Author |
Yorkshire Geek |
Yorkshire Geek Scooby Slapper
Back to top |
kerr |
kerr World Chat Champion
Back to top |
tony_d123 |
tony_d123 Nitrous Nuisance
Back to top |
grr666 |
grr666 Super Spammer
Posted: 11:31 - 26 Feb 2017 Post subject: |
Do you know what way they run? I'd start by figuring that out, or you may make a 100 holes and not hit one.
Go upstairs and lift a bit of carpet somewhere and see what way the floorboards run, the joists will run the opposite way.
This way you can at least you drill your holes along the correct wall.
Use Gyproc easi-fill to make good any unnecessary exploratory holes. ____________________ Currently enjoying products from Ford, Mazda and Yamaha
Ste wrote: Avatars are fine, it's signatures that need turning off. |
Back to top |
Freddyfruitba... |
Freddyfruitba... World Chat Champion
Back to top |
iooi |
iooi Super Spammer
Back to top |
ScaredyCat |
ScaredyCat World Chat Champion
Back to top |
Yorkshire Geek |
Back to top |
BTTD |
BTTD World Chat Champion
Back to top |
chris-red |
Back to top |
stinkwheel |
Posted: 18:05 - 28 Feb 2017 Post subject: |
Worth mentioning that while convention and common sense dictates wiring and pipework should be either in a notch on top of a joist or running through a hole in the centre of them, it could be a serious error to assume this is definately the case.
Take this from someone who drilled into the rising main while fitting battens for a suspended ceiling. Said rising main turned out to have been shoved up into a notch on the underside of the joist then had the plasterboard for the ceiling fixed below it to stop it dropping out again.
Thankfuly, it's an old house so there is a lot of redundancy in the joist thickness. ____________________ “Rule one: Always stick around for one more drink. That's when things happen. That's when you find out everything you want to know.”
Back to top |
chris-red |
Posted: 17:34 - 01 Mar 2017 Post subject: |
I've got a few joists that have been significantly drilled through(50%+), to put up spot lights. I'm just trying not to think about it ____________________ Well, you know what they say. If you want to save the world, you have to push a few old ladies down the stairs.
WANTED:- Fujinon (Fuji) M42 (Screw on) lenses, let me know if you have anything. |
Back to top |
ADSrox0r |
ADSrox0r World Chat Champion
Back to top |
The last post was made 7 years, 57 days ago. Instead of replying here, would creating a new thread be more useful? |
