Author |
robertw95 |
robertw95 Trackday Trickster
Back to top |
craigT19 |
craigT19 Jolly Green Giant
Posted: 15:24 - 14 Jan 2017 Post subject: |
Personally i like time-serts but you cant always use them due to material thickness, a helli coil will probably be fine too. ____________________ Bikes owned :- 2001 nsr125, 1999 zx6r, 2006 yzf-r1, 2009 xmax 250, 2012 yzf-r1, 2015 MT-07
Current bike : - 2016 MT-10
BCF member pops. sadly missed 1945-2003
Back to top |
ThatDippyTwat |
ThatDippyTwat World Chat Champion
Back to top |
robertw95 |
Back to top |
G |
G The Voice of Reason
Back to top |
robertw95 |
Back to top |
stinkwheel |
Back to top |
ThatDippyTwat |
Back to top |
G |
Back to top |
robertw95 |
Back to top |
Ed Case |
Ed Case World Chat Champion
Back to top |
robertw95 |
Back to top |
331X2 |
331X2 Crazy Courier
Posted: 22:15 - 14 Jan 2017 Post subject: |
I've just received some E-Z LOK inserts to repair a previously hashed thread repair in an engine I'm rebuilding. The benefit of these is that they use standard taps on the outside of the insert so you haven't got to drop >£100 on a Big Sert kit, I paid £25 to the door for five M8 inserts which requires a 10.4mm drill bit and an M12x1.75 tap.
They came from here if you wanted to have a look, they also sell Time Sert and Big Sert kits for comparison. No link to seller etc... |
Back to top |
robertw95 |
Back to top |
Rogerborg |
Rogerborg nimbA
Back to top |
Pete. |
Pete. Super Spammer
Posted: 13:22 - 15 Jan 2017 Post subject: |
Without seeing the offending object it's hard to say how I would approach this but from reading I think I would first have a look to see how much access there is through the sump, and if it's enough I would probably make a pull-stud similar to wheel nut studs, turn a shoulder on the base to locate in the now over-sized hole and the rest would be normal sized with a nyloc nut on top. ____________________ a.k.a 'Geri'
132.9mph off and walked away. Gear is good, gear is good, gear is very very good |
Back to top |
robertw95 |
Back to top |
The last post was made 7 years, 114 days ago. Instead of replying here, would creating a new thread be more useful? |
