Honda CD125 Benly - Does not stay running?
Bike Chat Forums Index -> The Workshop Goto page Previous  1, 2, 3  Next
doggone
PostPosted: 11:14 - 30 Apr 2017    Post subject: Reply with quote
Have you established if it's 6v or 12v yet?
Clue - look at battery.
It sounds like it was able to turn it over for quite some time so probably not needing new battery anyway.
It could just be you need to get familiar with starting without flooding it.
They were inclined to be temperamental when new so 30 years on your technique will need to be right.
Since it was running initially and you haven't really used it I don't suppose it's likely anything serious has broke from a few attempts to get it started again.
A small capacity bike of this age is going to be a constant battle to keep running - not a reliable transport choice.
nazK
PostPosted: 16:28 - 30 Apr 2017    Post subject: Reply with quote
12v. Which one should I get from thise links?
Yeah I hope it's not something major although teff has mentaly prepared me for the worst.
NEW TO BIKE MAINTENANCE- HAVE CD125 BENLY
Nobby the Bastard
Harley Gaydar
PostPosted: 18:02 - 30 Apr 2017    Post subject: Reply with quote
tbh, I'd not trust you to even know what a spark plug is, let alone whether it's wet or dry.
This is based on the fact that the delivery driver can start it and you can't.
Look at the underside of the tank. There is a tap. Put it in the 'On' position.
Sprint ST 1050
nazK
PostPosted: 18:24 - 30 Apr 2017    Post subject: Reply with quote
No I will not waste anyone's time here. I will say if I don't know something. The tap was on ON position. Other positions are Off and Reserve.
I have ridden bikes before like 20 years ago, but never had to fix one!
Nobby the Bastard
Harley Gaydar
PostPosted: 18:36 - 30 Apr 2017    Post subject: Reply with quote
have you checked that there is petrol in the tank? tuned the tap off. removered toe pipe and then turned it on again to check that it actually comes out?
How about 5 mls of petrol down the spark plug holes to see of it fires when kicked over?
Sprint ST 1050
nazK
PostPosted: 18:52 - 30 Apr 2017    Post subject: Reply with quote
<<< I did that yesterday and petrol did come out
<<<< Will try this but by kicking you mean through the start button? it does not have a kick.
On another note: my previous bikes in 1990's were Suzuki GP100, Yamaha RX115, Kawasaki GTO125 , Honda CG125 and Honda CD70 and a trail can't remember what make was that
bypass2
PostPosted: 19:23 - 30 Apr 2017    Post subject: Reply with quote
Did you put the petrol in or did it come with the bike.points may need cleaning. have a check if the plugs are still sparking if not. buy some new plugs then try it.
Nobby the Bastard
Harley Gaydar
PostPosted: 19:31 - 30 Apr 2017    Post subject: Reply with quote
nazK wrote:
p
Have you charged the battery yet?
FFS...
Sprint ST 1050
nazK
PostPosted: 20:01 - 30 Apr 2017    Post subject: Reply with quote
I am replying to the messages here today only. Like I mentioned in the earlier post. I am waiting on the battery charger (from a friend who is away and back on monday) before trying anything else and also looking to buy one for myself. I have asked for which battery should I buy by sharing some links in my earlier post but still waiting for a reply. Haynes manual from ebay is also on it's way and also trying to source a toolkit.
It came with petrol in it. Plugs are new.
Once the battery is charged I will follow the points mentioned by all other members above to fix this around points, spark etc. Fingers Crossed
Nobby the Bastard
Harley Gaydar
PostPosted: 20:12 - 30 Apr 2017    Post subject: Reply with quote
So..... you have flattened the battery but are replying to suggestions that rely on you attempting to start a bike that you can't start because the battery is flat.
Enemied. Fuck off and die due to supidity.
Sprint ST 1050
nazK
PostPosted: 20:49 - 30 Apr 2017    Post subject: Reply with quote
I am not sure what pissed you off to the extent that you wish me to die. If you had read my posts I made it clear at every stage of what I am doing with the bike as the thread grows. I have just been polite to reply to incoming posts to keep it ticking. But Never Mind!
Teflon-Mike
tl;dr
PostPosted: 22:23 - 30 Apr 2017    Post subject: Reply with quote
First up, make sure yo have a 12v system.... just because the battery says 12v on the side doesn't mean that it is... and that could be a very good reason why it's not charged or staying charged!!! Don't presume, CHECK.
Next; First two are optimizers/trickle charger's not "Oh shit, Flattery.. I need a charger' charger's.
They deliver about 1/4 am, which is enough, if a bike s left in a garage to keep the charge topped up, so that natural loss is replenished and any small draw from say an alarm or immobilizer....
If you have a 12v system, it aught to have a battery rated at around 8Ah.. that rating means it can deliver 8A for one hour.... it can supply more, and will have to on the e-start.. that will suck perhaps 30A... so f you suck 4x the amps, battery will only be able to deliver it for 1/4 the time...
B-U-T... it wont.. such 'deep cycle discharge' hammers the battery electrolyte, so you probably wouldn't even get 10 minutes of sustained cranking from it, and after a couple of minutes the battery will be loosing volts, and not delivering the amps, so the starter will start to labour.. leave it to recoer a few minutes, and let the electrolyte cool and charge even accross the plates and electrolyte, it will come back up, and you might get a couple more minutes of cranking, but, you wont get the full quota suggested by the rating and it does 'wear out' the battery f you do it a lot......
Which I mention because you aluded to the battery aparetly 'self charging' when you left it; which is exactly what happens when they have bee deep cycled and left to recover, and is usually a symptom of a) a knackered battery b) a tired starter.... and the two are related; a tied starter will hammer the battery... while if the motor is past ts best and a lazy starter, you get a self defeatig cycle..... engine is hard to start, so starter has to work harder ad longer to encourage it, that hammers battery.... battery gets tired, and replaement 'seems' to make things better.... tempererily... but, it's the symptom not the cause.... cause is poorly slow startng engine; making starter work harder and wear not faster, making battery work harder and give up first.... THIs is where you start going around in circles chasing 'problems' tackling symptoms never really getting to root cases..... as mentioned!
Back to the trickle chargers.... delvering 1/4A, the battery of good, 8Ah rating would imply it would take 8hours to charge at one amp, or 32hours to charge at 1/4 amp... but agan, like deep-cycle dscharge, trickle charging needs to put in not just enough amp-hours to charge the battery, but over come the natural 'wastage'.. and at such a low charge rate, designed to do little more than replenish natural loss... you likely only get a few mili-amps of useful charge getting into the battery and the thing will take DAYS to fully charge on one.....
So, they can be useful... but mostly for folks that leave thier bikes garage trophies for long weeks between short rides...... OR for folk too tight to buy a new battery when old ones get tired and start loosing charge capacity as well as more natural wastage.....
Your £20 budget would buy you a new battery... and THAT is where I suggest you put that first bit of spend.....
Does gve you a dilemah though, as they usually come 'dry' without electrolyte and you have to fill them with an acid pack, (make sure they come with one or enough to fill, if you order on-line!).. and even though they may claim to be 'dry' charged on despatch that is never fully charged, and you really need to properly charge one before use..... which begs you buy a charger!!!
OR, fit dry charged, and kick or bump-start t and let the bike charge t up.... whch it probably wot, if it's not running right!!!!
So, later two chargers? look like ones I have in my scrap-bin, waiting for me to get round to chopping ff the croc-clips!!! Err... yeah... that doesn't sound encouraging, does it? They aint great but for the money they'll do the job.... BUT o point tryng to flog a dead battery... start fresh get a new one and eliminate a variable....
In the MEAN TIME... if you dont want your new battery 'killed' by deep-cycle' starting and diagnostics of a tired old engine and probably as tired ols starter motor... go fnd an 'almost' dead car battery, and some jump leads or 30A cooker cable to do your fiffing and faffng with....
Even a pretty dead car battery, rated at maybe 20Ah has a far higher charge capacity than a bike battery, even if it's lost half of it and wont spin a car engine over any more..... little bike starter will far less 'deep-cycle' the thig, and it will keep the starter spining hardr and longer between needing to be recharged than a bike battery will... A-N-D... who cares if deep-cycling it kills it!!! It be dead and scrap before you started! And saves the risk that you will kill brand new battery dong diagnostcs.... I actually have a rather large Land-Rover battery for that exact purpose!
hint; DO NOT, try putting jump leads from a car onto bike battery... ON THE BIKE....
Car alternators are regulated in the generator and will deliver around 16-17v, possibly as much as 19-20. Bikes have a seperate reglatr, and t is clipped at about 14v.... put a car alternator onto a bike battery vai a jump leads, with the battery still connected to the bike, and the bkes regulator will start to try and regulate the extra volts the car alternator is delivering, and get fried in short time.... Amps that car alternator bangs out are also like deep-cycle-discharge working backwards; they can typcally charge a big car battery n around 15-20 minutes.... so they can fill a lttle bike battery in a couple of minutes... charge rate can be higher even than the charge draw from a starter, and even more radily kill the electrolyte or warp plates......
At a pinch, IF you remove battery fro bike to charge off a car on jumps, and are careful to only give them a couple of minutes, ad a few minutes t settle after before fitting back to bike, it's safe 'enough', but f you do t regularly, it will be because the battery s knackered before you started, or will be pretty soon!
Oh-Kay... that's your attry issue sorted.... meanwhle... DAVE SILVER SPARES.... go look at thier web-site... you WILL get very familiar with it over the comng, as well as CMSL.....
CMSL, I think are bases in Holland; useful supplier but prces rarely the best; they do provide the orignal micro-fishe exploded diagarams and original Honda Part numbers, on line though..... DSS sell a lot more than they list, and you can get prce and availability by part-number search havg got the pt-n off CMSL!
DSS, are also pretty good on price, and over the last ten year since e-bay, I have often found they are witing a gnats of any e-bay prices; usually have better availability, and are certaily more relable, and reputeable..... so DONT presume they aregoing t be more expensive, or be put off if they dont have bit you are looking for in the list....
So, to get you started: IF you are sure you want to percevere with this perversion of mechanical masocism....
A/ Check your electrical system; make sure it IS 12v; so look at the regulator, it should be under the tank behind the head-stock and marked with a big red label telling you the voltage. Also check in the generator cover whether you have 'points' igition.
B/ Consult Dave Silver's emporium of all old Honda..... you want prices and availability (se part o's from CMSL if needs!) for:-
1/ Battery
2/ starter motor brushes
3/ Tappet key and lock-but spanner (see Handy-How2's for part numbers)
4/ tappet screws (2 off)
5/ Spark-Plugs
6/ If 6v points ignition; New points & Condenser AND new points retension screw.
c) Battery charger from whatever source, making sure, IF you don't have a 12v system, you get one that will charge a 6v battery.....
If 6v ponts gnition, order the ponts, and condenser and points retension screw, as a matter or course. These are fiddle-finger prime territory and folk get them utterly to pot, get the tmng screw and never grasp the nettle tryng to clean old worn ponts and never replacing the cndenser, o never solvng prolems..... swap out as course and gve yourself at least some chance of elimnatng variables for further diagnostics.
Other wise; I'd recommend you roder the tappet key ad lock-nut spaner, straight away; they are about £15 and save a awful lot of faff
You can have a look at what you got before you buy, by lifting the rocker cover; but IF the tappets have ever been checked, they are likely chewed to bluggery ad rounded on the 'square' at the top you tur them with, from muppets using an adjustable spanner or pliers for want of propper key! If they aren't chewed... then the other end is probably peened to buggery from havg never been adjusted! Ether way... odds is you would do well to rplace, and as they are only somthng daft like £2 each, yo might want to stick them on your first order to save postage later.....
THEN.. with the tappet tool, and a feeler guage... see Handy How2, you can elminate one variable before you start, and do a PROPER service, and set tappets and cam-chai adjustment.
If waiting for parts, I would recomnd you pull the starter solenoid; remember I said ts ce, screwed to gether and has big bits of brass isde.... strip it, clean it, and file/sad the contactor plate flat of any pits or corrosion... then douse the solenod coil in WD40 before putting to back together......
Starter? I would lay odds, and probably as many as teh motor needng top-end overhaul, that the starter is full of old brush dust ad grease, rust, water and other shit.... ad teh comutator plate the brushes run on and make contact wth, is rough, tracked, cvered carbon, and shorng windings left right ad centre......
Pull it strip t, and like the solenoid contactor plate; clean, sand omutator plate sooth and free of corrosion and worst pits, and loose carbn dust
Clean the gear pack, and re-grease; does the wndings i WD40, and re-assemble with new brushes.... this will get as uch as you can fro the starter and help avoid t killing new battery too quick.
While it's out, you will find that it ha a small chai drive to the crank, and that has a one way roller clutch behind the generator rotor.... these often get a bit whney and erratc with age; IF you ca get the geerator rotor off, then strippig that roller, and it is basically just three small metal rollers inside the starter sprocket; you can clean them up with wire-wool, grease and re-assmble and a lot of starter niggles go away. If ot does wth chain live and work the sprocket back and forth a lot between swuibs; and libe the starter chain befor re-assembly.
Again, you may do most of this whilst waitng on bits.
BUT, tappets checked & set; am-chain tensioner adjusted; starter otor re-brshd; solenod cleaned up, starter clutch and chain lubed; and new spark-plugs; remember that old car battery..... for fault findng 'crankig'.... you may have a crack at starting...
And IF you are very lucky, should fire, and if you remember comment about puttg carb settigs to the book, and winding the idle screw out until you ca get it idling hapily.... you COULD have it start, and up and runnng fairly sweetly or the effort.. and some confidence that yu can fit the new battery without frther diagnostc or troublesome starting illinh t n quck time.....
And go for a ride... see how she behaves herself....... But not too far.... remember, you might have to push her home!
BUT, that would be my order of business to gt you off the stops and started... IF you are so utterly daft as to be detrmined to percevere here.....
I would suspect that spruced up starter system and properly serviced motor, will work wonders... but for how long, I dont know... remember, resussitated from derelict, its use that starts to skade them down and find where faults lie....
I the meantime.. remember device fro above... BEFORE you try GO, make SURE you can STOP!!!! Check the tyres the brake shoes, the make cable, the steering and the suspension......and when that Hayned Manual arrves, look long and hard at the 'routine mantenance' list, and ignoe the interval recomndations; you have no garatee that aythg has been done, ever, so you probably need to do ALL of it to make sure it has been, and recntly, or will have to sooner or later! And there'll be a LOT n there to keep you busy for a while!
Have fun!
nazK
PostPosted: 15:38 - 01 May 2017    Post subject: Reply with quote
Thanks Teff and ALL!
For now:
Battery on the bike is YB9-B Powerline Battery 12V 8Ah YB9B
Got the charger form that friend and the battery is being charged.
Charge rate indicator on the charger is showing the needle pointing to just pass 3 (which is yellow marked area labeled Medium rate
3-4 AMPS)
If understood the equation correctly Teff mentioned then it should take somewhere between 2 to 3 hours at this rate but then again I am wrong most of the times Smile
nazK
PostPosted: 16:29 - 01 May 2017    Post subject: Reply with quote
Well light at the end of a tunnel...
Charged it for nearly 3 hours not knowing what to do next...
Removed the charger, let the battery settle for half an hour don't know why but read somewhere it's better to do so...
turned on the ignition, indicators, horn and head light were more bright so far so a good start
then came the big moment to try the engine....had a good look around the petrol ON position, spark plugs intact etc
But wait the choke is stubborn, tried to fiddle with it and now I got it stuck in the pull position..
forget the engine, need to sort this out. could not get the the choke back down, it is still stuck in pull position
Traced the choke cable all the way back and found it somewhere next to Carburetor.
Then I thought i can do it manually, press start button hands on throttle and manual choking and she stayed on... Don't know if the Choke was working or not but it did move up and down on the first day
She is Alive!!!!
I am over the moon... need to ensure that this moment is not short lived , I now have a project to work on further!
WD Forte
PostPosted: 17:30 - 01 May 2017    Post subject: Reply with quote
Yep, they're often found down there Very Happy
That button and cable pulls a flap at the back of the carb shut
to enrichen the fuel mixture for cold starting.
If it sticks on it will soon flood the engine and may have caused your previous problems.
Its an old bike so get to know it and check everything
Luckily it's a pretty simple machine, so if you get on the learning curve you
wont have to throw money at mechanics
Besides not all mechanics are good mechanics
and if they are they may not have much experience in older bikes.
bikers smell of wee
Chris45
PostPosted: 19:37 - 01 May 2017    Post subject: Reply with quote
Perform a visual check of the choke cable - it could be frayed (inside the protective layer) hence the reason it won't close and why the engine was stopping/refusing to start. Very common problem on throttles and older carb bikes. Alternatively there is usually a small return spring (coil type) mounted on or close to the carb which allows the choke to spring back. It might be rusted or gunged up. Clean it and apply some light grease.
Replacing the carb cable is a doddle.
Chuffed it wasn't a serious problem for you - remember to always start with the really simple issues first as 90% of the time it is!
Honda CG125>Suzuki GT185>Honda CB 250N>Suzuki GSX400>Honda CX500B>Kawasaki GPZ305> Kawasaki GPZ550>Kawasaki GPZ500S+BMW 650GS
Hong Kong Phooey
PostPosted: 20:05 - 01 May 2017    Post subject: Reply with quote
Could be the choke cable needs lubing.
Disconnect choke cable at the bar end, and tape a bag over the end of the cable and put oil in the bag, gravity will do the rest. Don't do it in the kitchen if your wife is pregnant.
Teflon-Mike
tl;dr
PostPosted: 21:06 - 01 May 2017    Post subject: Reply with quote
Is it a 'twist to lock' choke cable?
If not there is usually a lock screw to twist to hold it out.
The cable clamp on the Keihin is also rather wampy, and prone to slipping, especially if the cable lock isn't used properly.
We await further developments.....
nazK
PostPosted: 21:48 - 01 May 2017    Post subject: Reply with quote
Through some research turns out that there is a metal and round tube below the lever which allows it to lock in the position by gently turning the lever clockwise or anticlockwise and should be turned again before pushing it down. I may have unintentionaly twisted or not twisted it before pushing it down out of frustration at some point or did something to get it stuck like that.
in short I have messed it up, now the only relevant move able parts that I can see are the silver shaft or the cable going into the shaft.
Shall I try pliers on the silver shaft or on the cable end going into the shaft?
The image is form internet, my cable is still on the bike and now hanging on the side because I could not access it when it was fixed to the bracket on the top near the middle of the handle bars. Will put it back there after fixed.
Teflon-Mike
tl;dr
PostPosted: 04:02 - 02 May 2017    Post subject: Reply with quote
See the gnarled ring, below the knob, that's supposed to be under the rubber boot, that's cocked away from it in the eg pic?
The tube, is just a tube; inside is a half round, half flat bit of rod, before the flexible cable begins. the gnarled knob, should have a sort of plastic cam on it, which when twisted bites into the flat bit of the rod from the tube to apply friction to hold it out. You can use it to adjust how much twist you have to put on the push-pull knob to make it stay stuck in one possition.
Fiddle with it!
Good chance that over tightened and or ham fisted operation of the choke has mashed the friction noggin and it wont make any odds.... but worth a try!
New choke cable is about £6 or £7... so I wouldn't faff too much; it's one of those PITA points, where it's more hassle than its worth to try salvaging a well knackered cable, or living with having to hold it out, or aid with pliers and stuff!!
nazK
PostPosted: 08:33 - 02 May 2017    Post subject: Reply with quote
Yes I may have to order a new choke cable if can't get it to work, with this in the pipeline,
Updates on start /stay on:
After it starts it only stays running on a full choke.
Is there a choke - throttle with and without combination I need to follow?
and try again or is it time for carburateur?
Chris45
PostPosted: 20:20 - 02 May 2017    Post subject: Reply with quote
Jeezo...
Keep the choke on for a mile or so, then when you are up to cruising speed, close it. All carbed bikes are the same. My old CX500 needed the choke open for ages because it was watercooled and had two large pistons, i.e., took ages for the engine to warm up.
Even with my GPZ500 it takes 3 or 4 miles to warm up, and the first mile is with the choke open.
Teflon-Mike
tl;dr
PostPosted: 22:27 - 02 May 2017    Post subject: Reply with quote
How quickly are you trying to turn the choke back off after it starts?
Use choke until warm. Idling on the stand, a motor wont burn as much or get as hot as under a bit of load being ridden.. ish...
On the CG's and the bigger benly's that have a lower compression ratio, they can often be knocked off choke almost as soon as they are running... on the CB's they take a bit more warming, annd after first start need a moment or two with the choke still full on, to get some heat into the pots, but then need the choke backing off a 'bit' so they don't choke to death, but wont take much load without any choke at all, so can be a three or four stage process....
EG:
1; full choke, no throttle, hit start, till engine catches
2; knock back the choke 1/4... let idle, add a little throttle (maybe 1/8th) to get it to pick up a bit, but not bog
3/ As engine warmsm idle should start to lift, then, the chocke may be knocked back maybe to 1/2 and the throttle closed...
4/ when engine starts to race to a high idle speed, choke may be knocked back to perhaps 1/4, and revs should drop to a healthy 'normal' idle, and the engine may be put under load and ridden, the choke knocked off completely, when it starts to take load willingly, on the road.
Most bikes, and especially old bikes will have thier own preferences in how they like to be started and warmed... and they will probably change thier mind depending on the weather, and how cold or damp the day is!
Case of practice and learning what your bike likes.
I DO suspect that a tappet tickle and proper service would likely make matters easier, though; AND, jury is still out on whether it's low on compression and or burning oil, which will likely only be revealed when put into more seriouse use and put under stress on the road.
nazK
PostPosted: 13:28 - 03 May 2017    Post subject: Reply with quote
I am back to the same issue now, it's not starting
Local car workshop guys were very kind to run a test on the battery.
Battery showed 12.55 V on the terminals during the test but failed on the health check. They gave me test print which I have attached.
The next door motorcycle workshop guy was a bit skeptical about that test and even went further to help and asked me to leave the battery with them on their commercial charging unit. Guy said their charger will tell on the dashboard through different lights where does this battery stand. I didn't have anything to lose.
In the meantime I opened the spark plugs and they were black on the inside.
This time I am going to take a formal approach by learning and applying starting from the battery, to compression test, carb etc. in the whatever order. I will go through the thread to see all the suggestions especially Teffed ones:) to structure and plan the new approach
Time to take a break and share findings after a few days since secular work keeps getting in the way of bike fettling and posting replies!
Thanks All
nazK
PostPosted: 20:19 - 05 May 2017    Post subject: Reply with quote
From Light to Lightning at the end of the tunnel......
1. Battery was passed by motorcycle workshop. I tried my battery on a friend's Honda lead 100cc scooter which was not ridden since last summer. Scooter started Smile
2. Then I moved on to spark plugs, there was carbon on both of them and also a bit wet this time. Gave them a good simple clean with cloth, used safety pin inside the plug to rub off any debris and blew in to blow it away
3. Checked if fuel was running from tank to carb by removing the fuel pipe first from the control under the tank and then from the carb. It was all good
4. Slightly unscrewed the screw (right at the bottom of the carb) until fuel started to come out and also it ran through the overflow pipe. Someone asked me to do so to ensure if there was fuel in the carb, did that just to follow along
After all above, Bike started with full choke and and stayed on, gradually going down on choke to running idle with no choke while playing with the throttle following how engine was behaving. Now I have got the gist of it and she starts and stays on every time. Only one time to nearly give me a heart attack when she did not respond at all to start only to realise that I had her in the first gear Smile
I let it run for few minutes, turned it off and then let it run again but this time I turned off the fuel until it died to burn off any fuel wherever it gets flooded. I have since started the bike several times without any problem. I know her personally now Smile
Other bits after that:
5. Oil changed after a short ride to ensure maximum drain. 1.5 ltr of 10w/40 oil type I think it was. See the state of old oil in the image.
6. Choke fixed. Drained oil was transferred to a 1.75 coke bottle to be recycled. But used it to fix the choke. I dipped the top end of choke cable in that bottle to lube it for 5 mins, then used two pliers one to hold and the other one to release the stuck cable. It worked. Choke was fixed back to it's location by removing two nuts on the handle bar.
6. Top storage box from the back was removed. Seat taken off to staple down the cover which is sitting lose.
I tried to keep the cost to none but could not hep save £10 on engine oil and a Friday off from annual leave Smile
I could not have done it myself if it was not for this thread, local workshops, family and friends to lend tools and chargers and couple of YouTubers!
Thank you ALL!!!!
7. Next on : Among many other things RUST on the rims....now that is the next mission. This is not just surface rust, it's stubborn pitted ugly tough hateful .......
The last post was made 6 years, 360 days ago. Instead of replying here, would creating a new thread be more useful?
Page 2 of 3
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.16 Sec - Server Load: 0.92 - MySQL Queries: 17 - Page Size: 161.5 Kb
