What have you done to your bike today? Archive.
This topic is locked: you cannot edit posts or make replies.
Bike Chat Forums Index -> General Bike Chat Goto page Previous  1, 2, 3 ... 249, 250, 251 ... 407, 408, 409  Next
Blah blah
PostPosted: 21:15 - 18 Apr 2017    Post subject: Reply with quote
Backed off the preload on the recently fitted ST4s forks I've stuck my Monster to try to get a reasonable amount of sag, then gave it some stick to Lands End and back...
Need to turn the compression down by a couple of clicks, and check everything again as the front still feels a bit vague but it's better than the crashy horrible things I took off as I can at least feel what the front is doing now
Fizzer Thou
PostPosted: 22:02 - 18 Apr 2017    Post subject: Reply with quote
Cleaned the K&N air filters on the FZR-R
https://i666.photobucket.com/albums/vv23/WiNot_Rhencullen/Workshop/20170401_183045_zpsgzqyhhee.jpg
Always have a 'Plan B'
AshWebster
PostPosted: 22:30 - 18 Apr 2017    Post subject: Reply with quote
I did this in an hour or so Smile
https://3-t.imgbox.com/O4qoaOlQ.jpg
edit: are my chicken strips bad ? been riding a few months so trying !
Honda cg125 J reg peice of shit ---> CB650F ---> 2016 CBR600RR
Ford KA ---> 93' MR2 ---> 94'MR2 ---> 98' Subaru WRX STI Ver 3 (track car)
grr666
PostPosted: 16:21 - 19 Apr 2017    Post subject: Reply with quote
New rubber on the Xenter. Just about to put it away now its back from the shop. Exhaust was a pita to remove apparently.
Still it tipped into bends a lot more willingly riding it home. Then again the front tyre was soft on the way there so that's
probably why...
pepperami
PostPosted: 17:46 - 19 Apr 2017    Post subject: Reply with quote
Today the excitement of my bike life was to chain them all together after moving some stuff in the garage Laughing oh whoope do !
Petemate
PostPosted: 18:43 - 19 Apr 2017    Post subject: Reply with quote
Checked over for MOT - adjusted chain, adjusted head bearings, checked all lights, gonna pop into my normal MOT dealer tomorrow and see if he can do it then.
82 not out....1983 Honda LA250 Custom
2008 Saab 9-3 1.9 Tid 150 Vector Sport estate
2005 Stirling Eccles Topaz 2-berth
Yorkshire Geek
PostPosted: 19:32 - 19 Apr 2017    Post subject: Reply with quote
Took it to a garage for MOT and to get the idle issues fixed by a pro. Run out of pissing about time, I want it rideable next time there's sun!
Hong Kong Phooey
PostPosted: 19:57 - 19 Apr 2017    Post subject: Reply with quote
Swapped the front caliper mount bolts for titanium alloy - I could feel one of the old ones stretch as I was torquing it up Neutral
Wonders if titanium alloy fixings are addictive? Rolling Eyes
DRZ4Hunned
PostPosted: 20:26 - 19 Apr 2017    Post subject: Reply with quote
Took the front sprocket cover off the fazer, no welded sprocket thank god.
Also removed a tennis ball sized lump of crap from around the cover and bamboozled myself as to why I couldn't get the clutch to automatically return, then realised the cover had to be bolted down as it has a pressure plate. Laughing
DRZ400-SM
FZS600
pompousporcup...
PostPosted: 10:18 - 20 Apr 2017    Post subject: Reply with quote
tightened all 8 of the exhaust manifold nuts on the thundercat as they'd worked so loose that the blowing noise was too much to stand. - sorted now though and sounds good again
just off to get a set of Avon 3D-XMs fitted as Mr Tyre Man couldnt get avon storm 2 ultras in anymore.
B5234FT
PostPosted: 10:48 - 20 Apr 2017    Post subject: Reply with quote
Had a pair of Michelin Pilot Streets fitted to the GPZ this morning.
pepperami
PostPosted: 12:58 - 20 Apr 2017    Post subject: Reply with quote
Had a couple of new tyres put on my Chinese POS to replace the originals.
Seems to ride a lot better now as it doesn't feel so vague Smile
derillius24
PostPosted: 14:58 - 20 Apr 2017    Post subject: Reply with quote
Fitted some Eazi-Grip tank pads to help with two-up work on the STriple. Adhesive seems pretty solid and they were inexpensive compared to the Tech-Spec stuff. Didn't manage to attach each side absolutely symmetrically though, despite my best efforts, which has awoken my compulsive demons Evil or Very Mad
CG125, CBF250, DRZ400-SM, Z750, Street Triple R, Tuono V4R
M.C
PostPosted: 15:14 - 20 Apr 2017    Post subject: Reply with quote
Burn bike and start again, it's the only way to silence them.
PostPosted: 15:47 - 20 Apr 2017    Post subject: Reply with quote
https://i.imgur.com/cJMsrka.jpg
thx1138
PostPosted: 17:03 - 20 Apr 2017    Post subject: Reply with quote
smashed the number plate on the beta with my sized 11 boots when getting off the bike, didn't even bin it or drop it Rolling Eyes
rotated both the clutch and the brake levers forward as far as I could, without moving the hand guards, makes it so much easier to cover clutch and brake with one finger when standing up - should have done it last year really
practiced stand up wheelies, getting slightly better now I bounce the bike up/down rather than trying to push forward
M.C
PostPosted: 18:51 - 20 Apr 2017    Post subject: Reply with quote
I've ripped mine off with a paddock stand but I think you win this round Smile
Petemate
Took the bike in for the MOT - passed! YaY!
DRZ4Hunned
PostPosted: 18:55 - 20 Apr 2017    Post subject: Reply with quote
Taxed it... £62!!!
I thought £45 was bad for my 400.
DRZ400-SM
FZS600
M.C
PostPosted: 19:17 - 20 Apr 2017    Post subject: Reply with quote
DRZ4Hunned wrote:
Taxed it... £62!!!
One more cc and you'd be paying £85 like me Crying or Very sad
TheSmiler
PostPosted: 22:04 - 20 Apr 2017    Post subject: Reply with quote
Started stripping the bike as the sprague clutch is gummed jp and can't get it loose.
ThatDippyTwat
PostPosted: 20:11 - 21 Apr 2017    Post subject: Reply with quote
Project - New clutch lever, new brake lever, new exhaust, stainless flex and shim on exhaust, new rear valve, sorted some of the wiring, replaced some bolts.
DRZ4Hunned
PostPosted: 21:13 - 21 Apr 2017    Post subject: Reply with quote
Rode my new FZS600, never ridden anything other than singles before. I feel like I'm going to blow the engine up revving it so much but it's only at about 6k and it goes to about 12k? before redline. Very Happy
Not sure if clutch needs adjusting or it's slipping as it revs but doesn't really accelerate... Might just be me being a n00b.
DRZ400-SM
FZS600
grr666
PostPosted: 21:30 - 21 Apr 2017    Post subject: Reply with quote
That'll be the loss of torque you're experiencing. FZS will find a second wind at about 8k
bandit_engineer
PostPosted: 21:31 - 21 Apr 2017    Post subject: Reply with quote
Replaced the rectifier/regulator on my GSXR 750 K7.
Had been relocated over the winter and thought I got away with it until it let go at 70 and had to be recovered Sad
The Suzuki engineer who decided it was a good idea to put the rectifier behind the radiator should seriously reconsider a career change. Twisted Evil
Installed a K9 rectifier and all is good. Luckily that was the only casualty and the stator and ECU are all good.
Finding you have ran out of voltage at 70 and knowing the inevitable is no fun Laughing
Previous: 2002 Speedfight 50, 2000 RS125, 2002 RS125, 1997 Bandit 600N, 2003 SV1000S
Current: 2007 GSXR 750 (Isle of Man)
The last post was made 7 years, 7 days ago. Instead of replying here, would creating a new thread be more useful?
Post new topic   This topic is locked: you cannot edit posts or make replies.    Bike Chat Forums Index -> General Bike Chat All times are GMT + 1 Hour
Page 250 of 409
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.18 Sec - Server Load: 0.85 - MySQL Queries: 17 - Page Size: 131.47 Kb
