Releasing agent
matlow
PostPosted: 13:35 - 20 Mar 2017    Post subject: Releasing agent Reply with quote
Do tyre manufacturers still use a releasing agent as part of the process? used a ride in ride out service yesterday, when I left the garage it was wetter than a virgin at a Bieber concert. I was stunned by how much grip I had from the off. tyres are PR4's so I was expecting good wet grip but not straight out of the box.
so does anyone know if releasing agents are still used? or was it some quirk of the gods and the wet roads that made them so instantly usable.
Hornet 600, CBR600F, 929 blade, 07 R1, R1200GS, 09 Blade, 750 SRAD, ZZR1200, 954 Blade, KTM 990 Adventure, Ducati 749s
P.
PostPosted: 13:39 - 20 Mar 2017    Post subject: Reply with quote
People say yes, people say no. Just ride it as you normally do and don't give it 10000000% until tyre is sufficiently warm.
It'll be down to people giving beans when cold.
PostPosted: 13:52 - 20 Mar 2017    Post subject: Reply with quote
Some manufacturers use it, but not very many nowadays. The issue is the surface of the rubber is smooth so water forms a fine layer, like aquaplaning I guess. You do need to take it easy but you might find that the new rubber is better than the old rubber just because the old tyres were completely dead.
Take it easy for a hundred miles or so, and then check the chicken strips etc. If it still has some, build up lean slowly. If you've already managed to get your elbow down, you can ride with impunity.
chickenstrip
PostPosted: 14:09 - 20 Mar 2017    Post subject: Reply with quote
Avoiding using great handfuls of throttle seems to me to be the more important thing on brand new tyres, rather than lean angles. With PRs, as soon as I've used the full width of the tyre, I pretty much consider them scrubbed. It usually takes me less than a day out on the bike to do it, 50 miles or so on some good twisty roads seems to be ample. I always give the tyres a couple of miles to warm up a bit before pushing things too hard though.
PostPosted: 14:12 - 20 Mar 2017    Post subject: Reply with quote
You know what that begs, right?
owl
PostPosted: 14:21 - 20 Mar 2017    Post subject: Reply with quote
when I had the roadtec 01's fitted the guy said they didn't need much scrubbing, it was raining when I left the workshop and they felt fine once they got up to temp, way more grippy than the rosso II's that were on before
Observation is the greatest source of wisdom.
goto10
PostPosted: 14:51 - 20 Mar 2017    Post subject: Reply with quote
https://i.imgur.com/WNubOAU.gif
PostPosted: 15:48 - 20 Mar 2017    Post subject: Reply with quote
There was an article in a copy of Performance Bikes that I recycled a few months back... it basically said that only one manufacturer they contacted still uses releasing agent in their motorcycle tyre moulds, and it wasn't a very well known one.
I don't think I still have the mag (as I said I'm pretty sure I put it out for recycling) but unfortunately I can't seem to find an equivalent article or citation on the internet after my 20 seconds of Googling.
Matt B
PostPosted: 15:59 - 20 Mar 2017    Post subject: Reply with quote
Most manufacturers use a mould that does not require release agents nowadays. Citation:
Continental Tyres wrote:
Once curing has taken place, the tyres are removed from the mould. With our Traction Skin Technology, we are able to remove the tyre from the mould without the use of a releasing agent.
https://www.conti-bike.co.uk/how-is-a-motorcycle-tyre-made/
Like Marjay said, there is (or was) one manufacturer still doing it. tyres are smooth and shiny because the mould is smooth in order to release the tyre, it's not a coating.
t121anf
PostPosted: 20:10 - 20 Mar 2017    Post subject: Reply with quote
Old thread but brand responses.
https://www.gixxer.com/forums/33-general-bike-talk/176572-new-tire-mold-release-fact-fiction.html
notabikeranym...
Formerly known as
meef
PostPosted: 21:45 - 20 Mar 2017    Post subject: Reply with quote
Always thought it was to do with heat cycles & scuffing the surface.
Common sense tells me not to lean over on a very smooth and cold tyre.
I like to go with big straight line acceleration and hard braking first to get heat into the front and rear, followed up by progressively leaning it over.
Probably all in my head, but I haven't binned it on the 3 sets of new tyres I've ridden on in the past 2 years using this "break in method".
Might be breaking in some new tyres when it gets warmer anyway, I don't like my current tyres very much.
Hong Kong Phooey
PostPosted: 22:35 - 20 Mar 2017    Post subject: Reply with quote
Pr4 fanboi here, uncanny isn't it?
I stuck a set on, 200 yards from new onto wet fresh tarmac and they felt better than the Avon storm 2 ultras I'd just took off.
chickenstrip
PostPosted: 22:46 - 20 Mar 2017    Post subject: Reply with quote
I'm really happy on PR4s, but how much of that was due to going from shagged out tyres to new ones? Or did you ditch the Avons early?
kgm
PostPosted: 22:48 - 20 Mar 2017    Post subject: Reply with quote
I had a couple of slight slippy moments with the pr4s I put on earlier in the winter for the first couple of days and they were fine after that. It was very wet, very cold and a really short commute though so could just have been particularly crappy road conditions.
Hong Kong Phooey
PostPosted: 23:02 - 20 Mar 2017    Post subject: Reply with quote
Avon front was fine, rear was squared off but the edges were well used in the dry. It had 2 plugs in too so was about due, but also I never had much confidence in the wet so I retired them as a pair. Best thing I ever did on the cbr. I know the nice round profile makes it faster steering but the feedback (maybe it's in my head) just gives me a better experience in the rain.
chickenstrip
PostPosted: 23:12 - 20 Mar 2017    Post subject: Reply with quote
It's just that the cynical side of me has been thinking everyone says when they switch to a different tyre how great the new one is compared to the old, how they'll never go back to the crappy things they had on before. Yeah, but wait a sec., your old tyres were down to the canvas Laughing
Snod Blatter
PostPosted: 00:22 - 21 Mar 2017    Post subject: Reply with quote
I've tried quite a few brands of tyre, and thought the old releasing agent thing had been consigned to history along with wet weather lag on disc brakes and boiling chains on the stove.. Until I had a Bridgestone TW202 fitted. That was like riding on lightly melting ice with a coating of oil on the top for the first 30 metres, I didn't know if I was going to make it round the first bend of my street even at 10MPH.
Very scary, I'll never trust a brand new tyre again. Otherwise, tyres from Nankang/GoldenTyre/Heidenau/Metzeler/Michelin/Continental/Avon/Pirelli have all been perfectly fine. Bridgestone, sort yourselves out!
1994 CB250, 1984 CBX250RS-E, 1989 K100RS, 1995 TRX850, 2016 Z250SL
Hong Kong Phooey
PostPosted: 00:25 - 21 Mar 2017    Post subject: Reply with quote
There's an element of that towards the end and that magnifies it, but they came on the bike only a couple of thousand miles in and never felt like the PR4's did in the wet. I don't even think about tyre warm up times nowadays Shocked
arry
PostPosted: 08:13 - 21 Mar 2017    Post subject: Reply with quote
I smashed the strips off my Attacks less than 30 miles after having them fitted. Definitely the best from fresh experience I've had.
There was this one, not very well known tyre brand that I had tyres from once, and they were terrible from fresh so I had to take it easy for 100 miles to wear the release agent out of them.
ThatDippyTwat
PostPosted: 08:29 - 21 Mar 2017    Post subject: Reply with quote
Previous owner on the little YBR fitted some OEM Cheng Shins and it didn't turn a wheel before I bought it (fucked crankshaft bearing), so it was less of a chicken strip, and more like the whole tyre was covered.
That was an interesting experience. Brand new tyre, felt terrible, but not dangerous, from the get-go.
Replaced with Avon Streetrunners after getting sick of it at 3K, and it's instantly loads better.
Pigeon
PostPosted: 19:07 - 21 Mar 2017    Post subject: Reply with quote
Just to have at it from the other angle, going from shagged PR4's to new Roadtec's and I did not think "WOW this is incredible".
However going from squared off Corsa's to PR4's was a WOW moment in the space of 1/2 a mile.
2p
subpardave
PostPosted: 18:02 - 24 Mar 2017    Post subject: Reply with quote
I utterly love the PR series, but really wish they'd make them in a wider range of sizes!
Sadly, email to Michelin basically got a 'no plans for 180/60 ZR17 at all'
Matt B
PostPosted: 18:07 - 24 Mar 2017    Post subject: Reply with quote
subpardave wrote:
180/60 ZR17
For what?
P.
PostPosted: 18:23 - 24 Mar 2017    Post subject: Reply with quote
Matt B wrote:
subpardave wrote:
180/60 ZR17
For what?
R6 race group run them, better turn in with a 120 70 Thumbs Up
subpardave
PostPosted: 01:49 - 02 Apr 2017    Post subject: Reply with quote
Matt B wrote:
subpardave wrote:
180/60 ZR17
For what?
Oh, sorry - 899
I know they're not the most super sticky race rubber in the world but I've loved their wet performance, and V good dry, on other bikes.
The last post was made 7 years, 16 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.10 Sec - Server Load: 0.48 - MySQL Queries: 17 - Page Size: 140.41 Kb
