Author |
Dadams9876 |
Dadams9876 L Plate Warrior
Back to top |
jaffa90 |
jaffa90 World Chat Champion
Back to top |
Dadams9876 |
Back to top |
jaffa90 |
Back to top |
smallfrowne |
smallfrowne Scooby Slapper
Posted: 15:16 - 20 Jan 2017 Post subject: |
Forgive me, stupid question, but are all the bulbs def 6v ones and not 12v? Also are the bulbs in the clock the right ones? ie 6v and low wattage ~3W? I've seen you can get 30W clock bulbs, which would make your speedo glow nicely but would sap the juice from elsewhere - and there really is no extra capacity from the little stator.
There is no reg/reg on it, just a diode that stops one side of the AC from getting to the battery, making it DC. But the battery only runs the horn and brake light, oh and the (daytime) indicators, lights are all AC.
When you get the multimeter don't forget to check running voltage - with a few revs on. Haynes is deffo your friend. Check it with lights on, lights off. Also try disconnecting the resistor that lives under the headlight bowl on the fork bottom if the voltage is really low, maybe that is somehow sapping power. Maybe.
It could well be the stator. I doubt it'd be the flywheel as that is just a bunch of magnets BUT I do have a spare one I could part with. If it's knackered you should be able to tell because the magnets will break apart/have signs of breakage - I think that's the only way it can actually be knackered. They are very brittle and once they start to break up they've had it. Come to think of it, you probably can't tell without removing the plates that hold the magnets on - DON'T DO THIS I TELLS YE!! Unless it really is the last thing you can possibly check, and I'll sell you a flywheel for £50 (you can mop up the tears with said fifty note before you give it me if you want, I won't mind).
Good luck, multimeter will be your best pal now.
PS I have a nice wiring diagram on another thread... lemme know if you need it. ____________________ '90 VFR750; '89 NC30; '95 DR650; '89 CD250U; ~'82 CG125; ~C90 |
Back to top |
Petemate |
Petemate Trackday Trickster
Back to top |
neptune8 |
neptune8 Nova Slayer
Posted: 15:42 - 20 Jan 2017 Post subject: |
It is unlikely to be the flywheel/ magnets that are faulty. Get hold of a Haines manual for your bike, which will include a wiring diagram, and details of how to test the stator with a multimeter. Test stator before removing or renewing it. As suggested, your bike likely has a 6 volt system, and 12 volt bulbs will not work. Test battery voltage with engine not running. Should be at least 6.4 volts. with engine running at about 5,000 rpm, voltage should rise to around 7 volts. No voltage rise equals, no charge. Not charging could be caused by faulty stator, flywheel, rectifier, wiring or rectifier. Rectifier on 6 volt CG125 is a simple two terminal job, easily tested with a multimeter. If battey voltage is low, recharge it using a proper motorcycle 6 volt charger, not a car battery charger. Haines manual may be available online. ____________________ Enjoy yourself, its later than you think |
Back to top |
smallfrowne |
Back to top |
jaffa90 |
Posted: 18:24 - 20 Jan 2017 Post subject: |
Image result for honda cg125E wiring diagram,
[img][/img]Image result for honda cg125E wiring diagram
[url][/url]
"""PS I have a nice wiring diagram on another thread... lemme know if you need it."""""
Lets have a look small frowne it must be different to mine. |
Back to top |
Tamsin |
Tamsin World Chat Champion
Back to top |
smallfrowne |
Posted: 21:51 - 20 Jan 2017 Post subject: |
Here's the diagram I use. Sorry it's not all coloured in, I was only interested in half the diagram at the time (a 6v points to 12v cdi conversion).
https://imgur.com/igNs4Pal.jpg
Click for big.
It's same as above really but quite clear I think. ____________________ '90 VFR750; '89 NC30; '95 DR650; '89 CD250U; ~'82 CG125; ~C90 |
Back to top |
chris-red |
Posted: 21:59 - 20 Jan 2017 Post subject: |
6v electrics are shit, charge/replace the battery and invest in some halogen bulbs is about all you can do.
You could go through the loom ensuring every connection is clean and makes good contact too.
With my RXS the indicators would only flash if the engine was reving or the lights off.
I got mine from here.
https://www.norbsa02.freeuk.com/goffybulbs.htm ____________________ Well, you know what they say. If you want to save the world, you have to push a few old ladies down the stairs.
Back to top |
jaffa90 |
Back to top |
smallfrowne |
Posted: 23:42 - 20 Jan 2017 Post subject: |
Yeah, sorry, it does have a rectifier, but that's just a single diode it is an old cg diagram i think it lacks the resister that is in series with the pilot bulb but otherwise it's the one. (i have a cgE and it mostly matched this diagram)
Hmm also I have some unused, untouched 6v halogen bulbs going spare actually. Infact i have a spare rectifier diode too if anyone needs one.. ____________________ '90 VFR750; '89 NC30; '95 DR650; '89 CD250U; ~'82 CG125; ~C90 |
Back to top |
Commuter_Tim |
Posted: 23:52 - 20 Jan 2017 Post subject: |
Too drunk to read the helpful peoples replies, but I did have the same experience as you OP.
Can't help with the electrical fault, but even if you fix it, the headlight will still be pissweak.
The headlight being dependant on revs isn't likely to go away entirely either.
My 1998 12v CG had dangerously underpowered headlights.
I just chucked a KREE lamp on the handlebars.
https://www.themarysue.com/wp-content/uploads/2014/02/Kree-Military-Uniforms-2.jpg https://i.ebayimg.com/00/s/NTAwWDUwMA==/z/h04AAOxy4dNS-pYv/$_3.JPG?set_id=2
Routed the cable to a battery pack I velcro on and off to the sissy bars.
Job Jobbed, you can blind anyone you like and light up the road to eternity.
You can also literally melt the skin off your fingertip if you touch the lamp after a long ride. ____________________ The above post is most likely nonsensical.
I ride a Bandit 600... badly. |
Back to top |
The last post was made 7 years, 96 days ago. Instead of replying here, would creating a new thread be more useful? |
