Really struggling with the rear tyre right now :(
Bike Chat Forums Index -> The Workshop Goto page Previous  1, 2
PostPosted: 11:10 - 23 May 2017    Post subject: Reply with quote
So you cut a sidewall off. You've still got two sidewalls on the rim. What's changed?
Jontyrider This post is not being displayed because the poster is banned. Unhide this post / all posts.
PostPosted: 13:40 - 23 May 2017    Post subject: Reply with quote
Hmm, maybe. The inner ring of the sidewall isn't magically enlarged though, and it's still got to come over the rim. I'm willing to give it a try next time.
PostPosted: 15:06 - 23 May 2017    Post subject: Reply with quote
Livestreeeeeam iiiiiiiiiit.
MamaChrissy
PostPosted: 14:33 - 24 May 2017    Post subject: Reply with quote
jnw010 wrote:
Jontyrider wrote:
couldn't you just angle grind a circular split right in the middle all the way around parallel to the wheel and then both split sides off?
Give it a go and let us know if any of the following happens: the angle grinder grabs and flies out of your hands, the disc shatters and tries to kill you, the tyre catches fire.
Maybe none of the above, but using an angle grinder has to be the messiest way of removing a tyre.
I've used an angle grinder and yeah, all of the above happened. Plus lumps of hot rubber flying around, and the odd slip of the grinder into the wheel. Awful business.
It's not recommended as a removal method unless you just want to destroy things.
I snapped the bead on the replacement tyre too, when putting it on. That was an expensive mistake, and I couldn't work out why it wouldn't hold air until a tyre fitter took the tyre off again.
I suggest that everyone takes off and fits a tyre at home, just so they appreciate their shop tyre fitters a little bit more.
The last post was made 6 years, 340 days ago. Instead of replying here, would creating a new thread be more useful?
Page 2 of 2
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.09 Sec - Server Load: 0.43 - MySQL Queries: 17 - Page Size: 56.12 Kb
