| Nemo |
 Nemo Could Be A Chat Bot
 Posted: 21:44 - 31 Mar 2017 Post subject: Thought this may be useful |
Just browsing YouTube, as you do, and RoadcraftNottingham has posted this video of a mock mod 1
https://youtu.be/zJac1xGKNjg
Thought it might help some anxious new comers. ____________________ Previously owned: Kawasaki KH125, Suzuki GP125, Suzuki GX 125, Honda CB125 TDC '83, Honda ntv 600, Kawasaki ER5, Kawasaki ZZR600, Aprilia RSV 1000 Mille
Now own: Ducati 848 evo |
| SDFarsight |
 SDFarsight Nova Slayer
| Pjay |
 Pjay World Chat Champion
| Analogkid |
 Analogkid Scooby Slapper
| SDFarsight |
| Pjay |
| Analogkid |
 Posted: 15:01 - 02 May 2017 Post subject: |
| Pjay wrote: | | Analogkid wrote: | Because at low speed and inexperienced riders can often grasp the front brake too hard, cause the bike to dive and making it more likely they feel the need to put their foot down or fall over, both instant fails, taught to balance clutch and back brake, you probably do it yourself when in traffic etc, rolling behind another vehicle and coming to a stop, I know I do it's smoother. |
I pretty much only put some small pressure on the back brake when slowing to lights, pretty much all other braking is on the front.
If a rider can't use a front brake properly, he should fail. |
That's what I'm referring too, at walking pace during a test you often need a dab of rear brake, the clutches on most school bikes aren't precision instruments and riders are novices, not everyone is a budding Pastrana. |
| Rogerborg |
 Rogerborg nimbA
| Pjay |
| SDFarsight |
| Analogkid |
 Posted: 15:30 - 02 May 2017 Post subject: |
| Pjay wrote: | | Analogkid wrote: | That's what I'm referring too, at walking pace during a test you often need a dab of rear brake, the clutches on most school bikes aren't precision instruments and riders are novices, not everyone is a budding Pastrana. |
I'm not disputing that using the back brake at low speeds is good practice, but teaching people not to use the front brake is poor form.
I mean that if they are not able to use the front brake at low speed, then they clearly shouldn't have a licence.
Teaching people to pass tests is bad form, instructors should teach them full control of the brakes. |
They do teach them how to properly use both brakes, but during the slow speed maneuvres, inexperience, nerves etc, that's when they advise staying away from front brake, they even advocate progressive braking by coming to a controlled stop using both brakes after the swerve test, even going as far as suggesting modulating pressure on front as you come to a stop. |
| dydey90 |
 dydey90 World Chat Champion
| Analogkid |
 Posted: 16:08 - 02 May 2017 Post subject: |
| SDFarsight |
 Posted: 16:24 - 02 May 2017 Post subject: |
Hey, some people do apply the break too heavily!  |
| Alpineandy |
 Alpineandy World Chat Champion
| M.C |
 M.C Super Spammer
| RhynoCZ |
 RhynoCZ Super Spammer
 Posted: 10:07 - 03 May 2017 Post subject: |
| SDFarsight wrote: | Indeed it's a progressive scale rather than a button. And for emergency stops I was advised to use a balance of front and rear. |
I was told not to touch the rear brake in emergency situations, because at that moment your rational thinking is focused elsewhere and you could, most likelly, just put too much brake pressure on the rear, making things even worse. The rear brake being yet another distraction.
''balance of front and rear'' is not what you're going to do, when you think you're gonna die. Also, and I don't say it's true, if you ride a sports bike, then have a look at your rear brake. Even Kevin Schwantz, and others, said that the rear brake was just a distraction and they never really used it on the track.
*Worth noting: The frame geometry pretty much determins how effective the rear brake is going to be. When there is more weight over the rear wheel, the rear brake will work better. Hence on the sports bikes the rear brake disc is tiny, because (and I don't know if motorcycles that I had a chance to ride were special) the moment you apply the rear brake, you can't feel much of braking/slowing down and if you apply more force, the rear wheel just blocks.
Pro-tip,
...might be pointless and I might be called names, but get used to use only one or two fingers on the front brake lever. This way, even in a emergency situation, you will never slam the front brake as you do not have the strenght in your one/two fingers. Locking the front brake, when panicing, is a result of using your whole hand to grab onto the lever. More further on the lever you apply the force, more torque you put there = more brake pressure applied. If you grab the lever at its end = minimal force required to lock the front wheel = instant road scraper.
YET, using only one/two finger/s on the lever is more than enough to operate the brake and slow down/stop the bike from three digit speeds.
*Worth noting: some front brakes can't be operated this way and require more force/fingers on the lever. ____________________ '87 Honda XBR 500, '96 Kawasaki ZX7R P1, '90 Honda CB-1, '88 Kawasaki GPz550, MZ 150 ETZ
'95 Mercedes-Benz w202 C200 CGI, '98 Mercedes-Benz w210 E200 Kompressor |
| ScaredyCat |
 ScaredyCat World Chat Champion
 Posted: 11:54 - 03 May 2017 Post subject: |
When I did my mod1 the first bit, moving from one bay to another, we were told to back the bike out in a straight line. Only turning when moving in a forward direction. So back it out in a straight line, move forward until you've done the semi-circle, back it in straight.
If you get off on the left of the bike (clutch lever side) and you're turning, with your left on the left handle bar and your right on the rear grab handle, then you're a bit fucked if it slips to the right. It'll be hard to catch it.
Not seen any other training videos where they do what I did though.
-- Edit : Found an example recorded with a potato:
https://youtu.be/snEJjokv6cQ?t=70 ____________________ Honda CBF125 ➝ NC700X
Honda CBF125 ↳ Speed Triple
| RhynoCZ |
| M.C |
 M.C Super Spammer
| ScaredyCat |
| arry |
 arry Super Spammer
| Chris45 |
 Chris45 Nitrous Nuisance
| arry |
 arry Super Spammer
| Pete. |
 Pete. Super Spammer
 Posted: 00:20 - 04 May 2017 Post subject: |
The biggest reason as I see it not to use your rear brake in the emergency stop is because with the weight transferred to the front it's very likely to stop the rear wheel and that's an instant fail. ____________________ a.k.a 'Geri'
The last post was made 9 years, 21 days ago. Instead of replying here, would creating a new thread be more useful? |
