Author |
fatporker |
fatporker L Plate Warrior
Back to top |
defblade |
defblade World Chat Champion
Posted: 07:47 - 17 Mar 2017 Post subject: |
Passive tailgaters (ie ones who don't know they're doing it, just never look further than 6 feet past their bonnet) you can't do anything about as such, just double your space to the vehicle in front and brake gently so they have time to react. Or pull in and let them past.
Aggressive tailgaters will simply overtake you when you're on a bike, even if you're already at the speed limit, and even if there's no proper room to do so - this goes double while you're on L plates. ____________________ Honda Varadero 125cc => Suzuki Bandit 650 33bhp => 77bhp =>
BMW K1200R Sport 163bhp => Aprilia Shiver GT 750 95bhp |
Back to top |
Rogerborg |
Rogerborg nimbA
Posted: 09:11 - 17 Mar 2017 Post subject: |
Riding well out towards the RHS of your lane helps, but as with cycling it won't stop it altogether if you're anywhere near the speed limit.
It does wind me up no end, which is why you did the right thing by pulling over. The sooner the better, before you get the red mist on. I have stopped once to remonstrate with a particularly bad culprit, which in hindsight was a mistake. Luckily (for me) he was a codger, and just shrank behind the wheel.
The worst oblivious offenders are geezers and tarts. Candidates for doing it deliberately are Audi- and White-Van-Man, so that they can spend longer stuck at the next set of lights.
I agree with ditching the L plates at the earliest opportunity. As a bit of an aside, are you aware that if you've passed your bike theory, there's nothing stopping you booking a module 1 test on your own 125? It won't get you closer to a full A license, but it's only £15.50 to do it under real conditions on a bike that's less capable than the 600cc+ that you'll use for your real bite at it. That's a bargain to familiarise yourself with the test and work through any nerves.
Oh, and enjoy the obligatory rant from Teflon-Mike when he shows up. Don't read too much into it - he won't actually have read what you wrote either. ____________________ Biking is 1/20th as dangerous as horse riding.
Back to top |
fatporker |
Back to top |
arry |
arry Super Spammer
Back to top |
Holdawayt |
Holdawayt Trackday Trickster
Back to top |
fatporker |
Posted: 09:49 - 17 Mar 2017 Post subject: |
____________________ CBT Done Theory Done ... Now for the rest of it |
Back to top |
Rogerborg |
Rogerborg nimbA
Back to top |
Andy_Pagin |
Andy_Pagin World Chat Champion
Posted: 10:16 - 17 Mar 2017 Post subject: |
arry wrote: | I'll tend to do 25-35-25-35; again same thing, they'll get close and then realise you're changing speed a lot of the time, and decide it's more hassle than it's worth to be up your chuff. | Same here, though I doubt they 'decide it's more hassle', more like the sheer pain of actually having to think is too much, so they drop back and return to a comfortable vegetative state. ____________________ They're coming to take me away, ho-ho, hee-hee, ha-haaa, hey-hey,
Yamaha Vity -> YBR125 -> FZS600 Fazer -> FZ1-S Fazer |
Back to top |
fatporker |
Back to top |
Andy_Pagin |
Back to top |
Teflon-Mike |
Posted: 10:53 - 17 Mar 2017 Post subject: |
Stock answer & Extras: Tail-Gaters - Back-Off Salient extract:
you are riding a vehicle, probably less than half the length of a car; there is NOT very much bike behind you to begin with, and that is likely to make it seem that anything in the mirror is closer to your number-plate than it possibly actually is. More so if you are an existing car driver... used to, what? An extra ten feet of metal, between where you are sat and your rear number-plate?
Large vehicles? Vans in particular. They are tall and wide, and FILL the rear-view mirrors, even if they aren't actually all that close; the wind-screen is also almost at the front of the vehicle; big exectutive or conventional saloon car? There's probably five foot of bonnet stuck out in front of the driver... and THAT is what you subconsciously look for; we are genetically programmed to seek 'faces' in any scene we look at.
But point is, these things can conspire to exaggerate, our perception of how close a following vehicle is, and significantly add to our over-estimation of the risk they actually pose!
So STOP staring in the mirror; don't obsess on them.
Long term car drivers are notorious for a lot of car driver habits, that include mirror dependency, assessing 'risk' emotionally not rationally, and even more hugely exaggerating the gulf between real risk and perceived risk based on the 'sensation' they have, on a bike, in direct contact with their surroundings, sat over an engine, not isolated and insulated from the world around them by a sitting-room on wheels.
It's quite normal; BUT, its as likely and probably more so, that it is YOUR notions of what's going on and who's more in the wrong that are 'wrong' than other traffic, at the moment.
Worth a thunk... when you are next driving the car... just check how often you are following the two-second-rule... then ponder your ideas, as a car driver, how close is close.... THEN.. 30mph is 15m/s, so normal following distance aught to be 30m or 100 foot.... park bike on the road outside your house, and then get in the car and try park that far from the bike... using just the scale of the bike as a guide... then measure it... I will lay odds that you will park probably half that distance away, and you'll get out and STILL think "That's huge!" Then go get on the bike, and look in the mirrors at the car, and see how close that 'huge' gap looks when you are sat on the saddle.
However, do have to congratulate you for pulling over, "Get-Off; Get-Safe; Start-Over" it is something so many are loath to do, and will escalate problems trying to 'make' tailgater back off, or trying to get ahead, and not actually deal with the problem. ____________________ My Webby'Tef's-tQ, loads of stuff about my bikes, my Land-Rovers, and the stuff I do with them!
Back to top |
Pjay |
Pjay World Chat Champion
Posted: 11:20 - 17 Mar 2017 Post subject: |
Teflon-Mike wrote: | Stock answer & Extras: Tail-Gaters - Back-Off Salient extract:
However, do have to congratulate you for pulling over, "Get-Off; Get-Safe; Start-Over" it is something so many are loath to do, and will escalate problems trying to 'make' tailgater back off, or trying to get ahead, and not actually deal with the problem. |
Where is Tef, and what have you done with him? |
Back to top |
Baggyman |
Baggyman Crazy Courier
Back to top |
Rogerborg |
Rogerborg nimbA
Back to top |
The last post was made 7 years, 40 days ago. Instead of replying here, would creating a new thread be more useful? |
