Honda CG 125 Charging Issues, Part 2
rpsmith79
PostPosted: 19:06 - 23 Mar 2017    Post subject: Honda CG 125 Charging Issues, Part 2 Reply with quote
I have decided to start a new thread on this as the last one went off track a little (thanks Tef Wink )
A bit of a back story, went out on CG a month or so back, conked out, no juice in the battery to restart it, got it home, charged battery, fired up fine, checked voltage, key off 12.5V, engine running 11.5V, ended up changing the Reg/Rec and got a healthy 13.5V when running.......... happy days
Jump to today, took it out for a quick country lane blast after work, all going well when save thing happened, started to conk out, no power, stalled when clutch pulled in, pulled over, no juice again, barely even enough to light up the neutral light
So, pushed it home (luckily all down hill), put on charge for 10 mins, fired up fine, and back down to 11.5V again............. fuck
So it appears i have somehow fucked up my Reg/Rec again.............. how is this possible?
TL:DR Bike not charging, replaced Reg/Rec and all was good, now not charging again, suspect Reg/Rec gone again
Any ideas what can cause the Reg/Rec to just go like that, or is there somewhere else i should be looking for potential problems
Fazer Tom
PostPosted: 20:08 - 23 Mar 2017    Post subject: Reply with quote
Probably just a shitty reg, stick another one on. If all the wiring checks out id just put it down to that.
just bad luck that you've had 2 go.
(CBT 01/07/11. Theory, 21/05/12. MOD 1, 01/06/12. MOD 2, 3/08/12)
Past: (1981 CG125) (1992 ZZR250 x2) (1976 KZ400) (1993 400 Superfour) (2002 Triumph TT600) (1998 Fazer) (2001 CCM 636) (2000 CCM 604) (2007 Kawasaki Z750) (2005 Husqvarna SM450R) Current: (1989 Bandit 400)
rpsmith79
PostPosted: 20:43 - 23 Mar 2017    Post subject: Reply with quote
2 in the space of a month though, only ridden it about 30 miles
To be fair, it was just a 2nd hand one of eBay, but i don't particularly want to spend £130* on a brand new one for it to last another 30 miles
Only place i can find a proper brand new one is www.bike-parts-honda.com unless anyone has any other ideas where i can try getting one from
fast wooly
PostPosted: 20:51 - 23 Mar 2017    Post subject: Reply with quote
Looking at the wiring diagram it looks like a single phase reg/rectifier so you should be able to pick a generic one up off ebay for around £20,if you need any help wiring it let me know.
Wooly
rpsmith79
PostPosted: 21:03 - 23 Mar 2017    Post subject: Reply with quote
This is the wiring for my CG 125 ES4, i believe they differ some from from the earlier ones
Looks like a 3 phase rectifier to me, but i'm not great with electrics
rpsmith79
PostPosted: 21:51 - 23 Mar 2017    Post subject: Reply with quote
Just found another 2nd hand one on eBay for a tenner, think i'll take a punt on that, and if that only lasts a month then i surely have something else wrong
WD Forte
PostPosted: 22:30 - 23 Mar 2017    Post subject: Reply with quote
Looks like a common 3 phase RR to me, as found on many's a bike
so there are thousands to choose from
£130 for a new one? WTF?
Why your previous one failed is mystery at the mo
They're normally quite reliable.
I'd get one from say a 500cc+ bike
as it would probably be rated for a higher output than a
125 bikes stock RR
I stuck a CX500 one on my lads Yamaha Majesty 125 and
it worked a treat
bikers smell of wee
rpsmith79
PostPosted: 08:00 - 24 Mar 2017    Post subject: Reply with quote
125 bikes stock RR
it worked a treat
Ahh right, good to know, but how would i know which bikes would have a suitable 3 phase Reg/Rec?
EDIT: just looking at a few on eBay now, and there seems to be a fair few regulators with 3 yellow wires (from the stator) but then with 3 other wires (green, red, black) i'm guessing 2 of those are +12V & ground, but unsure on the other, and my wiring diagram for the CG only shows 2 wire (Red and Green) Red looks like +12V, green looks like the ground, so what would i do with the black wire............ confused
rpsmith79
PostPosted: 11:13 - 24 Mar 2017    Post subject: Reply with quote
After a bit more digging, it appears i need a 3 phase, 5 wire Reg/Rec (3 wires from stator, +12V & 0V)
There seems to be plenty of universal 3 phase 6 wire Reg/Recs, with a 6th black wire, which as i understand is a "DC Voltage Sense" wire, which should be connected to the ignition switch
Can i get away with fitting a 3 phase 6 wire reg/rec and just ignore the "DC Voltage Sense" wire, or do i need to do a bit more wiring work and attach it to the ignition switch
Any advice much appreciated as i am out of my depth when it comes to electrickery
WD Forte
PostPosted: 00:43 - 25 Mar 2017    Post subject: Reply with quote
No you can't ignore the sense wire as this can make it float and
the output voltage go too high
You can use a 5 or 6 wire RR from any other bike that has a 3 phase charging system
5 wires have internal sensing and 6 wire external
I have 6 wire RR and just patch the black sense wire to the output wire/battery live
It's been like that for 9 years now with no charging problems at all
and steady output.
bikers smell of wee
rpsmith79
PostPosted: 14:57 - 25 Mar 2017    Post subject: Reply with quote
Cheers Forte, makes a bit more sense now
The last post was made 7 years, 32 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.06 Sec - Server Load: 0.84 - MySQL Queries: 17 - Page Size: 72.15 Kb
