| Snod Blatter |
 Snod Blatter Crazy Courier
 Posted: 13:03 - 29 Dec 2016 Post subject: Stainless brake pistons - Anyone lived with them? |
My CB250 needs some new brake pistons, the originals are pitted and nasty and will do new seals no good at all. Looking around I seem to have two choices, either OE style (coated mild steel, at a guess) pistons from David Silver or I can fit some aftermarket stainless pistons for slightly more money.
Other than the obvious "will it fit" gamble on aftermarket parts, stainless sounds like a stupid idea because they'll surely cause mad levels of galvanic corrosion when nestled inside a large lump of aluminium. And yet, a lot of people seem happy with them.. But I'm yet to see anyone report on how they fared after several years of salty all weather abuse.
So, has anyone tested stainless pistons long term? ____________________ 1994 CB250, 1984 CBX250RS-E, 1989 K100RS, 1995 TRX850, 2016 Z250SL |
 Posted: 13:07 - 29 Dec 2016 Post subject: |
Pure theory because I've never used them but they don't actually touch the alloy do they? So what completes the cell?
Would stainless be electrochemically any worse than the mild steel of the brake pad backing? ____________________ “Rule one: Always stick around for one more drink. That's when things happen. That's when you find out everything you want to know.”
| Snod Blatter |
 Posted: 13:22 - 29 Dec 2016 Post subject: |
As I understand it, the galvanic series states that the further apart two metals are in the series, such as this list, the more potential there is for corrosion to take place. As you can see, aluminium and steel are quite close to each other near the bottom of the list, while any kind of stainless steel is much further away.
But this is for in sea water, I guess where galvanic corrosion is of serious concern. Occasionally we may see salty water on the roads but it's not long term.. But how long does it take to be of concern to us?
And water full of caliper-related ions completes the cell. Is that close to sea water anyway in this case? I dunno. ____________________ 1994 CB250, 1984 CBX250RS-E, 1989 K100RS, 1995 TRX850, 2016 Z250SL |
| Teflon-Mike |
 Posted: 14:29 - 29 Dec 2016 Post subject: |
I've had'em in the 750 for the last decade... I have not been an autoglym freak, whilst the ting lives outside, and I am only 'now' thinking of pulling them off and giving them a dab of coppa grease on the float pins... and wondering whether I dare look, 'cos they have only just, this last month started to get a bit 'sticky', since last strip and grease 3 years ago!
Slugs seem 'fine'. ____________________ My Webby'Tef's-tQ, loads of stuff about my bikes, my Land-Rovers, and the stuff I do with them!
| sickpup |
 sickpup Old Timer
| Teflon-Mike |
| Polarbear |
 Polarbear Super Spammer
 Posted: 10:04 - 30 Dec 2016 Post subject: Re: Stainless brake pistons - Anyone lived with them? |
| Snod Blatter wrote: | My CB250 needs some new brake pistons, the originals are pitted and nasty and will do new seals no good at all. Looking around I seem to have two choices, either OE style (coated mild steel, at a guess) pistons from David Silver or I can fit some aftermarket stainless pistons for slightly more money.
So, has anyone tested stainless pistons long term? |
What do you call long term and how old are the pistons in your bike now?
If they have been in ther since the bike has been built then just fit the OEMs from Silvers. They will probably outlast the bike. ____________________ Victory Cross Country American tractor. |
| Bru |
 Bru Trackday Trickster
 Posted: 11:40 - 30 Dec 2016 Post subject: |
Hi.
I fitted OEM pistons to my Honda, from DS, as part of a rebuild several years ago. The bike was not used much, over a couple of years, and one of the pistons subsequently began to corrode around the seal lip area. I had to replace the stuck piston again, but this time I went for stainless.
I have also had stainless pistons fitted to another bike, which has pretty much also stood for two years. The brakes are not seized.
I think that if the bike is used, and maintained, regularly then the pistons will last longer: a combination of scrubbing action and heat to keep moisture at bay (assuming the fluid is in reasonable condition).
My experience points me to stainless as a replacement, rather than OEM.
[I did find that the pistons I bought had machining which resulted in a rougher surface finish of the sealing area, compared to the fine-ground finish of the chromed originals. Still, no failure recorded to date.]
Aside from my musings, the issue of conductivity of brake fluid is quite an interesting subject. There are plenty of published documents online, should you wish to learn more. |
| Snod Blatter |
 Posted: 12:45 - 30 Dec 2016 Post subject: Re: Stainless brake pistons - Anyone lived with them? |
| Polarbear wrote: | What do you call long term and how old are the pistons in your bike now?
If they have been in ther since the bike has been built then just fit the OEMs from Silvers. They will probably outlast the bike. |
I'm looking for about 5 years of all year round all weather riding, ideally. 3 years would do.
The pistons that are in there now, I don't really know as it's a replacement item off a CBR400 NC29. I think it had done about 20K when I bought it, and it has since done another 20K under me. The pistons have degraded quite a lot in that time but they may have been polished up for sale, I don't know. The original caliper lasted to about 60K when fluid started getting past the pistons and seals, so I junked it. These Nissin calipers are quite common, perhaps I should just find yet another replacement..! Though I do like the snazzy gold one I have now
Bru - many thanks for your experience, but this bike will hopefully not be laid up for any length of time. This is my main mode of transport.. The conductivity of brake fluid though? What can of worms is this..
Tef - thanks for keeping it short It does seem that stainless pistons perform better in real life than the science would suggest, but there's always the niggle that no brake manufacturer ever uses stainless pistons. At least not to my knowledge. There are murmurings that Yamaha blue/silver spots are stainless but no actual facts. ____________________ 1994 CB250, 1984 CBX250RS-E, 1989 K100RS, 1995 TRX850, 2016 Z250SL |
| Robby |
 Robby Dirty Old Man
| Snod Blatter |
 Posted: 13:13 - 30 Dec 2016 Post subject: |
I'm in there every 12-18 months cleaning out behind the seals. The dust seals on these Nissins are near useless. But then the Brembos on the front of the TRX and the Sumitomo on the rear are just as eager to gum up.. If only a manufacturer would dare have the imagination to use a TLS hydraulic drum
Considering Brembo and now Yamaha with their gold spots use pistons made of coated aluminium you'd have to guess that the hardness of the material isn't that important. Now, if someone in the aftermarket was making pistons like those I'd be all over them, they're lovely. ____________________ 1994 CB250, 1984 CBX250RS-E, 1989 K100RS, 1995 TRX850, 2016 Z250SL |
| c_dug |
 c_dug Super Spammer
| Islander |
 Islander World Chat Champion
 Posted: 18:24 - 30 Dec 2016 Post subject: |
I fitted a set to the Zephyr 750 about 6 years ago and they've been fine. The only slight problem I had when fitting them was the inner bore was too narrow for the inserts. That was simple to fix - I just ground the inserts down a bit.
I've seen no corrosion with them at all.  |
| sickpup |
 sickpup Old Timer
| Teflon-Mike |
 Posted: 13:35 - 01 Jan 2017 Post subject: |
| sickpup wrote: | the question stands, whats the mileage? |
Oh OK Pup... mileage is unrecorded... I'll just go hop in the Deloean, go back to 2005, and tell myself to note it when I popped the pistons in, and fix the oddo so it gets recorded, and I can come back to now, and give you the answer you want...
Because of course, how often the brakes are applied, how hard and for how long is absolutely proportional to miles covered and THE most significant factors in what makes them corrode, isn't it?  ____________________ My Webby'Tef's-tQ, loads of stuff about my bikes, my Land-Rovers, and the stuff I do with them!
| stevo as b4 |
 Posted: 14:14 - 01 Jan 2017 Post subject: |
Is it me being fucking simple here, or are people going far to deep into this and getting way too frothed up about brake caliper metallurgy and materials selection and design.
Surely your not all racing, or building ultra light custom built specials. OP seems an ok bloke, but is way too deep into discussing brake piston coatings, surface treatments, and materials properties, especially considering how often he says he's in there cleaning out his calipers and removing seals etc?
I just don't see why It really matters, it's not like your discussing how much cam shaft lift and overlap to use in a race engine build is it?
On my ZX6R I did 9500miles in 5years some wet some dry, but it never saw a winter or salt. I used to clean the calipers with brake cleaner and mini bottle brushes, but I never had to strip the allegedly awful Tokico 6pots, and with good sintered pads they were a brilliant brake tbh! |
| sievuun |
 sievuun Two Stroke Sniffer
 Posted: 18:22 - 01 Jan 2017 Post subject: |
Stainless steel brake pistons are absolute no problems in my experience. Some of mine are more than 30 years old, done more than 250.000km driving all year. The standard pistons may seize after first winter and can not go back in when they are corroded. Stainless steel items may seize too but after much longer service and then you just clean them and put them back in for 5 or 10 years more. I made mine myself, but buy them if you have the choice and want to keep your bike more than a year. I prefer to buy new rubber parts if available but the pistons will last the rest of your life. ____________________ BMW: R50/5 R80GS R90/6+sidecar R90S R100RS R100RS+s.c K100RT+s.c K1100RS IFA: RT125/2 DKW: RT125/3 MZ: ES150/1 TS250/1+s.c ETZ250A ETZ250+s.c Kawasaki: GPZ750
Once had: R51/3, CB350four, CB350K4,XS1100 XS1100S+s.c,XT250, XV500, Z550, GT550triple, TS150/1, TS250, ETZ251 saxon tour |
| Snod Blatter |
 Posted: 19:51 - 01 Jan 2017 Post subject: |
| stevo as b4 wrote: | I just don't see why It really matters, it's not like your discussing how much cam shaft lift and overlap to use in a race engine build is it? |
Err no, it's a long-term never looked after road machine used in all weathers instead. That's kind of the point of this..
| stevo as b4 wrote: | On my ZX6R I did 9500miles in 5years some wet some dry, but it never saw a winter or salt. |
Then can you kindly leave this thread?
sievuun - many thanks. Everyone who has used stainless pistons seems to be really happy with them, and I'm actually surprised that no one has had an issue with the fit of them or fluid leaking past or whatever. You are right about the original steel pistons though, they do "grow" and knacker up the seals. Stainless is supposed to pit instead which sounds bad for keeping the fluid in, have you never seen this?
Tef - don't feed the trolls  ____________________ 1994 CB250, 1984 CBX250RS-E, 1989 K100RS, 1995 TRX850, 2016 Z250SL |
| smegballs |
 smegballs World Chat Champion
 Posted: 20:46 - 01 Jan 2017 Post subject: |
I put stainless piston in back in 2014 with plenty of RRG. Pulled the caliper apart back in june just to check everything was ok and regrease the sliding pins.
There was a little bit of superficial muck that was literally just wiped off with a rag, but apart from that the only change in 2 years was the the RRG was now brown-rubber-grease.
It was all clean enough that I didn't even need to push the piston out far at all, so the dust seal had obviously done it's job well. So two years (including two winters) without attention and the whole thing was still perfectly fine.
Re: Pitting
https://i.imgur.com/yExEHASl.jpg
https://i.imgur.com/TG5vXG1l.jpg
My OEM piston looked like this when I took it out, pretty pitted IMO |
| sickpup |
 sickpup Old Timer
| kramdra |
 kramdra World Chat Champion
The last post was made 9 years, 260 days ago. Instead of replying here, would creating a new thread be more useful? |
