Annoying VFR800 VTEC Charging Problems
ferrisio
PostPosted: 16:45 - 23 Apr 2017    Post subject: Annoying VFR800 VTEC Charging Problems Reply with quote
Seems like people weren't joking about the charging problems with these.
Symptom - Batt voltage 12.8v, drops to 12.1v when engine running, and doesn't move a great deal when the bike is revved
Tested - stator continuity to ground (no continuity, each phase)
stator phase-to-phase continuity (all under 1 ohm)
stator output voltage (about 18vac on idle, 50-ish at 5k rpm)
voltage drop across reg/rec terminals to battery negligible (<.1v)
I've got two reg/recs and both give exactly the same symptoms, however neither were brand new. I've diode-checked them both.
Finally, I bought a brand new decent Yuasa battery (factory recommended) thinking it could just be some dodgy battery issue - no difference.
With the fuse for the headlights removed the voltage goes up to a more respectable voltage (13+) but I've measured the current draw with the headlights in (just over 6A from memory) and it seemed respectable for a 50w bulb and the various taillights etc.
What can I try next, this is very frustrating! Current thinking is to get a MOSFET reg/rec and wire it direct to the battery completely bypassing the existing loom.
BMW R1100R
Tankie
PostPosted: 17:02 - 23 Apr 2017    Post subject: Reply with quote
You have regulator fault, when fitting a new unit re check the earthing of this unit, I take it you have checked the plug and socket pins?
ADSrox0r
PostPosted: 18:50 - 23 Apr 2017    Post subject: Reply with quote
Your thinking is correct; get a decent 'fet and do a bypass.
ferrisio
PostPosted: 13:13 - 24 Apr 2017    Post subject: Reply with quote
OK, fingers crossed - have ordered FH012AA MOSFET reg/rec from an R1 and connectors and decent cable and will bypass the existing loom entirely.
Hope this fixes it, otherwise it can only be that the stator is weak.. CBA to change that yet again. Cheers for the advice.
BMW R1100R
Kawasaki Jimbo
PostPosted: 13:23 - 24 Apr 2017    Post subject: Reply with quote
ferrisio wrote:
OK, fingers crossed - have ordered MOSFET reg/rec from an R1 and connectors and decent cable and will bypass the existing loom entirely.
That worked for me (on my R1) after spending a lot of time and money looking for a solution. I used https://easternbeaver.com/Main/Elec__Products/Connectors/R-R_Connectors/r-r_connectors.html. The exchange rate makes them pricier now but they're extremely well made. I'm not bad with a soldering iron but these were better.
ferrisio
PostPosted: 13:26 - 24 Apr 2017    Post subject: Reply with quote
Cheers for the link, I found a pair of new Furukawa connectors in the UK on eBay for a tenner so probably a little cheaper. Am going to solder the stator connections and run the +/- from the reg/rec direct to the battery (via 30A fuse on the +) so only one connection to be made - hope it sorts it!
BMW R1100R
Tankie
PostPosted: 16:06 - 24 Apr 2017    Post subject: Reply with quote
Sounds like a plan , also make sure there is a good continuity from battery earth to chassis.
PostPosted: 22:54 - 24 Apr 2017    Post subject: Reply with quote
You checked there is good continuity between the reg/rec and the battery?
ferrisio
PostPosted: 15:15 - 01 May 2017    Post subject: Reply with quote
Well what are the odds.. I replaced Reg/Reg with R1 MOSFET one, and ran new wires direct to the battery, still didn't work. Evil or Very Mad
Changed the stator with a cheap and nasty Chinese one I'd bought for £35 new as insurance and it works fine. I'm sure its days are numbered but it has got me out of trouble for now, I'll get the OEM one rewound I think - should be better than original then.
Didn't have a gasket, and they are a tenner for a piece of paper so made one out of a cereal box (is that still the done thing?) but it doesn't seem to be dripping any oil.
I've fitted a voltmeter so I can keep an eye on it, but I still can't work out why the stator passed all the tests (no continuity to ground, <1ohm between phases, and output voltages) fine but didn't work....?
Thanks for the advice.
BMW R1100R
ADSrox0r
PostPosted: 15:47 - 01 May 2017    Post subject: Reply with quote
IME a rewind never lasts as long as OEM. Pony up before the Chinesium Excrement takes out your R/R and/or battery (again, experience talking)
The last post was made 6 years, 361 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.08 Sec - Server Load: 0.86 - MySQL Queries: 17 - Page Size: 68.76 Kb
