Loose cap?
mudcow007
PostPosted: 09:53 - 12 Jan 2017    Post subject: Loose cap? Reply with quote
Been struggling to find the cause of my Bandit's rough running in the rain.
Checked loom/ wiring/ connectors - no obvious signs of damage (got wd40'd anyway)
Poked around in the drain holes - seemed dry
On the way in this morning it started to misbehave, so i gave the bike a shake an it fixed itself.
So I stopped an prodded an poked an found No.2 plug is looser than a smack heads morals...... Shocked
I'm guessing when it gets wet its shorting to the head?
Looking inside the plug there looks to be a spring/ clip/ what-cha-maflip - is there anything I can do, or is it a case of just replacing the cap(s)
tom_e
PostPosted: 10:21 - 12 Jan 2017    Post subject: Reply with quote
What's actually loose? You flip between it being the plug and the cap.
I take it you mean the cap on the end of the HT lead that fits over the spark plug is loose?
PostPosted: 10:33 - 12 Jan 2017    Post subject: Reply with quote
Unless it's simply down to a missing screw top on the plug (which I don't think the bandit usually has anyway) then it's probably new plug cap time.
mudcow007
PostPosted: 10:49 - 12 Jan 2017    Post subject: Reply with quote
Sorry, I mean the cap.
Looks like Bandit's use specific caps as the generic NGK's are too short Thumbs Down
Will have a look on Robinson's
cheers all
LongJohn22
PostPosted: 20:11 - 12 Jan 2017    Post subject: Reply with quote
Probably not a bad idea to replace all at the same time if you want to ensure reliability.
The last post was made 7 years, 105 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.05 Sec - Server Load: 0.54 - MySQL Queries: 17 - Page Size: 49.39 Kb
