Put dry chain lube on the bike...
Waaarrrggghhh
PostPosted: 18:20 - 16 Jan 2017    Post subject: Put dry chain lube on the bike... Reply with quote
Was this a bad idea? Apparently dry lube is not good for wet/rainy conditions.
Or am I stressing out over nothing? I used Muc Off dry lube, it was really cheap compared to standard wet lube which is what I was using previously.
Can I just spray the wet lube on or do I have to clean the dry one off first?
Howling Terror
PostPosted: 18:34 - 16 Jan 2017    Post subject: Reply with quote
Yes to all your questions. Thumbs Up
Waaarrrggghhh
PostPosted: 18:40 - 16 Jan 2017    Post subject: Reply with quote
Which questions? The sentences in my post comprised of one question, followed by another that was asking the opposite.
Howling Terror
PostPosted: 18:46 - 16 Jan 2017    Post subject: Reply with quote
Thankyou for waiting. Your call is important to us.
You're lubing the chain and that's enough for most people. Any lube is better than no lube.
Wet lube is the preferred option so next time you clean it use that.
[Call terminated] Reason - Overuse of word 'lube'.
Waaarrrggghhh
PostPosted: 19:30 - 16 Jan 2017    Post subject: Reply with quote
Wow just realised its actually a wax lube, is that good or bad?
ThatDippyTwat
PostPosted: 19:39 - 16 Jan 2017    Post subject: Reply with quote
Just keep an eye on it, clean and lube if it gets shitty and/or dry.
I use wax lube. It's fine, just make sure you keep the chain lubed, no matter what lube your using.
RhynoCZ
PostPosted: 21:08 - 16 Jan 2017    Post subject: Reply with quote
Dry lube has got to be applied on a brand-new/clean low mileage chain only. It even says so on the can, I do believe. It's not as good lubricant as the wet lube. But it's perfectly alright for the on tarmac use. Do NOT use dry lube on off-road motorcycles.
It is no different to the wet alternative. Lube it every 350-450km, or after a wet run. One thing, when you apply the dry lube, always let it dry on the chain before you ride it.
skatefreak
PostPosted: 23:36 - 16 Jan 2017    Post subject: Reply with quote
Apply it after riding the bike as the chain will still be warm and the wax will melt and run into all the gaps in the chain Thumbs Up
arry
PostPosted: 01:07 - 17 Jan 2017    Post subject: Reply with quote
Stop panicking. It's fine.
PostPosted: 11:15 - 17 Jan 2017    Post subject: Reply with quote
How warm?
Everybody repeats this truism, but I've yet to see anyone measuring temperatures or comparing them to the melting point of the lube.
skatefreak
PostPosted: 11:21 - 17 Jan 2017    Post subject: Reply with quote
Admittedly I only suggest this as it's what I do with my track bike...
Road going hack just get's a splash of its last oil change now and then Rolling Eyes
The last post was made 7 years, 101 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 0.81 - MySQL Queries: 17 - Page Size: 71.96 Kb
