Honda Police switchgear
sickpup
Old Timer
PostPosted: 13:56 - 15 Dec 2016    Post subject: Honda Police switchgear Reply with quote
For years Honda have supplied bikes to the Emergency services and Military, many of these bikes use a different right hand switchgear with extra integral switches for activating the extra lights and sirens etc.
Its a bit odd that the extra switches are on the right, the left side would make more sense as your left hand does less but it seems to work anyway.
The switch is a lot bigger than a standard one and 11mm wider, the throttle cables also exit from the bottom rather than the front so you often need bar risers so the throttle cables miss the fuel tank.
This picture shows just how much bigger the Police switchgear is
https://i945.photobucket.com/albums/ad297/750RK/Deauville/20161212_042813_1481808263413.jpg
The basic features of the Police switchgear are also wired differently to most other switchgear filling all nine of the possible positions in the connector.
https://i945.photobucket.com/albums/ad297/750RK/Deauville/20161212_042859_1481808262767.jpg
I will be aiming to fit this to a 2001 NT650V Deauville. The standard Deauville switch only uses eight of the nine positions.
https://i945.photobucket.com/albums/ad297/750RK/Deauville/20161212_042838_1481808263138.jpg
The circuit positions within the switch are also different so these need to be altered to work on the Deauville.
The Police Switch has a lead that is about 4 inches shorter than a Deauville one so this gives space to have a bridging link to alter the circuits positions within the connector without having to modify the actual switch.
Circuit positions in each switch are here
https://i945.photobucket.com/albums/ad297/750RK/Deauville/20161212_043621_1481757705528.jpg
sickpup
Old Timer
PostPosted: 16:46 - 15 Dec 2016    Post subject: Reply with quote
So whats the point of fitting one of these?
If you fit anything like spotlights you will need a switch to operate them. Adding switches to the bars ends up being very untidy so to have a switchgear with the addtional switches already fitted is a spacesaver and keeps things tidy.
P.
PostPosted: 17:12 - 15 Dec 2016    Post subject: Reply with quote
-Monty- had a pan with those on, so many switches with so many possibilities.
Skudd
PostPosted: 20:13 - 15 Dec 2016    Post subject: Reply with quote
I want one.
sickpup
Old Timer
PostPosted: 22:40 - 15 Dec 2016    Post subject: Reply with quote
Skudd wrote:
I want one.
It could be arranged, there are a few on Ebay. What bike do you have?
PostPosted: 01:43 - 16 Dec 2016    Post subject: Reply with quote
You need a wiggly tool. (my name for it)
https://www.vehicle-wiring-products.eu/shopimages/products/extras/NEW%2070399%2003-12.JPG
sickpup
Old Timer
PostPosted: 14:20 - 16 Dec 2016    Post subject: Reply with quote
So we need a conversion bridge connection to extend the lead and make it all work.
The following conversion needs to be performed. To a degree it doesn't really matter which direction through the switches the positive or negatives go with two exceptions which I will show later.
First column is Deauville side, second column is switch side.
1 > 2 Bl/w Kill / Starter
2 > 7 Blu/w Headlight
3 > 6 Gr/y Brake switch
4 > 9 Bl/w/r Headlight
5 > 3 Bl Kill
6 > 8 Y/r Starter
7 Empty
8 > 1 > 4 Pilot (Live)
9 > 5 Br > Br/w Pilot
It'll take a little playing with a multi meter but initially I suspect that the Deauville shares a positive for the Pilot and brake circuits.
groovylee
PostPosted: 14:40 - 16 Dec 2016    Post subject: Reply with quote
forgive me if i'm stating the obvious, but you know you can push the socket pins back out and locate them in the right configuration don't you?
you need to flatten the barb bit inside, then they slide right out.
Past - 1988 honda revere 600, 1996 kawasaki gpz500s, 1999 Yamaha R6
Current - 2002 Aprilia RSV1000R & 1999 Kawasaki ZX6R
sickpup
Old Timer
PostPosted: 15:38 - 16 Dec 2016    Post subject: Reply with quote
Yes I know this but the Deauville only uses 8 of the nine connections and the Police switch gear lead needs extending so just moving the pins around wouldn't work.
sickpup
Old Timer
PostPosted: 17:06 - 16 Dec 2016    Post subject: Reply with quote
One bridging connector
https://i945.photobucket.com/albums/ad297/750RK/Deauville/20161216_152346.jpg
All except one in black as I only keep black and red cable at home. The red is a soldered 2 into 1 connection and it works perfectly to convert one type to the other.
Skudd
PostPosted: 15:47 - 17 Dec 2016    Post subject: Reply with quote
sickpup wrote:
Skudd wrote:
I want one.
Varadero 1000
sickpup
Old Timer
PostPosted: 16:29 - 17 Dec 2016    Post subject: Reply with quote
Skudd wrote:
Varadero 1000
A bit difficult on one of these due to the separate throttle tube but not impossible. It would possibly require custom throttle cables but this wouldn't be difficult.
By the looks of it the Varadero lights are always on so you would have an additional switch to play with.
From an electrical point of view it would be easier than most due to only needing to wire in the start button and kill switch.
TheSmiler
PostPosted: 19:13 - 20 Dec 2016    Post subject: Reply with quote
sickpup wrote:
Skudd wrote:
Varadero 1000
Couldn't skudd just look for someone who has an ex police varadero, there are some from google image searches. That way less modification needed. Interesting thread considering looking for an ex police k100 now just see the difference in the switchgear.
ThatDippyTwat
PostPosted: 22:18 - 20 Dec 2016    Post subject: Reply with quote
If someone could link me to one of these, that would be awesome. I have a project in mind that could use some stock looking switches. My ebay searches are not turning anything up.
Dimerz
PostPosted: 03:18 - 21 Dec 2016    Post subject: Reply with quote
Sorry if I'm being a tard here, but why would you want lots more lights/switches?
trevor saxe-coburg-gotha
PostPosted: 10:00 - 21 Dec 2016    Post subject: Reply with quote
My 90's cb500 could sometimes benefit from extra lights, I think. But I decided because I don't actually ever ride in the dark that much, I could probably get away without them - even though they would make me more conspicuous in daylight hours too. One idea I had as a cheap ass quick fix bodge was to get cheap bicycle lights and tighten them onto the indicator stems and just switch them on and off by hand, and use rechargeable AAA batteries in them! But I thought all the big lads at Squires would call me a puffter and gob in me cuppa when I wasn't looking.
Aside from that though was the conclusion I drew that they'd probably just shake off or else simply dismantle themselves part way into the first ride with them on. These sort it was:
https://www.digitalsave.co.uk/images/detailed/1/front_bike_light.jpg
sickpup
Old Timer
PostPosted: 10:41 - 22 Dec 2016    Post subject: Reply with quote
The Varadero's didn't have them fitted.
They use standard switchgear.
You live in London so must have seen all the bikes with spotlights?
There you go, clicky.
The last post was made 7 years, 125 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.08 Sec - Server Load: 0.57 - MySQL Queries: 17 - Page Size: 102.4 Kb
