Tightening drive chain... help
Waaarrrggghhh
PostPosted: 17:06 - 29 Mar 2017    Post subject: Tightening drive chain... help Reply with quote
I am trying to adjust the chain slack (tightening it) but unfortunately I am unable to get any of the nuts out. They are stuck in so tightly I am actually starting to round the edges of the nuts off and bend the wrenches.
Is there any way for me to loosen them? I fear I might have done some irreversible damage to the lug nuts on the axle.
The only tools I have are the ones that came with the bike. Would a mechanic with some machine tools be able to help me out?
ThatDippyTwat
PostPosted: 17:45 - 29 Mar 2017    Post subject: Reply with quote
Decent set of sockets and spanners. Plusgas.
Until you have those, stop. The stuff that comes with a bike is, almost invariably, made of Red Leicester.
PostPosted: 17:50 - 29 Mar 2017    Post subject: Reply with quote
Pics. Thumbs Up
Waaarrrggghhh
PostPosted: 19:52 - 29 Mar 2017    Post subject: Reply with quote
The bike judders and shudders hard when in low gears and accelerating so I'm wondering if the loose chain is what's causing these judders.
It sounds like something is slapping around inside the engine/against it.
arry
PostPosted: 19:54 - 29 Mar 2017    Post subject: Reply with quote
What is the bike?
How slack is the chain?
What's the condition of the cush drive?
RhynoCZ
PostPosted: 20:05 - 29 Mar 2017    Post subject: Reply with quote
Is the chain new? Is it the right length?
Dealing with rusty bolts:
1) Spray with: WD40, penetrating oil or Plusgas (the best thing to use, but if you don't have Plusgas, just use the rest of the list),
2) Use proper tools (not pliers like people tend to),
3) Seat the tool properly,
4) Use impact force, DO NOT try to slowly turn/apply force,
5) IF you fecked up the bolts, then post the picture and I'm gonna give you the best advice possible on how to undo your negligence.
IF you were succesful, then buy some new bolts, do not reuse the fecked up ones.
Baggyman
PostPosted: 20:52 - 29 Mar 2017    Post subject: Reply with quote
hooked sprocket? Pictures please
Old fart
Baghira, modded GS1000 and the T150 I bought in 1978 when I was 21
Waaarrrggghhh
PostPosted: 21:41 - 29 Mar 2017    Post subject: Reply with quote
Yeah the sprocket is pretty shark toothed now. Sorry no pics but u can probably imagine.
Waaarrrggghhh
PostPosted: 21:43 - 29 Mar 2017    Post subject: Reply with quote
arry wrote:
What is the bike?
ybr 125.
The chain is very slack, should be between 20-30mm slack but right now its nearly 50mm.
Seems its happened after a few long journeys I've done across England.
Where is the cush drive located on a ybr 125?
arry
PostPosted: 21:47 - 29 Mar 2017    Post subject: Reply with quote
Ok first things first, you're going to need a better toolkit. A few spanners don't cost a lot, go do a buy.
The cush drive rubbers are inside the rear wheel. They're bits of rubber. YBR's seem to suffer with them expiring. They're only £10 so not expensive, but worth checking. How you check is whether there's any movement in the rear sprocket against the movement of the rear wheel. That is to say, if you turn the rear wheel, does it turn the sprocket without undue slack.
PostPosted: 22:35 - 29 Mar 2017    Post subject: Reply with quote
And make sure you take pictures if you are asking for advice.
We don't want to laugh at you attempts, we want to help and a picture is worth a 1000 words.
But, as others have said. A socket set and spanner set. They don't need to be Snap on or Britool, just something that isn't made of pressed steel like your bike toolkit. It's actually good economy as when you come to try and remove the sump plug with a piece of shit OEM toolkit spanner and round it off you wont be laughing.
Triumph Trophy Launch Edition
NJD
PostPosted: 00:10 - 30 Mar 2017    Post subject: Reply with quote
Pictures of the condition of the axle, adjuster and adjuster lock nuts would be helpful.
I recently purchased a Halfords advanced combination spanner in the size that my axle needed and used the ring end to loosen and tighten the axle, no problems to report.
kgm
PostPosted: 06:21 - 30 Mar 2017    Post subject: Reply with quote
Halfords had their big spanner and socket sets half price the other day what I was in. 12pt sockets unfortunately but still a decent kit, serves my needs fine and I'm doing full rebuilds. Might still be on sale, and if not they will be soon as they always are.
Definitely worth getting a decent set of tools. It makes life much easier.
arry
PostPosted: 06:48 - 30 Mar 2017    Post subject: Reply with quote
And don't forget you'll need to loosen off the adjustment for the drum rear brake too, otherwise when you pull the wheel back to tension the chain you'll just be fighting against it, or end up with a very snatchy rear brake.
PostPosted: 08:38 - 30 Mar 2017    Post subject: Re: Tightening drive chain... help Reply with quote
If you put your location in your profile, you might get a localite willing to turn up and whip your nuts off.
PostPosted: 10:24 - 30 Mar 2017    Post subject: Reply with quote
Now I don't get the hate with twelve points as long as they are a decent brand and fit well. I have six points for impact use and my 3/4" drive set is six point but my best 1/2" drive is 12 point and I've never had a problem.
Six points are a way of getting round quality control in a cheap set, they don't have to be so well made as they won't fuck up the nut if the fit isn't brilliant.
On our ships we used to use Facom & Gedore 12 point sockets/sets with no issues.
cb1rocket
PostPosted: 10:50 - 30 Mar 2017    Post subject: Reply with quote
just the adjusters?
obvious first, have you actually loosen the axle nut first?
Waaarrrggghhh
PostPosted: 11:09 - 30 Mar 2017    Post subject: Reply with quote
Ok I managed to loosen the axle nuts, but the swing arm nut is stuck in so badly I have completely rounded it off. I did try WD40 before attempting to loosen it, and I used my dad's tools which are all high quality, as he is a professional carpenter/furniture maker.
I am unable to use a torque wrench on it because for some really strange reason there's a thin piece of metal tied up in front of the nut.
edit: right hack sawed the weird metal knot that was in the way and got to it with a torque wrench, and it has rounded it off completely now. Going to need to call the mechanic.
What a piece of shit!!
RhynoCZ
PostPosted: 11:11 - 30 Mar 2017    Post subject: Reply with quote
Swing arm nut? Shocked
PostPosted: 11:19 - 30 Mar 2017    Post subject: Reply with quote
https://i.imgur.com/3jO8Wep.gif
https://i.imgur.com/A4ZC42q.jpg
PostPosted: 11:27 - 30 Mar 2017    Post subject: Reply with quote
Castellated nut and didn't take the split pin out first? We can't have two imbeciles can we, Arcane and now OP?
Fucking photographs you fucking wally Evil or Very Mad
Fizzoid
PostPosted: 11:30 - 30 Mar 2017    Post subject: Re: Tightening drive chain... help Reply with quote
Yeah, if you're in the Birmingham area, I'm sure Arcane is free after completing his latest engineering project
Rogerborg wrote: It'd certainly make it easier to ego-find my own posts on pages, given the number of fags (gay like traps) who insist on putting my name in their .sig
kgm
PostPosted: 11:35 - 30 Mar 2017    Post subject: Reply with quote
I have no issue with 12pt sockets, they can make things a little easier sometimes but 6pt are a bit better for stuck fastners. Apart from my impact sockets all of mine are the Halford 12pt.
Waaarrrggghhh
PostPosted: 11:41 - 30 Mar 2017    Post subject: Reply with quote
Rogerborg wrote:
yeah thats exactly what I've been trying to do, the bottom nut is rounded off and probably stripped.
I took off the little knot thing on the end of the thread to get at it with the torque wrench.
PostPosted: 11:47 - 30 Mar 2017    Post subject: Reply with quote
Where are you?
I'm sure a reasonably competent local BCFr will help.
The last post was made 7 years, 61 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.10 Sec - Server Load: 0.76 - MySQL Queries: 16 - Page Size: 134.47 Kb
