Stripped bleed thread
Fin
PostPosted: 22:02 - 22 May 2017    Post subject: Stripped bleed thread Reply with quote
My pads had worn out so today I went to replace them, the brakes have always been shit on my XJ and I've had to pull hard to stop but they've always been fairly firm. I couldn't wedge the pads far apart to get the pistons all the way in so I decided I'd let fluid out and give them a bleed.
This was when I noticed
https://i.imgur.com/KD7yNRS.png
I hoped it was all just a sketchy design but upon the slightest unscrewing my thoughts were confirmed of it being an awful cross thread. Fluid poured out the sides straight away rather than out the top of the bleed nipple.
What can I do now? Try and re-cut the threads or will I just have to buy another calliper?
Perfect timing especially with the lovely weather right now Sad
pompousporcup...
PostPosted: 22:07 - 22 May 2017    Post subject: Reply with quote
It could have just bent at some point likely during an attempt to undo it. Is it very difficult to unscrew?
Only way you're going to find out is by getting it off.
Alternatively, wedge the fucker closed so it doesn't leak and add a bleed nipple as part of the banjo bolt. Prices showed under a tenner for the banjo and bleed nipple...
Commuter_Tim
PostPosted: 22:08 - 22 May 2017    Post subject: Reply with quote
Great Odins Raven! ...By the Beard of Zeus! etc.
How did you not notice that when you did it?
If were talking bodges, weld(JB) it shut? Laughing
More seriously, there should be enough meat for a helicoil surely?
It can't be any worse than the original aluminium thread.
I ride a Bandit 600... badly.
PostPosted: 22:35 - 22 May 2017    Post subject: Reply with quote
Drill and tap the hole the next size up and either fit an oversize nipple or loctite a bolt in there and fit a banjo bolt with a bleed nipple built in.
kramdra
PostPosted: 23:21 - 22 May 2017    Post subject: Reply with quote
Used calipers are not expensive, 15-30 quid, they often come with good pads.
The nipple needs to seat on the taper, and since yours was, the seat is probably damaged, so fixing the thread might not be adequate.
Tdibs
PostPosted: 02:46 - 23 May 2017    Post subject: Reply with quote
Ye id probably be pricing up a new caliper.
Previous : 09 Vanvan 125| 02' Sv650s || Current: 1999 Xj600n | 1992 DR650 RSE | 2005 Fazer 1000
Tracer1234
PostPosted: 02:58 - 23 May 2017    Post subject: Reply with quote
This is bring back horrible memories of my nearly borking my caliper the other day.
Definitely want to be checking out what the tapered end of the nipple and the seat look like before thinking about re-threading.
Riding: Yamaha MT-09 Tracer Occasionally Riding: 08 Suzuki SV650, Potato: 2011 Yamaha YBR Custom.
Used to ride: 2015 Yamaha MT-09 Tracer (smidsy) 09 Triumph Street Triple (P/X'd) 08 Yamaha YBR (Sold)
CBT 04/14. A: Mod 1 & 2 13/04/15
Fin
PostPosted: 21:40 - 23 May 2017    Post subject: Reply with quote
Think I'm okay boys!
https://i.imgur.com/5B8UFuh.png
Nobby the Bastard
Harley Gaydar
PostPosted: 21:52 - 23 May 2017    Post subject: Reply with quote
Why are you assuming our gender, shitlord?
Sprint ST 1050
Commuter_Tim
PostPosted: 22:49 - 23 May 2017    Post subject: Reply with quote
Inb4 the Non-Binary shitstorm.
Tdibs
PostPosted: 00:24 - 24 May 2017    Post subject: Reply with quote
Look at those oppressive white hands!
Tracer1234
PostPosted: 01:33 - 24 May 2017    Post subject: Reply with quote
Shocked
What on earth happened to that? Confused
PostPosted: 10:19 - 24 May 2017    Post subject: Reply with quote
Nathan0834 wrote:
Shocked
Disclock?
MamaChrissy
PostPosted: 14:23 - 24 May 2017    Post subject: Reply with quote
You were lucky there, Fin.
Will the internal thread be so deformed that it won't allow a new bleed nipple to seal properly, though?
colink98
PostPosted: 15:32 - 24 May 2017    Post subject: Reply with quote
lucky as fuck id say.
PCX125 (stolen) - CBF600 (current)
Ride it like you stole it.
ride sensible and not like an idiot and you wont get 6 points in one week.
The last post was made 6 years, 336 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.10 Sec - Server Load: 0.6 - MySQL Queries: 17 - Page Size: 87.29 Kb
