Suspecting it is borked
Sload
PostPosted: 05:06 - 10 May 2017    Post subject: Suspecting it is borked Reply with quote
Bombed out a couple of times, black screen, audio in the background, power loss to monitor and fans going nuts requiring a hard reboot.
I think it gave up though, GPU fan is trying to take off from the moment you press the power and it seems to think it's hot stuff.
Do you concur?
Honda Varadero >> Triumph Speed Four >> Honda CBR1100xx
UncleFester
PostPosted: 07:00 - 10 May 2017    Post subject: Reply with quote
Take it apart and replace the thermal grease between the GPU and the heatsink.
2017 Z1000SX
PostPosted: 08:17 - 10 May 2017    Post subject: Reply with quote
And cull the dust bunnies.
What's "it"? Desktop, laptop?
If it turns out that you've cooked your GPU, the solution can be more heat. I've baked my laptop GPU more times than I've hot dinne- wait, bad analogy.
Loui5D
PostPosted: 12:06 - 10 May 2017    Post subject: Reply with quote
Clean it up first with isopropyl alcohol, once the heat sink is off use either some compressed air or a pipe cleaner or two to get rid of any dust buildup .
CaNsA
PostPosted: 13:10 - 10 May 2017    Post subject: Reply with quote
If you strip the card, and everything off the heatsink... give the HS a good clean in some hot water then put it in the sun or on a radiator to dry.
Get a dry cloth on the fan fins, be careful though because you don't want to snap one of them fuckers.
And as above, clean the GPU and replace the TIM.
Sload
PostPosted: 14:35 - 10 May 2017    Post subject: Reply with quote
Cheers peeps but I think it popped. Won't boot and just a black screen with no card output with the fan spinning.
Time to shop I think.
Probably shop around the best value, usually stick with ATI https://www.144hzmonitors.com/best-graphics-card/
Loui5D
PostPosted: 15:04 - 10 May 2017    Post subject: Reply with quote
whereabouts are you?
I have two HD7950's that i don't use anymore, you could have one of them if you want.
I haven't used them in at least two years but should still work.
Sload
PostPosted: 15:15 - 10 May 2017    Post subject: Reply with quote
Wow thanks, that is generous. I'm in the midlands but I'm ok cheers. Cash is available for a new card, I'm just tight with myself. I have two 4890s, one unused and unopened on a shelf, you're as bad as me Laughing
What about something from the 1070 range plus water cooling? Probably worth updating the monitor at this point as well really. https://www.amazon.co.uk/s/ref=nb_sb_noss_1?url=search-alias%3Dcomputers&field-keywords=nvidia+1070
First time I've managed to cook a card actually, starting to get annoyed at myself. Embarassed
M.C
PostPosted: 21:15 - 10 May 2017    Post subject: Reply with quote
GPUs tend to be the main component that fails, I wouldn't beat yourself up over it.
UncleFester
PostPosted: 21:25 - 10 May 2017    Post subject: Reply with quote
Running dual 1070 here - nice cards and cooler / more efficient in terms of power needs.
2017 Z1000SX
Sload
PostPosted: 22:05 - 10 May 2017    Post subject: Reply with quote
Need to pull the old one out and check the space before I pick one. PS seems steady and an 850. Managed to get a stress test on that before I lost the GPU fully. I'll just have to wait till the weekend when I can switch back from neets.
UncleFester
PostPosted: 22:12 - 10 May 2017    Post subject: Reply with quote
I think my current one is only a 700 and that's running two in SLI perfectly.
2017 Z1000SX
Sload
PostPosted: 17:17 - 13 May 2017    Post subject: Reply with quote
New card arrived and fitted. Big ol thing it is to replace a monster anyway.
https://www.dropbox.com/s/hsusg7coc142c73/IMG_20170513_152016.jpg?dl=0
Might need a bit of support due to weight.
https://www.dropbox.com/s/8wh15t5pkzq9mp4/IMG_20170513_152016_2.jpg?dl=0
CaNsA
PostPosted: 17:53 - 13 May 2017    Post subject: Reply with quote
that cpu cooler though
it makes me sad.
Crying or Very sad
Sload
PostPosted: 18:19 - 13 May 2017    Post subject: Reply with quote
Meh, still not bottlenecked and on the standard clock. Grabbed afterburner so ill have a nose at the graphs during use. The fans on this card do not even spin at idle, very quiet.
I fitted that cooler as a get by and never got round to changing it Laughing. Now I've blasted it with air and hoovered it all out core temps dropped by 10 degrees.
Numbers attached.
grobura This post is not being displayed because it has a low rating (Spam). Unhide this post / all posts.
The last post was made 9 years, 78 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 0.13 - MySQL Queries: 16 - Page Size: 90.88 Kb
