Author |
Commuter_Tim |
Commuter_Tim World Chat Champion
Posted: 01:42 - 16 Dec 2016 Post subject: Aqua Ingress/Pissing water |
So since it started raining, I immediately died due to lack of WipeyPal...
Well no but it appears my bike may be dying...
2 weeks ago my bike started chugging along after filling up petrol Would try to stall and barely idle at more than 900rpm (idle is normally around 1500rpm)
The exhaust sounded like it was producing weak farts on every combustion.
I thought it may have just been some shit/water in the fuel so ran it for a while in hopes to burn off the water.
It idled fine the next morning.
I emptied the plugged rubber hose at the bottom of the bike (crankcase breather?) and approx a third a cup of water came out.
A week later the problems returned (without filling up this time) again managed to burn through it, and emptied a third cup of water again.
Even though the idling issues have not returned in over a week, I have been emptying that plugged up hose on a 48 hour basis, and there is a considerable amount of water each time.
Where should I start looking for water ingress first?
[/TEF]
EDIT: My Bandit lives outside without a cover, this only really seems to be happening when its raining overnight, hard to say if that's the cause though. ____________________ The above post is most likely nonsensical.
I ride a Bandit 600... badly.
Back to top |
stinkwheel |
Back to top |
Commuter_Tim |
Back to top |
CaNsA |
CaNsA Super Spammer
Back to top |
BTTD |
BTTD World Chat Champion
Back to top |
stinkwheel |
Posted: 10:35 - 16 Dec 2016 Post subject: |
If it's the airbox drain and you're getting a cupful of WATER in 24h, I suspect the cause will be obvious as soon as you take the saddle/tank off.
If it's petrol, I'd suspect you have a blocked/leaking needle valve or punctured float.
@jnw010, airbox drain hoses often have a bung in them. It's just there to drain out any condensation. You'd normally get a few ml over a period of months, no more than fits in the tube itself. ____________________ “Rule one: Always stick around for one more drink. That's when things happen. That's when you find out everything you want to know.”
Back to top |
BTTD |
Back to top |
mudcow007 |
mudcow007 World Chat Champion
Back to top |
Robby |
Robby Dirty Old Man
Back to top |
Commuter_Tim |
Back to top |
Commuter_Tim |
Posted: 00:21 - 22 Dec 2016 Post subject: |
So I had the tank off/Air filter out, no damage/holes I could see.
However after I filled up with petrol again and left sitting overnight it started farting out the exhaust, underpowered and idling about 1000 instead of 1500 again.
Again dropped petrol from carbs, blasted the engine for a bit, and it was all good again.
Is it possible if water dripped into the tank during fillup, it could end up coming out of the airbox drain? (evaporation blasting back or something?) ____________________ The above post is most likely nonsensical.
I ride a Bandit 600... badly. |
Back to top |
jaffa90 |
jaffa90 World Chat Champion
Back to top |
stinkwheel |
Back to top |
CaNsA |
CaNsA Super Spammer
Posted: 01:04 - 22 Dec 2016 Post subject: |
Commuter_Tim wrote: | So I had the tank off/Air filter out, no damage/holes I could see.
Is it possible if water dripped into the tank during fillup, it could end up coming out of the airbox drain? (evaporation blasting back or something?) |
There is usually a drain around the tank filler cap that leads to a pipe which runs down the inside of the tank and feeds into a drain pipe attached the underside of the tank.
That can get blocked with debris, which prevents water draining away and leaves it sitting around the filler cap rim.
Open cap, water spills into tank. Bad times.
The only reliable way to safely clear a blocked drain is to use compressed air and blow it from the bottom up.
Do not poke anything in the hole, you might puncture the pipe in the tank and then you wil cry like Wonko.
I would take the tank off and drain it into a clear receptacle, then you can see if there is any water in the tank.
While the tank is off, check the filler cap drain.
Using a can of compressed air, like the stuff used for dusting computers, blow up through the drain from the bottom. |
Back to top |
Wafer_Thin_Ham |
Wafer_Thin_Ham Super Spammer
Back to top |
Commuter_Tim |
Back to top |
Commuter_Tim |
Posted: 21:55 - 22 Dec 2016 Post subject: |
CaNsA wrote: |
Cheers dude but I had that problem on the CB500.
Ze Bandit doesn't fill up with rivers like that, at worst 1 or 2 drops of water came off the cap into the tank last I filled up, the 'rim' was bone dry, just how I like it.
Back then I stupidly did poke the top drain hole with an air can straw and blasted it.
I didn't think about the tubing inside, so cheers for that heads up should I need to do it again.
I do have to press the cap down like a bastard every time I want to open/close it though.
So I'm now wondering if the cap seal has failed and is always letting water in. ____________________ The above post is most likely nonsensical.
Back to top |
Commuter_Tim |
Back to top |
Commuter_Tim |
Posted: 23:34 - 20 Jan 2017 Post subject: |
In case anybody else has this issue, I finally appear to have sorted this....
The seal around the airbox cover is made of something similar to that 1mm foamy sheet you get layed over the top of the cheapest socket sets on Ebay.
It is cheap, shit and fucked, causing water to pool in the airbox, fill up the plugged hose, and overflow through the air filter into the carbs.
I have noob bodge fixed it with Hylomar Blue and its been fine for a week with a fair bit of rain here and there. (I'm aware that's not its intended purpose, but it was to hand)
All going well I'll source a proper seal, all going wrong the Blue got into the carbs and gummed shit up.
Cheers fellas ____________________ The above post is most likely nonsensical.
Back to top |
stinkwheel |
Back to top |
Tdibs |
Tdibs Traffic Copper
Back to top |
Commuter_Tim |
Back to top |
Commuter_Tim |
Back to top |
mudcow007 |
Posted: 01:55 - 22 Jan 2017 Post subject: |
weirdly, my Bandit does something similar in the rain.
In the dry it idles happily, in the wet it idles much slower on the verge of knocking/ spluttering an dying.
I have sat there an held the throttle open a touch at the lights to just keep it going
cheers will check the seal on mine |
Back to top |
Commuter_Tim |
Back to top |
The last post was made 7 years, 88 days ago. Instead of replying here, would creating a new thread be more useful? |
