Author |
scotto75 |
scotto75 Renault 5 Driver
Back to top |
scotto75 |
Back to top |
jaffa90 |
jaffa90 World Chat Champion
Back to top |
bypass2 |
bypass2 Spanner Monkey
Back to top |
scotto75 |
Back to top |
SixFeetOfMan |
SixFeetOfMan L Plate Warrior
Back to top |
bypass2 |
Back to top |
scotto75 |
Back to top |
smallfrowne |
smallfrowne Scooby Slapper
Posted: 12:23 - 11 Jan 2017 Post subject: |
If the wiring is all ok, connectors, switches, dodgy earths, etc then maybe it's the stator's ignition coil that is bad. Coils can go bad when hot (currently have a very similar issue with a CD250U) and since you've changed the coil pack I'd have a look at the stator.
It might look black and crusty, but maybe not if it's intermittent. Not sure about testing it with a multimeter, I've not got that far with mine yet, so not sure on 'OK' resistance values, but worth a go checking values when its firing ok against when it isn't.
My CG, when it was on points, had the lighting coils fail on the stator. I had no lights but it carried on running to get me home (in the dark ).
I still have that stator kicking about (nearly threw it out last night). It obviously has bad lighting coils, but the ignition coil worked. Bit of a faff swapping stators about but you can have it for postage if you want to try it. ____________________ '90 VFR750; '89 NC30; '95 DR650; '89 CD250U; ~'82 CG125; ~C90 |
Back to top |
scotto75 |
Back to top |
smallfrowne |
Posted: 21:24 - 11 Jan 2017 Post subject: |
Right, that took more time than I thought - since I forgot where I put it, doh, only just 'tidied' it away as well - at least it wasn't actually in the bin (I checked )
This look right?
https://i.imgur.com/MdPbp96l.jpg
Snakes wedding - lollers. Any luck? ____________________ '90 VFR750; '89 NC30; '95 DR650; '89 CD250U; ~'82 CG125; ~C90 |
Back to top |
SixFeetOfMan |
Back to top |
scotto75 |
Back to top |
jaffa90 |
Back to top |
scotto75 |
Back to top |
smallfrowne |
Posted: 00:38 - 13 Jan 2017 Post subject: |
I will sleep soundly tonight. Good stuff ____________________ '90 VFR750; '89 NC30; '95 DR650; '89 CD250U; ~'82 CG125; ~C90 |
Back to top |
The last post was made 7 years, 104 days ago. Instead of replying here, would creating a new thread be more useful? |
