Author |
toler85 |
toler85 L Plate Warrior
Posted: 18:27 - 28 May 2017 Post subject: Crack and damage in the crank case |
Back to top |
V2 |
V2 Nearly there...
Posted: 18:30 - 28 May 2017 Post subject: |
a) Leave it be
b) Get it welded up
c) Buy new engine
Back to top |
Mentacycle |
Mentacycle Borekit Bruiser
Back to top |
Polarbear |
Polarbear Super Spammer
Back to top |
Pete. |
Posted: 18:52 - 28 May 2017 Post subject: |
I'd paint over that and forget about it. ____________________ a.k.a 'Geri'
Back to top |
Chris45 |
Chris45 Nitrous Nuisance
Back to top |
MCN |
MCN Super Spammer
Back to top |
kramdra |
kramdra World Chat Champion
Back to top |
Paulf |
Paulf Nova Slayer
Back to top |
Pete. |
Posted: 20:47 - 28 May 2017 Post subject: |
The damage lower down is obviously the result of a bunched chain and it's possible that the long crack is related to that but equally possible its from casting shrinkage. It's certainly no reason to cry doom, gloom, disaster and going by the state of the gear lever I'd say the bike isn't in the sort of condition that warrants spending out on new cases or engine anyway.
If it's leaking oil badly then you might want to do something but if it's just getting a bit of oil mist on the dirt leave it alone and top up as necessary. It's not going to explode on you. ____________________ a.k.a 'Geri'
Back to top |
Paulf |
Paulf Nova Slayer
Back to top |
Chris45 |
Back to top |
MCN |
MCN Super Spammer
Posted: 15:47 - 29 May 2017 Post subject: |
The crack is most probably only the outside of the 'bolt hole'.
The inside of the 'bolt hole' will obviously still be hail or the pressure from that long bolt would split the case open.
De-grease it and spray it Lada Stratus Silver.
Get on with your life. ____________________ Disclaimer: The comments above may be predicted text and not necessarily the opinion of MCN. |
Back to top |
The last post was made 6 years, 332 days ago. Instead of replying here, would creating a new thread be more useful? |
