More brake pad questions.
PostPosted: 15:27 - 16 Apr 2017    Post subject: More brake pad questions. Reply with quote
My rear pads on the Trophy are worn. Obviously OEM and worn in 4000 miles. I have no idea who made the pads but the calipers are Nissin. Triumph part PFKL2151711, PAD SET, TT2450GG, £ 35.17
I'm not paying that when they wear out stupidly fast.
Now EBC sintered are £23.98 and EBC organic are £17.02 from Wemoto. They are even cheaper on ebay.
Question. I have never fitted anything but sintered however I'm presuming my bike did not come with sintered pads all round (can't see anything to say they are or not) and I'm not replacing perfectly good pads on the front at a cost of £100.
Sintered on the back and organic on the front with a linked braking system with ABS. Would there be any issues?
Would the sintered last longer. Should I try something other than EBC.
At the moment I am veering towards EBC organic. Decisions decisions.
Triumph Trophy Launch Edition
Hong Kong Phooey
PostPosted: 15:39 - 16 Apr 2017    Post subject: Reply with quote
Sticky rear caliper, or rear brake lever need adjusting?
Pads might be making constant contact to wear that quickly.
PostPosted: 15:48 - 16 Apr 2017    Post subject: Reply with quote
It seems the linked braking system eats rear pads. There are comments on the Trophy website. Others said on an earlier thread about sticking calipers but the brake is never hot and when I took it off to check the pads, everything moved pretty freely.
I just want to know if anyone has mixed bake pads that way round. I don't want the rear ABS kicking in before the front has done it's job which is my worry with sintered back and organic front.
wr6133
PostPosted: 16:23 - 16 Apr 2017    Post subject: Reply with quote
Currently have organic on the front and sintered on the back (K1 GSXR1000).
I'm not dead so it can't be all bad. Front provides ample stopping power just lack that bite sintered give you. Brakes are not linked though and the back only really gets touched at low speeds or to bring the front down.
PostPosted: 16:39 - 16 Apr 2017    Post subject: Reply with quote
That's what concerns me. I cannot operate the rear independently. If I could all would be fine as on a normal bike I just use the rear for balance and the front for the serious stopping. On mine, if you don't use the rear pedal and therefore the combined front and rear linked calipers, along with the front lever you are seriously reducing your braking ability.
Petemate
PostPosted: 20:32 - 16 Apr 2017    Post subject: Reply with quote
Even though linked braking is supposed to be very safe, what concerns me (and this is why I am glad I have not got a bike with it ATM) is what happens, when with linked brakes, if one needs to apply braking during a slow speed turn? I always use my rear, for example, during u-turns to balance out the progress. Using the front brake on a bike in this situation is very likely to have one off pronto. Gentle use of the rear reduces the speed without shifting the weight on to the front end enough to topple one off.
For instance, I even heard recently of one of our cub members who came off at slow speed on a slight turn when his engine cut out. So using a linked system, operating the rear pedal would bring on both brakes? No thanks.....
82 not out....1983 Honda LA250 Custom
2008 Saab 9-3 1.9 Tid 150 Vector Sport estate
2005 Stirling Eccles Topaz 2-berth
PostPosted: 09:50 - 17 Apr 2017    Post subject: Reply with quote
There are some very good semi-metal or organic pads out there. Sintered are just quicker for the manufacturer to produce. Wink
Personally in the rear I wouldn't bother with sintered. A semi-metal or organic pad is more than good enough.
You can pick up Galfer semi-metal pads for £14.95 on eBay and they're a very good pad for the money.
Hong Kong Phooey
PostPosted: 10:06 - 17 Apr 2017    Post subject: Re: More brake pad questions. Reply with quote
If your ABS is 2 channel, then if you lock the rear or front it temporarily releases that end only. Shouldn't be a problem.
Hong Kong Phooey
PostPosted: 10:09 - 17 Apr 2017    Post subject: Reply with quote
Not all linked brakes work that way. e.g. some BMW's let you use just the rear. I've found them to be unexpectedly powerful at first but you'd soon get used to it.
Petemate
PostPosted: 12:06 - 17 Apr 2017    Post subject: Reply with quote
Ah, thanks Hong Kong Phooey. So a bit more research then as to which bikes have which type of system. Can't afford a BMW though......
Ta again.
PostPosted: 13:48 - 17 Apr 2017    Post subject: Reply with quote
Mine is an utterly ludicrously over complicated system with the rear brake pedal operating the rear brake and 2 of the four pistons in the right hand front brake caliper. Add into this some sort of smart balancing between the front and rear calipers, independent front and rear ABS plus traction control you can see what a fuck off nightmare Triumph have created.
OK, it works. It will stop the bike but why oh why can't we just have front brake on the handlebars and rear brake on the pedal. The ABS/Brake 'brain' costs £1171.17p Shocked
FFS, If I still have the bike when that dies it's cgoing to get a conversion to a simple brake system.
As for my rear pads, I'll try those semi metal that Wafer_Thin_Ham suggests Thumbs Up
Snod Blatter
PostPosted: 13:49 - 17 Apr 2017    Post subject: Re: More brake pad questions. Reply with quote
Polarbear wrote:
TT2450GG
I would guess that the GG means they are not sintered. Based on this I'd stick some boring organic EBC pads in and see what they're like Thumbs Up
1994 CB250, 1984 CBX250RS-E, 1989 K100RS, 1995 TRX850, 2016 Z250SL
PostPosted: 13:55 - 17 Apr 2017    Post subject: Re: More brake pad questions. Reply with quote
Snod Blatter wrote:
Polarbear wrote:
TT2450GG
Good point, I didn't pick up on that.
The last post was made 7 years, 11 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 0.56 - MySQL Queries: 17 - Page Size: 82.51 Kb
