Author |
Arfa__ |
Arfa__ Traffic Copper
Posted: 21:42 - 24 Apr 2017 Post subject: New clutch plates, now sticks when hot - help! |
Got a FZS600, clutch was worn and slipping lots, so just put in some brand new EBC plates and replaced springs too with EBC heavy duty ones. Fresh oil went in (Castrol Power1, Semi 10w40), plates were soaked in this for a hour beforehand too.
Now, I'm pretty certain I put all the plates back in right order, as per set coming out, with damper spring and thinner plate coming second. Pressure plate was refitted in the one position it fit flush against the plates. Torqued all springs up exactly as Haynes stipulated (8Nm). Pulling clutch lever moves plates out nicely as you'd expect. Though I did adjust it to be sure (both at sprocket cover and at lever).
Now, when bike is cold it all runs fine. Gear change is nice and smooth, slips into neutral fine. Lots of bite and kick in ass as you jump up the gears and open it up.
However, after 10 mins of running once things have warmed up the clutch will stick and stick really bad. At first it just won't go into neutral and you can feel the bike pulling forward whilst the clutch lever is pulled right in. Warm it some more, and you really have to hold the front brake in, get the revs high enough and you can almost do a burn out with the clutch lever pulled in! Stick it on centre stand in gear and you have to stamp on back brake to keep wheel still with clutch in before it soon stalls.
If I look down through oil filler I can see all the plates moving in and out as I pull lever, even when hot.
Any ideas? I'm totally puzzled here. ____________________ Beginner Biker Adventures Blog
Yamaha FZ6 S2 2007 |
Back to top |
Evil Hans |
Evil Hans World Chat Champion
Back to top |
Nope. |
Nope. World Chat Champion
Back to top |
Arfa__ |
Back to top |
Arfa__ |
Back to top |
Nope. |
Back to top |
Arfa__ |
Posted: 21:26 - 26 Apr 2017 Post subject: |
Nope. wrote: | Arfa__ wrote: |
No... Just assumed new kit specific for bike was good. |
Never assume. Go measure it and report back. |
Tipped it on side and took it all apart tonight. Didn't have a pair of calipers to accurately measure (Screwfix couldn't get any in until tomorrow), but all plates appear to be ~3mm (Haynes book quotes 2.94-3.06mm, service limit 2.8mm). Double checked kit, definitely right one for FZS600.
Took them all out anyway, inspected. Some appears a little dry of oil, so did cover them in more oil.
Also read elsewhere about the steel plates having a slight rounded edge on one side. Hadn't noticed last time, so ensure they were all same way around, rounded edge facing outwards.
Double checked basket, no obvious notches on fins etc. Also double checked movement of plates with cover off, moves out about a 1cm and running fingers along edges of plates they appears to slides easily.
Once all refitted, it's definitely better than it was now. No longer pulls when clutch is engaged, even after 30-45min stop start ride around town. However, when warm it's very reluctant to go into neutral. Big effort to pop it up out of first then will always go straight to second. And vice-versa trying to go down from second. If I kill it, it will go into neutral much easier.
So, better, but not perfect.
I've got a new clutch cable to go on, will try that next, if only to rule it out. Otherwise I'm half wondering if I should have replaced the steel plates too - weren't obviously warped, but I didn't thoroughly check them all. ____________________ Beginner Biker Adventures Blog
Back to top |
Pigeon |
Pigeon World Chat Champion
Back to top |
The last post was made 6 years, 363 days ago. Instead of replying here, would creating a new thread be more useful? |
