Stupid N00b question VFR800
mrmistoffelee...
PostPosted: 14:55 - 16 Feb 2017    Post subject: Stupid N00b question VFR800 Reply with quote
Hi all,
My new to me VFR800 (2002) has got a flat(Ish) battery. Got it a couple of weeks ago and suspect it was put on a booster to get it going, got it home and it went into the garage and I haven't ridden it since due to other commitments. Tried this morning and it's sluggish trying to turn over.
So, I managed to get the seat off
Found I think where the - terminal is
Cannot for the life of me work out where the + terminal is so i can attach the clips for the optimiser.
Can someone help a novice out please?
Thanks in advance
tom_e
PostPosted: 15:00 - 16 Feb 2017    Post subject: Reply with quote
Both terminals will be on top of the battery at opposite edges surely Confused I don't think I've ever seen a setup where they hide one of the terminals somewhere else.
Is the + one covered with a rubber boot to remind you to disconnect that one last?
Evil Hans
PostPosted: 15:02 - 16 Feb 2017    Post subject: Reply with quote
Find a picture online of the battery for your bike, then work it out from there?
Triumph Sprint ST 1050. And it's Red.
mrmistoffelee...
PostPosted: 15:11 - 16 Feb 2017    Post subject: Reply with quote
Picture attached
negative is terminal with grease across the top...
jaffa90
PostPosted: 15:17 - 16 Feb 2017    Post subject: Reply with quote
I can only see half off the battery.
Evil Hans
PostPosted: 15:34 - 16 Feb 2017    Post subject: Reply with quote
I'm guessing that +ve is somewhere off the top of that pic, under the cover.
mrmistoffelee...
Sorted, the positive terminal is located under a plastic trim piece which needs to be removed from the side of the bike.
Thanks everyone for input
oouche
hi it looks like the two metal tags to the right of battery terminal is a link or solenoid the tag nearest the battery is from the battery + and the other one is to the starter if the optimiser is like most smart chargers it will have polarity and overload protection so its unlikely you could do any damage trying it
ADSrox0r
PostPosted: 18:58 - 16 Feb 2017    Post subject: Reply with quote
As you've already found, it's under the irritating trim piece that you'll fiddle about with for ages popping it back in......every...fucking....time.
Current bikes: '08 VFR 800 VTEC(yo) , '07 ZZR1400 Winter hack: '95 Aprilia 650 Pegaso Currently lusting after: RC30
mrmistoffelee...
PostPosted: 19:23 - 16 Feb 2017    Post subject: Reply with quote
What a STUPID FUCKING LOCATION !!!!!
I'm going to connect the optimiser leads to the battery this weekend and the cable tie the other connector somewhere.
jjdugen
PostPosted: 19:31 - 16 Feb 2017    Post subject: Reply with quote
In B4 reg/rec.
mrmistoffelee...
PostPosted: 19:34 - 16 Feb 2017    Post subject: Reply with quote
jjdugen wrote:
In B4 reg/rec.
What is? Do you mean regulator? best not be or the shop will be replacing it quick smart any other symptoms to look for?
PostPosted: 20:18 - 16 Feb 2017    Post subject: Reply with quote
mrmistoffelees wrote:
jjdugen wrote:
In B4 reg/rec.
Quick and dirty. Start the bike, turn on the headlight. If it gets brighter as you rev up from tickover, the charging system is broadly ok.
More scientific. Voltmeter across battery. Volts should rise with revs up to the region of 15v or so, no higher.
Even better. Ammeter. Watch current flowing into the battery.
Hondas of that era are known for iffy reg/rec units.
ADSrox0r
PostPosted: 20:29 - 16 Feb 2017    Post subject: Reply with quote
stinkwheel wrote:
Hondas of that era
To be fair, just about every diode r/r Honda ever used were and still are shit.
mrmistoffelee...
PostPosted: 12:05 - 19 Feb 2017    Post subject: Reply with quote
So, the bike has been on the optimiser a few days, went out last night and it started sweet as a nut. Reattached the optimiser closed garage door went to sleep.
Went out this morning sluggish but started, took it out for a good twenty mile blast, pulled onto drive at home turned engine off. Tried to start again, dead as dodo.
TL:DR place i bought it from are going to get a very arsey phone call on Tuesday, have also noticed the heatshield is loose so they can get that sorted as well
Whilst 3k on a bike isnt a lot of money to some people for a bike. It's a lot for me.
Rather pissed off at the moment.
jjdugen
PostPosted: 12:21 - 19 Feb 2017    Post subject: Reply with quote
He he Bet I'm right!
PostPosted: 12:34 - 19 Feb 2017    Post subject: Reply with quote
ADSrox0r wrote:
stinkwheel wrote:
Hondas of that era
Dunno. The superdream ones were about the best you could get when they first came out. All the magazines carried articles about how to retro-fit them to your suzuki (many of which at the time were using an unpotted bridge rectifier and mechanical regulator).
The last post was made 7 years, 119 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.09 Sec - Server Load: 0.29 - MySQL Queries: 16 - Page Size: 96.4 Kb
