Author |
RickTaff |
RickTaff Nitrous Nuisance
Back to top |
Hahadumball |
Hahadumball World Chat Champion
Back to top |
Polarbear |
Polarbear Super Spammer
Back to top |
stinkwheel |
Posted: 21:18 - 15 Mar 2017 Post subject: |
Does look very much like there is an inner bearing race stuck on the end nearest the camera.
If you fitted the new one, presumably you removed the old one? How did that go? Normally the centre race is pretty important in that process so you ought to have noticed its absence at some point in proceedings (the shower of loose ball bearings when you removed that spacer would have been the first clue). ____________________ “Rule one: Always stick around for one more drink. That's when things happen. That's when you find out everything you want to know.”
Back to top |
Chris45 |
Chris45 Nitrous Nuisance
Back to top |
Pete. |
Posted: 21:29 - 15 Mar 2017 Post subject: |
It won't fit through the new bearing because the inner race of the old bearing is still on it.
The near end in the picture - that wider bit with the smooth groove running round it is part of the old bearing. You have to knock the tube out of that and then it will fit into the new bearing. ____________________ a.k.a 'Geri'
Back to top |
RickTaff |
Back to top |
RickTaff |
Back to top |
kgm |
kgm World Chat Champion
Back to top |
RickTaff |
Back to top |
Robby |
Robby Dirty Old Man
Back to top |
Pete. |
Posted: 14:00 - 16 Mar 2017 Post subject: |
I think it's right. Tube spacer plugs into carrier bearing for ease of assembly and buts again wheel bearing to provide axial force for clamping.
No need to freeze it, won't help anyway coz both parts are steel. Hold the tube lightly in a vice with the bearing hub on top and knock the tube it with a hammer and socket. Don't muller the hole.
To re-fit lay the new bearing on a flat surface and tap the tube in until it seats. ____________________ a.k.a 'Geri'
Back to top |
Baggyman |
Baggyman Crazy Courier
Back to top |
RickTaff |
Back to top |
The last post was made 7 years, 38 days ago. Instead of replying here, would creating a new thread be more useful? |
