How to change halogen bulbs
PostPosted: 10:29 - 08 Jan 2017    Post subject: How to change halogen bulbs Reply with quote
I know I need to hand in my man card, but I'm stumped.
Any ideas how to change the bulb on these types of recessed halogen lights?
https://www.solihulllighting.direct/wp-content/uploads/2016/08/5619_Kamo12v_FireRated-600x600.jpg
White plate doesn't seem to twist off, and the rest of the assembly is up in the ceiling and won't fit through the hole.
andyscooter
PostPosted: 10:32 - 08 Jan 2017    Post subject: Reply with quote
they ysed to have brass ones in my local that popped off if you got a small screw driver behind them you could then get to the bulb
PostPosted: 10:35 - 08 Jan 2017    Post subject: Reply with quote
So the front plate pops off? I didn't want to hang off it as I didn't want to bugger the fixture or make a big hole in my ceiling.
redeem ouzzer
Usually held into the ceiling by spring clips. You'll need to lever under the bezel evenly to pop it out. The effort required will be determined by the size of the hole. If it's on the small size it'll be a twat. Once you drop the unit it down on it's wires all will become clear.
Be a REAL MAN!
331X2
PostPosted: 19:11 - 08 Jan 2017    Post subject: Reply with quote
If its an IP rated one (bathroom?) then the bezel will twist off with the lamp held into it. If you give it a straight pull down the whole fitting will pull down as mentioned above but will probably take some of the ceiling plaster with it.
Try pressing your flat palm on it and twisting anti clockwise rather than trying to grip with your finger tips.
PostPosted: 19:26 - 08 Jan 2017    Post subject: Reply with quote
Not clear from the pic if there is glass over the end of the fitting or just the face of the bulb itself.
If it's the bulb itself, you just need a sucker thingy.
mudcow007
PostPosted: 12:02 - 09 Jan 2017    Post subject: Reply with quote
pull down slightly on the "white" ring an unscrew it. the bulb will more than likely be held within this white bit/ lens
replace bulb an refit in reverse
UncleFester
PostPosted: 15:33 - 09 Jan 2017    Post subject: Reply with quote
This.
That metal round collar should rotate and unscrew off and then you can get at the LAMP behind it.
2017 Z1000SX
UncleFester
PostPosted: 15:36 - 09 Jan 2017    Post subject: Reply with quote
If won't - tap the metal ring gently with something to get the thread moving.
2017 Z1000SX
t121anf
PostPosted: 16:32 - 09 Jan 2017    Post subject: Reply with quote
Our bathroom ones you literally just pull out of the ceiling. Get your nails between the fitting and the ceiling and start to pull, the clips begin to compress and it pops down.
Our porch ones are like others have said and have cir-clip holding the lamp in place, remove and the lamp drops out.
angryjonny
PostPosted: 16:54 - 09 Jan 2017    Post subject: Reply with quote
My kitchen ones (LED in a halogen type fiitting) you just twist the bulb itself to unclip it from the light unit, reverse the process to insert a new one. They're a sort-of bayonet fitting.
Other halogen bulbs just fit via pins and can be pulled out.
As people have said, there may just be a spring clip holding the light unit into the recess - stick a credit card or something under each side and pull down - see if there's any give.
The last post was made 9 years, 29 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.06 Sec - Server Load: 1.27 - MySQL Queries: 16 - Page Size: 71.64 Kb
