Fuel gauge - voltage or current?
ThatDippyTwat
PostPosted: 11:53 - 29 Dec 2016    Post subject: Fuel gauge - voltage or current? Reply with quote
Does a fuel gauge work on voltage or current?
I know newer ones are probably CANBUS, but I've been asked about the feasibility of a custom dash on a couple of older, fighter'd bikes, oil cooled GSX, Z1000 and Z750 Turbo, Also if the kid likes it, the kids YBR (Go figure). The rest I'm fine with, but I realised I have zero idea on which principle a fuel gauge works.
Any pointers? I'm fine with electronics, it's just the principal that I have no idea about.
Nobby the Bastard
Harley Gaydar
PostPosted: 12:06 - 29 Dec 2016    Post subject: Reply with quote
Most fuel guages I've looked at tend to have 3 wires, one earth, one constant 12v and the one from the sender (which is just a variable resistor) with a voltage between 0 and 12v depending on position.
Triumph Sprint ST 1050
PostPosted: 12:09 - 29 Dec 2016    Post subject: Reply with quote
Motorcycle fuel guages run on lies, modulated by hearsay and guesswork.
ThatDippyTwat
PostPosted: 12:51 - 29 Dec 2016    Post subject: Reply with quote
I had figured that as a likely way to do it. I'll just have to go over and get the meter out on the running bikes and see what's what before committing and buying material for them.
Carbon film tracks on pots would also explain the randomness of fuel gauges, but with 4 LED's (What they want), it's anyone's guess where it actually is.
PostPosted: 15:14 - 29 Dec 2016    Post subject: Reply with quote
It wouldn't be too hard a project to make an accurate fuel gauge - read the sender value with an Arduino (or PIC of choice), then output a corrected value to the display (gauge/LEDs/screen/whatever).
weasley
PostPosted: 15:34 - 29 Dec 2016    Post subject: Reply with quote
Do the bikes in question already have fuel gauges? I only ask as I looked at the possibility of adding a fuel gauge to mine (rather than just a low level warning) and the difficult bit is adding a level sensor/sender.
ThatDippyTwat
PostPosted: 16:17 - 29 Dec 2016    Post subject: Reply with quote
The YBR will have a working system, the kids bike is on the road and used daily. It'll be no problem to measure that.
The others are all without clocks, hence me being asked to do some custom ones. I've shown them everything from full digital race systems to cheapy Chinese, and they want none of them.
I'm not going to argue if I'm being paid for it, but I don't want to say "yeah, sure" and then realise I cant do a fuel gauge. I would assume they have senders of some type in them already.
WD Forte
PostPosted: 17:31 - 29 Dec 2016    Post subject: Reply with quote
Older cheaper gauges I've come across usually worked on current.
Both temp and fuel gauge used this in opposite ways
The sender as a variable resistor where as the float drops, resistance lowers or rises ( usually in a non linear way)
and the increased/decreased current in the clock distorts a bimetal strip acting on the needle.
Early K series used a god awful thyristor array circuit where the only effect of this complexity was a light to warn you at low fuel levels
Voltage based gauges were basically expanded scale voltmeters
again with variable resistors in the tank
Out of interest and wondering if it could be done without drilling holes in tanks ( Nooooooooo!)
I did once make a gauge for my CX based on the slight pressure differences between full empty tanks read between tap and carb.
It worked !
MKI was a bit too sensitive and suffered from the slooshing about as the bike was ridden of course, so MKII had damping to smooth this out which helped.
By MkIII I was going to use a microcontroller to read and average the readings, but I'd lost interest by then
bikers smell of wee
ThatDippyTwat
PostPosted: 17:45 - 29 Dec 2016    Post subject: Reply with quote
If I was going to do one from scratch, a flex sensor attached to a float sounds about right. Even a basic PIC or Arduino should have plenty of oomph to display it on whatever you choose.
PostPosted: 20:16 - 29 Dec 2016    Post subject: Reply with quote
If I could trust the local scum to leave it alone, I'd like to steampunk the Enfield with some brass/glass arrangement :-
https://s-media-cache-ak0.pinimg.com/736x/75/05/b6/7505b6b61d28c26a1086601b9ae4be94.jpg
andym
PostPosted: 20:33 - 29 Dec 2016    Post subject: Reply with quote
Why not have something like this:
https://i.imgur.com/9CIKPwS.jpg
What could possibly go wrong?
NutsyUk
PostPosted: 14:04 - 30 Dec 2016    Post subject: Reply with quote
WELL... Thats a firery death just waiting to happen....
On my lexmoto I think its Volt, the divider built into the anilogue gauge is a beefy divider with high wattage.
On my Speedo Project its a volt meter, but to get an accurate reading you have to first set the low and high fuel points and the program then extrapolates levels.
The trouble is a volt meter without a voltage reference is unreliable as the mains voltage can fluctuate.
So in your project youll want to make a formula that reads the reference and put it against the reading on the input.
As for that formula... I can let you know. When i work it out myself Very Happy Im not at that bit of my project yet.
Yamaha FZ8/Fazer800 (split headlight one) 2014, gingerly getting used to the massive increase in HP and not killing myself in the process! That was easy to get used to.
Kawasaki ER6F 2007 650 Gonna sell as a project bike!
Lexmoto XTR S 125 Sold!
PostPosted: 18:30 - 30 Dec 2016    Post subject: Reply with quote
Screw a formula, sodding about with float arm angle in an irregular container shape - just start with an empty tank, and record the reading after adding a litre each time, stick it in an array.
ThatDippyTwat
PostPosted: 18:36 - 30 Dec 2016    Post subject: Reply with quote
That ^^^^^
Empty tank, 1 trimmer per led, fill it by one "segment" and adjust the trimmer accordingly. Trimmers aren't exactly expensive, and it's a one-time calibration.
I'll regulate the line to 12v, and bung in something like an LM339 (per 4 LED's), and bob's your mothers brother.
Just waiting on parts now, I'll mock the fuel gauge up. I have a spare sender with the same resistance range.
WD Forte
PostPosted: 18:58 - 30 Dec 2016    Post subject: Reply with quote
The bimetal (current)type gauges have the built in advantage of reacting slowy
to current/heat changes which damps out the effect of the float bobbing about when riding.
Most use a regulator of around 7-8V as well
If you're going to read/display a voltage alone I doubt you'll get steady readings
bikers smell of wee
ThatDippyTwat
PostPosted: 20:04 - 30 Dec 2016    Post subject: Reply with quote
Once we've proven the principle, we're going to put it on his Lads YBR first. That'a a standard 8-10/390-400ohm sender as far as I can determine, so we'll prototype based on that. I could pop it all on a µC via a voltage divider and "damp" the input, but it's massive overkill really. If sloshing is really problematic, we'll do that.
I have a few µ's and Comparator's kicking around the house, just waiting on pots really.
NutsyUk
PostPosted: 22:02 - 30 Dec 2016    Post subject: Reply with quote
ahh fair do's if your making it just for your bike... on my project im building it as if its going to be a universal jobby...
Sure its not going to be 100% accurate but as you said irregular tank and float.
I noticed at least on my tank theres about a 6th of a tank left when the fuel float is at empty position and when at full theres still a good 2 6ths left to go on my tank.
As for filtering out the noisy volt read wth a float bobbing about... You take several readings... Say 10 or 20. Then average them out. Should filter most of the noise out.
Its how im doing the RPM reading. Adding a sample to an array and periodically add up and divide the results
ThatDippyTwat
PostPosted: 23:02 - 30 Dec 2016    Post subject: Reply with quote
Not my bike, but they will be one-off's. He's got a very specific idea of what he wants, and his lad likes the idea of it as well, so he's being the Guinea Pig.
NutsyUk
PostPosted: 13:13 - 31 Dec 2016    Post subject: Reply with quote
heh
Im currently putting together a lightbox and UV exposure box... but I must admit i really want to get back on with my project... Ive not touched it in a couple of weeks.
PostPosted: 14:06 - 31 Dec 2016    Post subject: Reply with quote
The sender is a variable resistor so in it's simplest form the gauge and sender form part of a voltage splitter circuit.
Looking at an old Fazer wiring schematic that seems to be the case, as the meter has only power and ground then a third wire goes through the sender to ground. With the float level high, resistance across the sender is low so the gauge gets more volts. As the fuel level drops resistance at the sender increases and gauge voltage reduces giving you a lower reading.
Usually sender resistance is very non-linear, presumably because the sender swings through a progressively wider arc as the fuel level drops. When the tank is full, taking out an inch of fuel level will cause the float to drop an inch. When the tank is near empty however, taking out an inch of fuel can cause several inches swing of the float arm. How well this is accounted for in the design will determine how accurate the gauge is.
ThatDippyTwat
PostPosted: 15:40 - 31 Dec 2016    Post subject: Reply with quote
I appreciate it's non-linear, which is why I'll be putting a trimmer on each line, so it can be adjusted to suit actual, real-world levels. There's not point in uber accuracy, 4 LED's can only display with an accuracy of 12.5% anyway, but a linear response is needed.
NutsyUk
PostPosted: 16:06 - 31 Dec 2016    Post subject: Reply with quote
*cough sneezes and farts...
https://www.ebay.co.uk/itm/2-52mm-Fuel-Meter-LED-Digital-Display-Fuel-Gauge-For-Car-Motorcycle-DC12V-/201388391024?hash=item2ee3aefa70:g:Rw8AAOSwQItUGm~7
I mean sure its not making it yourself but, given the price it might be worth buying one and taking it apart to see what its doing as well...
PostPosted: 16:27 - 31 Dec 2016    Post subject: Reply with quote
Fill tank to brim, ride 100 miles, fill tank to brim. Divide miles by litres used then multiply by tank capacity. This will give your full-tank range. Reset trip meter every time you fill up.
ThatDippyTwat
PostPosted: 16:42 - 31 Dec 2016    Post subject: Reply with quote
They said they had a look online for weeks, and saw nothing they like, and they're specific with what they want. They're paying for it, so who am I to argue? If they want 4 LED's, they get 4 LED's.
The last post was made 9 years, 269 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.13 Sec - Server Load: 0.45 - MySQL Queries: 16 - Page Size: 130.87 Kb
