Honda CB400 Super Four cutting out
iansoady
PostPosted: 17:11 - 25 Mar 2017    Post subject: Honda CB400 Super Four cutting out Reply with quote
I've had a couple of very pleasant rides on the Super Four.
https://i43.photobucket.com/albums/e398/iansoady/bike/CB400/_86_zpsdzxtaico.jpg
However, it refuses to idle once warm and cuts out, requiring a rest and then substantial winding over to start. It then idles quite lumpily.
The first time I decided it was the daft vacuum-operated petrol tap so modified that so it didn't need vacuum and blanked off its pipe. But clearly there's more to it than that. It's not blocked tank breather as when I open the petrol cap there's no inrush of air.
I am thinking it's mucky pilot circuits but never having had a bike with more than a couple of carbs, what do those with more experience think?
It runs beautifully at higher revs although I keep looking for a couple more gears at the top end.....
Ian
1986 Honda XBR500
1952 Norton ES2
jaffa90
PostPosted: 10:56 - 26 Mar 2017    Post subject: Reply with quote
Pilot jets work mostly up to 2/3,000 rpm.
On a cold start can the choke jets let the engine rev evenly?
Robby
Dirty Old Man
PostPosted: 11:30 - 26 Mar 2017    Post subject: Reply with quote
It's an old bike, and may have spent some time standing in the past. Could be fuel, could be electrical.
Pilot/mixture circuits are a possibility, and I find they're the one bit of carbs that doesn't clean itself - the other jets tend to sort themselves out with a bit of fresh petrol.
If you're lucky you might be able to access the screws without taking the carbs off the bike. In that case it's a case of winding each one in, counting the turns, and writing down the settings. Then unscrew, recovering the tiny washer and O-ring. Blast some carb cleaner down the hole, and reassemble - leaving the screw the same number of turns out.
It's also old enough for coils or their mounts to be knackered, HT leads are probably toast, or something deeper.
Tankie
PostPosted: 12:23 - 26 Mar 2017    Post subject: Reply with quote
carbs off, bowls off and clean them out , blow all the jets out with compressed air, check the float heights, remove the air screws, counting the turns in first and blow through, reassemble and refit.
If the machine has any diaphragms fitted on the side of the carb bodies these also need checking for perforations
redeem ouzzer
PostPosted: 13:08 - 26 Mar 2017    Post subject: Reply with quote
Split carb bank, ultrasonic bath, rebuild with new seals. There can be no half measures.
Be a REAL MAN!
iansoady
PostPosted: 16:02 - 26 Mar 2017    Post subject: Reply with quote
Thanks all.
It has been standing since I bought it in the autumn and hadn't done much before that (maybe as the previous owner had the same problem......)
I've taken the plugs out - they're clean, properly gapped and a nice colour. I've also lubricated the choke mechanism to ensure it's not sticking and upped the idle speed to 1,300 (it was actually way too low below 1,000 so that wouldn't help). Standing in the drive running up to normal temperature it seems fine but we'll see. I've also chucked some silkolene fuel treatment in - any straw in a storm.
I know I should do it properly but TBH this is supposed to be my reliable modern bike (old bike - what a cheek!) and I have far too many other things to do rather than fiddling with it so I don't really want to take the carbs off......
Ian
1986 Honda XBR500
1952 Norton ES2
iansoady
PostPosted: 15:17 - 04 Apr 2017    Post subject: Reply with quote
Finally tracked down to one of the plug caps showing an infinite resistance. Replaced with a new one and just been for a very nice 40 mile ride.
I have to say I was reluctant to believe that it wouldn't just run (even if badly) on the other 3 (or maybe 2 given that coils are shared) but there you are.
Ian
1986 Honda XBR500
1952 Norton ES2
jaffa90
PostPosted: 15:48 - 04 Apr 2017    Post subject: Reply with quote
Well done but you never answered my post.
redeem ouzzer
PostPosted: 21:05 - 04 Apr 2017    Post subject: Reply with quote
Hopefully he's doing the decent thing and ignoring your braying insincere horseshit, mr. Sub-1000 idle god.
Be a REAL MAN!
jaffa90
PostPosted: 00:28 - 05 Apr 2017    Post subject: Reply with quote
Quiet simple really like you, if it ran evenly on the choke then it would be a pilot problem Laughing
P.
PostPosted: 14:06 - 05 Apr 2017    Post subject: Reply with quote
Jaffa just fuck off you waste of oxygen.
PostPosted: 14:10 - 05 Apr 2017    Post subject: Reply with quote
Ooh, why the kicking? Should I be putting the boot in too, or saying leave it, he ent worth it.
Evil Hans
PostPosted: 15:26 - 05 Apr 2017    Post subject: Reply with quote
I don't know what Paddy's beef is, but I wanted to kick him for not knowing the difference between "quite" and "quiet". Wink
jaffa90
PostPosted: 15:36 - 05 Apr 2017    Post subject: Reply with quote
Whoah, that`s awful, i think i`ve forgot more than you know!
P.
PostPosted: 01:44 - 06 Apr 2017    Post subject: Reply with quote
Jaffa is 1k idle fanatic/autistic cunt.
PostPosted: 06:49 - 06 Apr 2017    Post subject: Reply with quote
One time, right? Everyone gets one.
P.
PostPosted: 16:11 - 06 Apr 2017    Post subject: Reply with quote
He cri evertim.
He's had more than one. I've offered for him.to come get my triple.of GSXR to idle at 1k... He hasn't attended.
The last post was made 7 years, 20 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.10 Sec - Server Load: 0.79 - MySQL Queries: 17 - Page Size: 94.32 Kb
