Is 60 miles per day on a 125cc Motorcycle doable?
Bike Chat Forums Index -> General Bike Chat Goto page Previous  1, 2, 3  Next
ZX-7R This post is not being displayed because the poster is banned. Unhide this post / all posts.
pompousporcup...
PostPosted: 12:35 - 04 Jan 2017    Post subject: Reply with quote
gpz500 is what i'm using 110+ miles a day, mainly motorway. Serviceables are cheaper than the 600 bikes and if i stuff it, whilst heartbroken i'd be, it wouldn't cost a big chunk of my salary to replace. Thumbs Up
200 miles to a tank is doable for sure. I put fuel in at 180 miles into a tank as to not drag the crap in the tank through to the carbs. Whilst the engines look the same as the ER500.. they're not the same. Different cams and timing make it a much more enjoyable bike IMO. They're quick enough and will sit at 70-80 without much issue
el_oso
PostPosted: 13:10 - 04 Jan 2017    Post subject: Reply with quote
if you swapped the 12miles of dual carriageway for 12miles through central then I'd say yes. Not many people used to pass me on the 125 through central London and virtually no one passes me on the 250. I really like little bikes but when half the journey is on long fast straight roads then there are more suitable machines. If the right varadero popped up locally for the right money, then I'd consider it. Otherwise I'd be looking at fazer.
Duke 390
Car: Jeep Wrangler 4.0L
kgm
PostPosted: 14:13 - 04 Jan 2017    Post subject: Reply with quote
I agree with going bigger bike. I love my 125 and it's ideal for my current commute and running about in winter but for those miles it would be shit. Certainly do-able, and I would if I had to, but I don't so I won't. There are plenty of bigger bikes about for very little money these day so I also agree the best way forward is to set a max budget and see what's available within a reasonable distance. I do a gumtree search like that regularly just in case an interesting bargain crops up. Always very tempted (recently a nice VFR750 that went for a pittance) but I need to finish my CX500 rebuild first.
Azoth
PostPosted: 14:33 - 04 Jan 2017    Post subject: Reply with quote
It depends how old you are. I went into a clothes store the other day and saw a young woman who worked in there running across the floor area and up the 2 flights of stairs to the mens department. Not exactly an athletic feat, but still a brief exertion of effort to change the intensity of her rhythm. My immediate reaction was surprise, because she probably had 4 more hours on her feet before her shift ended, and, in any case, I would never run for any employer no matter how 'urgently' my presence was needed. Not now, anyway. When I was in my 20s I did. But then, everything seemed exciting and new and about to give way to better things.
That said, I have done a significant commuting distance (albeit quite a bit shorter than 30 miles each way) a few times on a 125 last winter. It wasn't any fun at all, because of rush hour, the cold, the high concentration needed to deal with road surface and other traffic, etc. I arrived slightly tired, as if I'd been out running, while everyone who had commuted by car was barely awake. When it was time to go home, the journey felt much longer, and I was already rueing having to do the same journey the next day! Basically, 125s are no fun for that commuting distance. It would be great if they were, because they cost much less to run. A big difference from your CBR.
As Tef says, it depends how hardy you are, which in turn depends on how hardy you want to be.
Safety in numbers
tsmith
PostPosted: 21:49 - 07 Jan 2017    Post subject: Reply with quote
used to commute 90 miles a day on my GPZ500 and in the Winter on snowy/icy/frosty roads these tyres were a godsend:
https://en.reifenwerk-heidenau.com/modules/reifenliste/view.php?lang=en&point=5&rtyp=17&profil=102&pic=59
temeluchus
PostPosted: 06:12 - 08 Jan 2017    Post subject: Reply with quote
All 600s are equally expensive to service now?
PostPosted: 10:15 - 08 Jan 2017    Post subject: Reply with quote
2002 CBR600f
Almost not worth claiming for. If they write it off your policy will be cancelled so you'll end up with loss of NCD, loading for several years AND stumping up for another policy right away to get back on the road, with extra loadings included.
Cancel the claim, fix with ebay bits, ride it as a rat. Keep your NCD and save doubling your premium for the next 2 years and the money the bike is still worth as a rat when re-sold coupled with the premium/NCD savings will all add up to more than you'll get paid out most likely.
Jim Mc
PostPosted: 10:22 - 08 Jan 2017    Post subject: Reply with quote
The bike will cope easily with that distance. My cbr125 was very comfortable and fun, more so than a bigger bike I found as it screams everywhere you go and you learn the lines of the road so you don't lose speed on corners to make your commute as efficient as possible. You will probably need to fuel up every day though and as you probably realise overtaking is dodgy.
redeem ouzzer
PostPosted: 10:41 - 08 Jan 2017    Post subject: Reply with quote
Laughing Laughing Laughing
Be a REAL MAN!
PostPosted: 12:29 - 08 Jan 2017    Post subject: Reply with quote
For the best results you should do what Pete say and don't do what Jim Mc says. Wink
myvision
PostPosted: 12:42 - 08 Jan 2017    Post subject: Reply with quote
Pete. wrote:
2002 CBR600f
Is the bloke who owns the parked car he hit claiming though?
VFR800FI, YZF600R Thundercat and FZS 1000
PostPosted: 12:56 - 08 Jan 2017    Post subject: Reply with quote
Missed that tucked-away detail. The OP says he 'came off' not smashed into a parked car. It does complicate it somewhat.
steve_
PostPosted: 17:07 - 09 Jan 2017    Post subject: Reply with quote
Small update for anyone who's interested!
I took a '96 Virago 535 out and it felt like what I'd imagined a 125cc would feel like so that shuts the door on that chapter!
I'm going to see a Bandit 650s which I think I will end up having.
My insurance company have offered me £1,875 for my 2002 CBR 600F. (on Auto trader they go for about £2,200. And they've said that I can buy it back for £600 which I think I'll do. I've been speaking to a company who say they might be able to straighten my forks for £150 if not they will make me a new set for £250. The CBR will then become my "Frosty road day bike"!
Thanks for all the tips.
PostPosted: 17:15 - 09 Jan 2017    Post subject: Reply with quote
Send them links to the ads on biketrader you've found to get them to increase their offer. Thumbs Up
PostPosted: 17:19 - 09 Jan 2017    Post subject: Reply with quote
Buy-back seems high. I'd counter that and suggest 25% at the most. I bought one for 10%.
steve_
PostPosted: 18:13 - 09 Jan 2017    Post subject: Reply with quote
Will do. I just read an article that says they must offer you a sum that will allow you to buy a like-for-like in a similar condition in your local area. All the insurer should deduct is the excess you agreed to when taking the policy.
Is it possible to check the condition of a wheel via photos?
Would someone mind telling me if they think this front wheel is any good?
Thanks.
https://www.ebay.co.uk/itm/HONDA-CBR-600-F-SPORT-F4i-FS1-FS2-2001-2003-FRONT-REAR-WHEELS-/162341443660?hash=item25cc4dd84c:g:2MQAAOSwAuZX2tyl
kramdra
PostPosted: 22:54 - 09 Jan 2017    Post subject: Reply with quote
Dont do this. Replacement forks are cheap, I doubt 14 year old chrome plating will be much good after.
PostPosted: 11:14 - 10 Jan 2017    Post subject: Reply with quote
It feels like they're getting fly to owners turning a profit on write-offs.
However, I'd be surprised if they're being offered £600 for it by a salvage outfit if it's got both mechanical and cosmetic damage, so sure, treat their offers as their opening position.
PostPosted: 13:21 - 10 Jan 2017    Post subject: Reply with quote
I don't know is what the usual deal is but I bet it's a token amount if anything at all. If you have to collect, store and dispose of a bike and deal with paperwork plus potential liabilities even 600 doesn't go very far.
Alpineandy
PostPosted: 14:32 - 10 Jan 2017    Post subject: Reply with quote
The 535 isn't a great bike (pretty poor bike actually) but has multiples more torque than a 125 so would have been a better option than a 125 by some way for that type of journey.
You're much wiser to look at a 600 or keep your old bike (at the right price).
The above comment isn't necessarily the truth and anyone that says it is, is only correct if it's the truth or they're bigger than me.
steve_
PostPosted: 15:14 - 10 Jan 2017    Post subject: Reply with quote
I just spoke to them again and they are not budging on the price!
They are saying that because mine is on 61k they minus £15 per 1k miles, and that the "advertised prices" that I'm seeing on biketrader and MCN for other 2002's are not necessarily the "sold prices" and may be more because they include extras like warranties ect!
PostPosted: 15:35 - 10 Jan 2017    Post subject: Reply with quote
60K? The closest I can find on eBay is a 2001 with 52,000 miles that closed at £1290. A 46,000 mileer 2002 was asking £1250.
I think their offer is fine, it's the £600 cost to you to retain the bike that's hooky. Maybe they have got a salvage monkey ready to hand over that to them (plus any extra costs), but I'd doubt it, not at that mileage with that damage.
If they won't budge, I'd be mildly minded to take the offered money, invite them to collect their bike (feel free to remove any extras first) then buy something fresher. It's a toss-up though, you're still £1275 up and could spend some of that sorting your CBR.
steve_
PostPosted: 15:40 - 10 Jan 2017    Post subject: Reply with quote
I found a couple of 2002's going cheap, but they are both cat c.
What do you think a reasonable buy back price is?
Thanks.
PostPosted: 16:31 - 10 Jan 2017    Post subject: Reply with quote
I'd want to pay them at most £400.
https://www.ebay.co.uk/itm/351882498870 = rekt 2001, £430
https://www.ebay.co.uk/itm/302141276533 = nice 2002, £820
Both with fewer miles than yours.
Those are the retail prices, not what the salvage outfit paid for them. If they paid £600 to the insurer then they got rinsed on the first and probably didn't turn a profit on the second either.
The last post was made 7 years, 109 days ago. Instead of replying here, would creating a new thread be more useful?
Page 2 of 3
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.10 Sec - Server Load: 0.36 - MySQL Queries: 17 - Page Size: 140.05 Kb
