daverave999 Trackday Trickster
Posted: 13:16 - 21 Mar 2017 Post subject: Versys instrument cluster intermittent |
I'm becoming a bit stumped with this one, but don't want to assume straight away that it needs replacing as that's expensive...
2007 Versys instrument cluster. Example (not mine) image here.
LED backlight still works, indicator, neutral, oil lights still come on, but no LED segments. I have no speedo, clock or fuel gauge. The analogue tachometer also moves to new position, but just stays in that place.
I wondered if some water had got in so I've had the connector off and it is absolutely pristine. Put some WD40 on it anyway, and either side where the wires connect.
Charging is at correct voltage so it's not been damaged by that.
Anything else to try before it goes to the garage? TIA ____________________ 2007 Versys 650 2001 Yamaha XJ600S Diversion
HT: Imagine a bike......A bike designed by way of crude polls, assembled by cretins using the finest hammers that Lidl had on offer. |
