Author |
liladams1 |
liladams1 Borekit Bruiser
Back to top |
Paulf |
Paulf Nova Slayer
Back to top |
liladams1 |
Back to top |
jaffa90 |
jaffa90 World Chat Champion
Back to top |
liladams1 |
Back to top |
liladams1 |
Back to top |
Paulf |
Paulf Nova Slayer
Back to top |
jaffa90 |
Posted: 02:11 - 22 Mar 2017 Post subject: |
Paulf wrote: | Low compression worn piston ring, valve not closing, valve seats, head gasket, cracked head, worn bore, etc
Compression test warm engine if possible, insert compression tester, open throttle all the way and crank engine. The maximum is reached in 4-7 secs. Compression pressure 14 bar or 199 psi ( figure from honda workshop manual honda fes 125).
Repeat this time with a spoon of oil 55mls if the figures are greater suggest the rings or bore are worn. No change head problems gasket, valves or crack in head. |
Well stated, better than i did. |
Back to top |
liladams1 |
Back to top |
The last post was made 7 years, 35 days ago. Instead of replying here, would creating a new thread be more useful? |
