2000 Yammie R6 - yeah, you guessed it, gearbox issues
MistreKul
PostPosted: 11:35 - 17 Mar 2017    Post subject: 2000 Yammie R6 - yeah, you guessed it, gearbox issues Reply with quote
Well, I recently bought a '00 R6 in pretty good condition, original paint, no mods and all that and for a pretty decent price. I've been told it's been sitting for a while and was in need of a good service so I didn't give it a proper trashing when I bought it. Besides, I always had the bad habit of trusting the wrong people (which makes up 90% of the population) and took his word for good when he said the bike was fine from all points of view. Bike started and ran really sweet, engine sounds absolutely spot on, really quiet, fairings looked pretty good for its age it made a very good impression
Now that I've done the service, I took it out for a more enthusiastic spin and discovered that when I accelerate harder and change from 1st to 2nd, it "clunks" pretty hard and the shift lever kinda kicks back 2-3 times before engaging 2nd. Like it doesn't want to engage 2nd and wants to go back to neutral, I guess. It doesn't jump into neutral, but kicks back 2-3 times and engages the gear. Once engaged, it's fine. The rest of the gears are fine, no kicking.
Am I right in thinking this is the beginning of the end of the gearbox? The much dreaded 2nd gear issue with these bikes? And if so, what are my options? The bike is pretty sweet otherwise and I wouldn't like to have to sell it (at a loss, since I'm not a complete scum like the previous owner and I'd have to mention that the gearbox has some probs). I've heard I could swap 2nd and 6th cogs with the '03-'05 R6's for a definitive fix, apparently they fit perfectly. What would you recomend, gents?
This is the culprit:
https://i832.photobucket.com/albums/zz242/mistreku/WP_20170311_12_54_49_Pro_zpsojinerzr.jpg
Cheers,
Gab
jaffa90
PostPosted: 11:57 - 17 Mar 2017    Post subject: Reply with quote
At 17 years old i would live with it and change to second sooner.
I take it that you put motorcycle oil in it!
PostPosted: 12:06 - 17 Mar 2017    Post subject: Re: 2000 Yammie R6 - yeah, you guessed it, gearbox issues Reply with quote
Cheers,
Gab
I thought it was the dogs that go not the cogs? I've seen people put the entire gearbox from an 03-05 R6 in. I think that is the definitive fix.
If you are reasonably mechanical, and the thought of dropping the engine doesn't terrify you, you should be able to do it yourself. You don't have to touch the top end IIRC. If you aren't A mechanic would likely charge a small fortune to do this.
I have no first hand experience with this so take everything I've said with a pinch of salt.
MistreKul
PostPosted: 12:55 - 17 Mar 2017    Post subject: Reply with quote
You are correct, it is the dogs but I think you can't replace them on their own, they seem to be cast as one piece with the cog. I might be wrong, hopefully someone more savvy will chip in.
I'm fairly skilled with the spanners but don't know much about bikes. However, considering my budget, I think I'll have to learn about them soon! Laughing
PostPosted: 13:18 - 17 Mar 2017    Post subject: Reply with quote
I don't know if it is something that can be repaired, welded then reshaped? It might be worth seeing. I'd get on an R6 forum they will have countless threads of the subject.
Edit
The cogs are /only/ £60ea +vat, for the 2004 model new from yamaha. might as well go with that!
groovylee
PostPosted: 13:19 - 17 Mar 2017    Post subject: Reply with quote
if you do facebook, join the r6 owners page. BUT.... stand by for the onslaught of liner jokes...
you know about those yeah? if not, get reading so you know the symptoms.
anyway, the recommended fix is to stick the 03 on 5sl gearbox in it. end of problems.
one other thing to check first would be the detent spring. google should throuw up some results. its a few quid part and might make the difference between neawer gearbox or not.
nice bike btw Thumbs Up
Past - 1988 honda revere 600, 1996 kawasaki gpz500s, 1999 Yamaha R6
Current - 2002 Aprilia RSV1000R & 1999 Kawasaki ZX6R
jjdugen
PostPosted: 13:20 - 17 Mar 2017    Post subject: Reply with quote
And then you can start worrying about the cylinder liners splitting.......
Edit... Drat, got there before me.
groovylee
PostPosted: 13:21 - 17 Mar 2017    Post subject: Reply with quote
oh, and as i found out, don't clutchless change from 1st to 2nd.
MistreKul
PostPosted: 15:05 - 17 Mar 2017    Post subject: Reply with quote
Cheers for the tip on the '03 cogs Chris, was not aware they are that cheap, someone told me they were double that, 60 quid really isn't bad at all. I did post this on R6-forum as well, funny enough, no replies so far. Perhaps they moved on from the 99-02 series.
Groovy, just send a request to join the FB group, I can deal with the jokes, no problem. The engine really doesn't worry me at all atm, it runs and sounds really sweet. It's this bloody gearbox which grinds my gears right now. Pun intended. But you have planted the seed of terror for the liners issue in the back of my mind, I'm sure I'll read a lot of horror stories about it later, thank you very much! Laughing
JJ, I never shifted clutchless in any bike owned or ridden so far, I'm sure I will be able to refrain from it in the future as well, especially on such a sensitive gearbox. It seems like you can only pick two out of "pretty, reliable and cheap".
Jaffa, I put Motul 7100 10w50, defo bike spec. I can't live it that gearbox though, I really like this bike and want it to work properly.
Now, a little update. My throttle cables are a bit sticky and unless I roll the throttle back myself, it will keep the revs a little bit higher in the range (not too high, maybe 2000-2500RPMs). I noticed that if I focus on rolling the throttle back between the shifts, the shifter will kick back a lot less, if at all. Just shifts into 2nd quite smoothly. Especially if I delay the shift half a second. Not sure if this means anything, but thought I'd mention it.
I will have a look at that detente spring and see if I can see anything wrong with it. Basically, what do I need to check for, spring wise? Certain tension, lenght or just visible wear?
Cheers everyone for the input, much appreciated! Thumbs Up
Copycat73
PostPosted: 18:37 - 17 Mar 2017    Post subject: Reply with quote
try askin here .. and there wont be the piss takin either..
https://www.yamahar.co.uk/index.php
caveat emptor
PostPosted: 18:43 - 17 Mar 2017    Post subject: Reply with quote
www.r6messagenet.com is the bestest R6 forum. Wink
How much did you pay for the bike?
groovylee
PostPosted: 20:33 - 17 Mar 2017    Post subject: Reply with quote
from what I can make out, the forums are piss poor, and the FB page is the best way of getting help or answers.
PostPosted: 20:42 - 17 Mar 2017    Post subject: Reply with quote
Bull honkey!!
R6 Messagenet isn't piss poor. Razz
Copycat73
PostPosted: 20:53 - 17 Mar 2017    Post subject: Reply with quote
au contraire mon ami.
caveat emptor
groovylee
PostPosted: 21:29 - 17 Mar 2017    Post subject: Reply with quote
really? R6messagenet - 9 most recent posts - going back to mid February..... 5 replies in total. hardly a hive of activity is it.
or am I missing something? Confused
Copycat73
PostPosted: 11:56 - 18 Mar 2017    Post subject: Reply with quote
4 pages in 4 days
caveat emptor
MistreKul
PostPosted: 19:21 - 18 Mar 2017    Post subject: Reply with quote
I think I'm gonna have to live with it for now and save some money for the 5SL gearbox, for a stronger fix. We'll see. I don't want to drop too much money in it, despite really loving this bike, it seems to be riddled with issues like the gearbox or liners. I'll keep you guys updated, for now, I'll just try to keep it as is.
The last post was made 9 years, 69 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.10 Sec - Server Load: 0.46 - MySQL Queries: 16 - Page Size: 101.93 Kb
