Honda CBR 125 weight modifications,performance enhancers etc
Bike Chat Forums Index -> General Bike Chat Goto page 1, 2, 3, 4, 5, 6, 7  Next
Arcane1729 This post is not being displayed because the poster is banned. Unhide this post / all posts.
redeem ouzzer
PostPosted: 08:34 - 26 Dec 2016    Post subject: Re: Honda CBR 125 weight modifications,performance enhancers Reply with quote
Arcane1729 wrote:
Which full exhaust system will give the biggest increase in bhp the CBR125 and the biggest reduction in weight?
Any other performance enhancing modifications would be appreciated, thanks.
Best mod is a full licence and purchase of a fireblade.
However if you insist-
Weight, get rid of as much as possible. Anything electrical not needed for an MOT, junk the battery if possible (or use the smallest one possible), centre stand, basically anything not needed for propulsion. For speed add lightness.
Be a REAL MAN!
stevo as b4
PostPosted: 09:34 - 26 Dec 2016    Post subject: Reply with quote
Are you in a one make race series, or is it for road use? Does it need to be legal, fast or reliable?
Seeing as your post comes across as bhp and weight reduction are equally important I'm assuming it's for track use?
Weight loss will not matter for shit on the road, there's a good argument too for ''keep it heavy: keep it reliable''
In terms of Pure power output, any pipe will have no noticeable effect on performance on its own. Your looking at barely measurable gains at best.
If you have race class rules on modifications, what are they?
If there's no rules or its a road bike, then budget allowing, fit a 170cc big bore kit to a fresh or low mileage bottom end , with a flowed head with bigger valves and a performance cam too. You'll need a way to tune the EFI fuel delivery to suit then too.
You'll spend a relative fortune doing the above including dyno set up, but will make alot more bhp and a big percentage gain, maybe 40-50% more. 40% reduction in engine life. Would be a fair trade off for that too.
PostPosted: 09:38 - 26 Dec 2016    Post subject: Reply with quote
Probably something like Akrapovic system which gives you a dizzying 0.8 bhp.
secretagentmo...
PostPosted: 09:52 - 26 Dec 2016    Post subject: Re: Honda CBR 125 weight modifications,performance enhancers Reply with quote
Is the correct answer. Forget trying to tune the 125, never going to happen with modern bikes, time to get the test passed, be cheaper too!
PostPosted: 10:34 - 26 Dec 2016    Post subject: Reply with quote
It's already one of the quicker 4 strokes. You won't make.it much faster. Just deal with it.
dydey90
PostPosted: 12:10 - 26 Dec 2016    Post subject: Reply with quote
Aloysius Parker wrote:
Arcane1729's Public Bio
21 year old at uni. Will do my A2 in October and buy a
Yamaha FZS 600 Fazer.
Oh, A2 done then?
Trade it in for a Suzuki SV650. You should be able to get one for a similar price to a CBR125.
That gives you a 32bhp power increase for next to no money, while I would think is your main concern as a student.
andyscooter
PostPosted: 12:14 - 26 Dec 2016    Post subject: Reply with quote
You weren't the twat riding round droitwich conastantly for two hours were you op
If so the bike aounds shit and you need to fuck off
Two hours of a drone going around yesterday up ring road and round again could here rhe open pipea lpoud deone all the way round
RhynoCZ
PostPosted: 12:19 - 26 Dec 2016    Post subject: Reply with quote
Let's give the OP some real answers.
Exhaust = titanium.
Change all the metal bits you can for titanium or aluminium.
Drill all the bits that you can't change for the above.
Get fiberglass fairings and lose some weight yourself.
Now for the engine = big bore kit + pay the specialist for the tune up.
Teflon-Mike
tl;dr
PostPosted: 12:38 - 26 Dec 2016    Post subject: Reply with quote
CBR125's been around a while & gone through at least one major re-design. I'm trying to remember whether the very first had carbs or if they have all had fuel injection, these sort of things do rather influence matters. All model's though are down almost 2bhp on what A1 Learner Licences 'may' permit, as they are one of the lighter bikes in class to start with.
In their early days, there was a 'Factory' HRC race-kit for them, for Mini-Stocks 125 racing. Comprised a pair of hi-lift cams, a lighter, but 'race legal' (103dB, ISTR) pipe and revised fuel map. There may have been other goodies in the box, like lightweight 'replica' plastics and possibly a different back shock & brake pads. 'Kit' gave the motor about 16/17bhp ISTR, and REALLY is about the best you can hope to do with one.
The HRC kit cams hint at the 'problem' trying to tune a CBR125 motor; those HRC cams, liberated an extra 15% more power from the thing without any extra displacement. So, you can muck about to your hearts content, but if the cams don't open valves far enough or long enough to let in enough 'charge' to make more than 13bhp, it don't matter much how bigger the hole beneath them is, or how big the holes in front of them are, those valves still wont flow any more charge, so you wont get any more power.
Tiddler Tuning is a general exercise in futility, where at best, you'll likely get no real measurable gain for whatever you try do, however much you spend. And most likely, you will actually loose both performance and reliability in equal measure to your efforts.
Meanwhile 'Power to Weight'... weight has no influence on top speed; that's purely a function of power vs drag. Does make a difference to acceleration, but, PTW is rather misleading on bikes, where the 'weight' the power has to shift is the 'all up' weight of bike + rider, where even on a 200Kg heavyweight, the 80Kg or so of rider, is quite a significant factor, it isn't to cars where the driver is likely less than 1/1oth the vehicle weight. On a 125Kg lightweight? The rider can almost halve the PTW ratio!
You can save a few grams from ditching the indicators or using titanium clutch cover screws I suppose.... B-U-T in the scale of thing, taking loose change and unused keys out your pocket would probably make as much difference! Heck, leaving your Smart-Phone at home, probably save as much mass as a 'race' exhaust!
As has been said, for the road, it's all rather pointless; if you actually achieve anything, then it will almost certainly breach L-Plate/A1 licence regs, and if you have a licence to ride the thing legally you could have got an awful lot more, an awful lot more cheaply ad easily, just by buying something else!! Heck, even the fastest of the fast illegal on L's/A1 125's, the Aprilia RS or Cagva Mito two-strokes, that might just scare 30bhp, and 100MPH, are only just about as powerful and quick as an old 250cc commuter bike!
For the track? Old Padock Lore: Want a faster bike? Fit a Better Rider!
A better rider, will go quicker, without necessarily going any faster; they'll be 'smooth', they'll not 'waste' speed slowing down so much to have to speed up again so often; they'll not load the tyres with violent action, so save grip to react higher corner speeds; so it will 'look' all rather un-dramatic, but they'll get the absolute most the bike can deliver, whatever that happens to be.... and time and time and time again, in the heat of real competition where points mean prizes not penalties and the stop watch never lies; them 'better riders' get far more impressive 'results' from that pure talent than thier mechanics can ever find them from a bit of tinkering or even a heck of a lot of 'cheating'!!!!
To wit.. most will be found improving your riding, NOT your bike...
Better rider? Makes the bike go faster, and further, between services and doesn't crash. So, its all win; bike holds its value; whilst not costing any more to run or insure. AND better rider fits any bike it's fitted to.. 'no cost'.. It's ALL win.
So... my advice, forget trying to tune a tiddler; work on that 'better rider'.. go get trained, go get that licence you suggest you plan in your profile.
stevo as b4
PostPosted: 13:23 - 26 Dec 2016    Post subject: Reply with quote
I didn't know OP was a hopeful on a hiding to nothing newbie, desperate for a tiny bit more interim speed. His post didn't come across that way, like the countless fools that say 'make my xxx faster for 3ponds'
I thought race use hence my reply.
I also disagreed really with the weight loss idea, as I thought he was after power and speed, not making the most of what's already a light bike, with little weight to loose reliably without making it fragile.
Big bhp increases affect top speed and high speed acceleration unless your looking at aerodynamics in a committed serious way to the point of a stream liner or speed record machine. Weight does not have any effect really on top speed once your going quick enough for wind resistance to matter.
redeem ouzzer
PostPosted: 13:26 - 26 Dec 2016    Post subject: Reply with quote
^^disregard Captain 'Tism (teffers) up there.
More power will make you faster in a straight line. Less weight will make you faster EVERYWHERE.
But you have to be autistic about it.
Battery - small or replaced with an eliminator
Starter motor and relay - scrap bin
Clocks - minimise
Ignition switch - remove
Anything not needed for propulsion should be open to review, trust me, once you start throwing stuff away it gets addictive.
Be a REAL MAN!
PostPosted: 13:52 - 26 Dec 2016    Post subject: Reply with quote
OP was just on about getting an FZ6 (on A2?) but only if he can find the right flyscreen to make it be bitchin'.
So I'd suggest the ideal bike is an R6. Imaginary ones can be as light as you like.
notbike
PostPosted: 14:30 - 26 Dec 2016    Post subject: Reply with quote
If a panigale engine can fit inside a grom, it can fit in your CBR125, just saying. Pic related.
https://www.todocircuito.com/ckfinder/userfiles/images/honda-msx-panigale-ducati.jpg
stevo as b4
PostPosted: 14:33 - 26 Dec 2016    Post subject: Reply with quote
He must have had trouble wording his post then, as where I come from CBR125 is spelt differently to FZ6?
I like light bikes, love them even. But say on my own 125 that started out at 99kg dry, I've maybe lost 3-4kg from it having a non std exhaust, rear light and numberplate holder, alloy handlebars and the removal of the oil pump and cables?
For road use it doesn't seem to make any difference, and unless I weigh it against a std bike I doubt I'd know it's lighter? I certainly wouldn't feel the difference lifting it onto a workstand. But I would agree that for off road trials or enduro use, having it weigh 90kg is better and less tiring over the day than it being 100kg.
definitelyinc...
PostPosted: 14:53 - 26 Dec 2016    Post subject: Reply with quote
Had a CBR 125 '15 plate, no point in m odding it, keep it stock, tidy and work towards a full license, nothing matches up to going from a 125 to a 650, just saying, sell off said 125 for as much as possible, job done.
Edit: Even someone I know who has a derestricted 2 stroke 125 which (I think) makes 33bhp when derestricted is left behind in the dust by my heavier, restricted 650cc, so no matter how hard you work to mod it you won't get any more adrenaline from it than you already do :/
arry
PostPosted: 15:01 - 26 Dec 2016    Post subject: Reply with quote
dydey90 wrote:
Oh, A2 done then?.
Flunked then flounced from memory.
PostPosted: 15:03 - 26 Dec 2016    Post subject: Reply with quote
If you want a fast 125 then you should get a two stroke. Thumbs Up
PostPosted: 16:04 - 26 Dec 2016    Post subject: Reply with quote
Oh, lordy, yes.
Crashed his scootay on his first ride, totes not his fault.
Had 3 days of A2 lessons, ragequit.
Is possible restrict KTM Superduke 1290 for A2 tho?
Want FZ6 S2 naow (still no licence, hasn't spotted that the FZ6 isn't legal for A2 anyway).
Rather than investing in a licence, is thinking about pouring money down the 4-stroke 125 racebike hole.
Serial fantasist manchild.
definitelyinc...
PostPosted: 18:44 - 26 Dec 2016    Post subject: Reply with quote
Rogerborg wrote:
Oh, lordy, yes.
I think there was one year when the fzs6 was a2 legal, I may be wrong though.
Investing in the 4 stroke 125 racebike thing is beyond silly when you're of age to get the er6n, mt07, sv650s, or any other similar bike, especially when you're after performance.
Hong Kong Phooey
PostPosted: 20:11 - 26 Dec 2016    Post subject: Reply with quote
Shame it got a bit burnt in the fire Confused
definitelyinc...
PostPosted: 20:15 - 26 Dec 2016    Post subject: Reply with quote
Any videos of this grom? I'd love to see it in action.
Teflon-Mike
tl;dr
PostPosted: 06:12 - 27 Dec 2016    Post subject: Reply with quote
Arcane1729 wrote:
Why isn't the FZ6 A2 legal anyway? It's 90bhp...
The law doesn't take 'random' internet power claims, it takes what's on the maker's plate; other sources suggest it's claimed at 72Kw (98bhp).... MCN probably took an independent 'Rear Wheel' figure.
Point of symantics, though even if it were 70Kw/90bhp, it still wouldn't be A2 'complaint'.... 'as standard'.
Licence restrictions state 35Kw 'max', so it is over licence limits, and would have to be 'modified' to be 'made' A2 complaint.. then other regs kick in; notably that a bike cannot e 'restricted' by more than 1/2 original claimed power, and must remain within the 0.1Kw/Kg? I think PTW limit, as well as the 35Kw A2 max licence limit.
Arcane1729 wrote:
Also can't a man dream about two bikes?
A man can dream... but most of them are probably best not voiced.... Folk will likely think you are just mad, sad or simply a pervert.
Arcane1729 wrote:
On the plus side I passed my car test at the start of this month- 3 minors Smile (I had to save up for that as well you know... six weeks of almost daily lessons set me back over a grand)
Do you have a car?
Given your comments in other thread about being "So" passionate about bikes you make up new words.... I have to say my eye-brows are doing a good job of keeping my bald-spot warm, and tend to agree with the Jockish Hobit about being a serial fantasist, TBH.
IF you had the passion you claim for 'bikes', then you wouldn't be spending a grand to get a car licence, to drive a car you, I presume don't own or have regular access to. You would have put that cash to nailing down your A2 tests, or getting up to scratch going it alone on a 125 for A1 as a 'Dry Run' (Which ISTR even Roger, usually aghast at offering my common advice, suggested to you, some while ago).
Arcane1729 wrote:
I've already paid for my lessons- it only took a week of work during the christmas holiday
Was that delivering pizzas on a push-bike still? As said, putting the cart before the horse, you could have been doing that on a 125, without L-Plates, or even a 'big-bike'. Better late than never I suppose, except that pizza isn't so nice cold.
Arcane1729 wrote:
I'm gonna buy a CBR first and sell it after a few months when I'm ready- I was just curious was all- Honda had 15bhp limit and for some reason they've made it so weak... Of course it'd be silly to invest any money into it.
? Shocked ? Surprised ? Shocked ?
I retract comment about agreeing with the Borg on your serial fantasys.... 'serial' implies some sort of logical order.... 'random fantasist'... I think is more apt.
You are an ADHD gold-fish, aren't you? You leap down a train of fantastical inspiration, based on whatever you have bumped into most recently to inspire you! THEN try and find 'reason' to support the 'notion'... rational 'planning' is just NOT involved is it?
Arcane1729 wrote:
My motoring exploits haven't been totally hopeless!
Hopeless or Hapless? I'll go with the latter.
Arcane1729 wrote:
Even if the FZ6 (if you could kindly explain) is not available then all is not lost good sir! we have these two beauties still available:
Eh? What two beauties?!?! No! Dont bother, I don't care!!
STOP THINKING....... I would add the rest of the mantra "Start Riding" but in your case, that's optional!!!
Get a grip kid. Sparks is firing, flames are occasionally occurring, but the pistons ENT going up and down, or if they are, they aint making motion!
Turn the ignition 'off', stop making brum brum noises in your hat; and take a good long look at the matter!!! Get your ideas in order... and then stick them on a high shelf WELL out of the way, THEN go learn how to ride a motorbike!
The last post was made 9 years, 281 days ago. Instead of replying here, would creating a new thread be more useful?
Page 1 of 7
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.17 Sec - Server Load: 0.52 - MySQL Queries: 16 - Page Size: 154.88 Kb
