09 Sec - Server Load: 1.21 - MySQL Queries: 16 - Page Size: 125.84 Kb
