Author |
Luckyfish13 |
 Luckyfish13 Renault 5 Driver
 Posted: 11:40 - 28 Mar 2017 Post subject: 08 Yamaha xt125r overheating |
Hi people,
I've posted this on Yamaha club as well....
bought a non runner 08 xt125r, did the top end rebuild using all genuine parts...
the barrel was within spec and not warped.
only thing I noticed was the second ring gap was about 0.05 mm too small, but hey I installed it anyway....
had reset the carb to stock settings...
new oil...
she fired up straight away, 75psi compression, but after going ride for about 5 mins it felt crazy hot so came home checked temp it was 130C....
now ive set the pilot mix 2.5 turns out, moved the throttle needle up to rich out the mix, after the test ride temp was showing 120c, so improvements but still too hot.
theres no air leaks
air box is standard
oil is changed after every test ride (probs cos 120c absolutely destroys it)
Engine starts pinging after it's been running a couple minutes, or when temp reaches around 70-80C
Went for a ride with the choke (enrichener circuit) on, came back temp was 105c....
any ideas why she's runnning soooo hot????
Sorry for the essay lol
[img][/img][/list] ____________________ Daytona 650
XT 125R |
Back to top |
AndyCF |
 AndyCF Two Stroke Sniffer
Back to top |
Luckyfish13 |
Back to top |
AndyCF |
 Posted: 17:04 - 28 Mar 2017 Post subject: |
If the plug is about the right 'shade' when its got the choke on, it points towards a weak mixture as remember the mix is stronger with the choke due to the reduction of air.
Talking of air, worth a look to check you do not have any air leaks (carb to head area possibly)
I'm not 100% up on this model with regard to the timing, it probably is as you say fully locked however it would not be impossible for either the timing sensor to move or the actual CDI unit to be iffy but that does seem quite a stretch somehow.
Not a betting man but money is on weak mix from what you say... Hope that's a little bit of help anyway. |
Back to top |
Luckyfish13 |
 Posted: 17:23 - 28 Mar 2017 Post subject: |
Thanks bud will defo look for air leaks again where the rubber intake mount is...also I re torqued the engine head bolts incase it was leaking there....
Was wondering...if the valves are out of time/adjustment would that cause overheating?
Btw the inside of the carb is frickin spotless  ____________________ Daytona 650
XT 125R |
Back to top |
AndyCF |
Back to top |
Robby |
 Robby Dirty Old Man
Back to top |
Luckyfish13 |
Back to top |
Luckyfish13 |
Back to top |
The last post was made 8 years, 114 days ago. Instead of replying here, would creating a new thread be more useful? |
