Garden path bricks moving
mudcow007
PostPosted: 12:56 - 17 Mar 2017    Post subject: Garden path bricks moving Reply with quote
a few years ago i laid down a bricked garden path to our front door -
where the path goes past the front door and ends - the bricks at the very end (of the path) dislodge/ wobble an fall off
I have tried cementing them in, which sticks em for a bit but then come loose again
Is there anything special that i should have done with these last bricks
I prob havent explained it very well - will take a pic tonight if needed?
Hawkeye1250FA
PostPosted: 13:25 - 17 Mar 2017    Post subject: Re: Garden path bricks moving Reply with quote
I think it comes down to the quality (or lack of) the border bricks. These go in first and you build the internals of the path second.
Cement / mortar seems your only option now other than rip it up and lay it again with a deeper foundation?
PostPosted: 14:25 - 17 Mar 2017    Post subject: Reply with quote
The path just ends against, what, soil?
Got some spare bricks? I'd be minded to lift the last row (or two) and re-lay them on-end, i.e. half buried in the ground.
doggone
PostPosted: 14:29 - 17 Mar 2017    Post subject: Reply with quote
They should be set against a deeper foundation pad/kerb of concrete ideally, however something like an old sleeper or long kerbstone would probably be almost as good for the life of the path and could just be dug in and set the end bricks directly against it.
You might try a substantial flag stone or two at the end.
Some soil types move a surprising amount as they get wet and dry even without traffic pressure.
mudcow007
PostPosted: 15:05 - 17 Mar 2017    Post subject: Reply with quote
Its a bit hard to explain, but the house/ garden is on a slope, so the path is flat, but the ground runs away from it to the side of the house, only by about 6-8"
I have then put slate chippings up to the path to make up the difference - obviously the chippings arnt meant to be supportive or anything
Photo is prob easier
ScaredyCat
PostPosted: 15:14 - 17 Mar 2017    Post subject: Reply with quote
I put down some slabs in my garden so I could get my bike up the hill of after any rain without digging a massive rut.
I cut out the slab shape from the grass dug down about 1/2" and used small stones (B&Q sell bags of them) to half fill the hole. Then I put the slabs on top of those and jumped up and down on the slabs. Lifed the slabs up and then filled in any gaps with more little stones. No cement, nada. They haven't moved an inch and I ride up and down them, pretty much, every day..
Sounds like the bed for your path isn't very flat/stable. fill it with stones.
Honda CBF125 ➝ NC700X
Honda CBF125 ↳ Speed Triple
mudcow007
PostPosted: 22:42 - 29 Mar 2017    Post subject: Reply with quote
sorry forgot to update - now sorted.
I sunk a plank of oak (work in a place that produces oak furniture) hard up against where the path ended then re cemented the bricks back in
jobs a good un
ta Thumbs Up
The last post was made 7 years, 28 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.11 Sec - Server Load: 1.21 - MySQL Queries: 17 - Page Size: 54.91 Kb
