Author |
Jontyrider |
Jontyrider Banned
Posted: 14:48 - 21 May 2017 Post subject: Really struggling with the rear tyre right now :( |
Got a Kawa ZZR 400 which is 160/70-17.
I've removed the valve core so obviously there's no air but it is rock rock solid- the tire lever just absolutely refuses to go in- anyone got any ideas please? can't believe I've broke sweat at the first hurdle
Never had this problem with other tyres it usually just pops in under the soft tyre with a bit of a push... |
Back to top |
Bozzy |
Bozzy Traffic Copper
Back to top |
craigT19 |
craigT19 Jolly Green Giant
Posted: 15:01 - 21 May 2017 Post subject: |
you need to break the bead as it will be stuck to the rim, ive done mine in the past by putting the wheel against a wall then putting a car jack on the floor with a breeze block behind it then jacking the tyre into the wall untill the bead went.
Please excuse the drawing but its all i could do to help explain
I normally do it once per side of the wheel and the tyre comes off. ____________________ Bikes owned :- 2001 nsr125, 1999 zx6r, 2006 yzf-r1, 2009 xmax 250, 2012 yzf-r1, 2015 MT-07
Current bike : - 2016 MT-10
BCF member pops. sadly missed 1945-2003
Back to top |
stinkwheel |
Back to top |
Beehive Bedlam |
Beehive Bedlam World Chat Champion
Back to top |
Chris45 |
Chris45 Nitrous Nuisance
Back to top |
Jontyrider |
Jontyrider Banned
Posted: 16:54 - 21 May 2017 Post subject: |
Managed to break the bead with a G Clamp and a mate's special tyre irons- this one was especially hard cos the tyre's are really really old so the bead was really well set in. Was actually not bad- I always take it to the garage usually, just thought it wouldn't hurt to do it myself sometimes
cheers for the top tips, I'm sure they're all great I'll experiment with a few of them and see what consistently feels comfortable |
Back to top |
Jontyrider |
Jontyrider Banned
Posted: 19:40 - 21 May 2017 Post subject: |
If the tyre is being taken off it's almost certainly completely toast does it really matter how it's taken off tbh- couldn't you just angle grind a circular split right in the middle all the way around parallel to the wheel and then both split sides off?
I mean I can't think of a reason why you'd want to take the tyre off unless it was dead... why bother cursing and getting swollen fingers and farting like I just did.
Also what does everyone thing about this following method?
https://www.youtube.com/watch?v=4-PD48uGl4o
If it's as easy as the above video then I'll just install them that way from now on instead of the normal way I've been doing it for ages with tyre levers- then take it to the garage to inflate it- probably for free I assume. |
Back to top |
Arcane1729 |
Arcane1729 Banned
Posted: 10:53 - 22 May 2017 Post subject: |
Wow that video looks neat Jonty- not sure if he edited stuff out though and actually getting it off was just as hard as using tyre levers-
there's some actual metal in the tyres so grinding through the top will probably be really hard and also overkill-
this other video shows someone else's fail : https://www.youtube.com/watch?v=nlIbeGPI-I8
Maybe if you got to the final bit where you needed to pull off that last side of the tyre off the opposite rim edge to completely get it off: maybe then you could grind a long rectangular strip parallel on the side of the tyre which is touching the rim. I don't think there's any metal on the side of the tyre- anyone know otherwise?
Actually if there isn't maybe just a knife would do? ____________________ Kymco Super 8 (125) Honda CBR 125
A2 2017
Teflon Mike: "A man can dream... but most of them are probably best not voiced.... Folk will likely think you are just mad, sad or simply a pervert." |
Back to top |
BTTD |
BTTD World Chat Champion
Back to top |
Hawkeye1250FA |
Hawkeye1250FA World Chat Champion
Posted: 12:26 - 22 May 2017 Post subject: |
Breaking the bead is tough. I used a 6ft steel pole as a lever, with one end under a transit van and a piece of wood pushing down on the bead at the fulcrum.
It bent the pole a couple of times on the rear tyre.
Front was easy in comparison.
I like the jacking into a wall idea, and will be stealing it. ____________________ 1993 RF400R - 2002 Bandit 1200 - 2012 1250 FA |
Back to top |
Arcane1729 |
Arcane1729 Banned
Back to top |
pompousporcup... |
pompousporcup... World Chat Champion
Back to top |
Monkeypony |
Monkeypony World Chat Champion
Back to top |
kramdra |
kramdra World Chat Champion
Back to top |
Jontyrider |
Jontyrider Banned
Back to top |
V2 |
V2 Nearly there...
Posted: 06:08 - 23 May 2017 Post subject: |
Back to top |
defblade |
defblade World Chat Champion
Back to top |
doggone |
doggone World Chat Champion
Posted: 08:16 - 23 May 2017 Post subject: |
It's breaking the bead that has got harder with modern tyres having very small sidewalls to attack.
Once it's popped into the middle you only need 2 or 3 tyre levers which are useful for other jobs too.
Very easy to scratch alloy wheels though, I always start with good intentions and rim protectors but eventually get to sod it stage.
Dicking around with over-sized cable ties was interesting but he still needed a lever to ease it off, it looked very time consuming and he had a special tool to break the bead.
With a bit of lube getting them on/off is not usually too difficult.
Just make sure the side opposite where you start is firmly held into the central well.
What do home fitters do about balancing?
Provided original weights are there I have never bothered
Nothing bad happened...
When I've had them done at tyre shop he usually puts it on the rig and says seems about right anyway.
Surely it's the wheel needs balancing anyway the tyre ought to be the same weight all round. |
Back to top |
BTTD |
Back to top |
BTTD |
Posted: 08:33 - 23 May 2017 Post subject: |
doggone wrote: | What do home fitters do about balancing?
I use a static balancer on the front, and some airsoft BB's in the rear - I need an adapter to do the static balance on the rear as it's off a single sided swingarm and I haven't got around to making one. |
Back to top |
Rogerborg |
Rogerborg nimbA
Back to top |
Arcane1729 |
Arcane1729 Banned
Back to top |
Evil Hans |
Evil Hans World Chat Champion
Back to top |
Jontyrider |
Jontyrider Banned
Back to top |
The last post was made 6 years, 347 days ago. Instead of replying here, would creating a new thread be more useful? |
